When using the Python GUI to rectify a vector, georectification fails at
i.group. The i.group module in the GUI is assuming that georectification
is for rasters.
Steps:
1. Select "vector" at first screen (along with source map location and
mapset).
2. At second screen, select "Create / Edit Group"
3. Give group a name
4. Click "Apply"
5. Result below:
Error in command execution i.group
Execution failed: "i.group group=test"
Details:
Error: no input raster map(s) specified
as its i.* name suggests i.group et al were designed for rectifying
imagery rasters, not vectors. vectors are a modern slap-on hack only
present in the GUIs. thus a solution should be carefully considered, but
could be as simple as a new group/$GRP/VREF file. This is really an issue
for grass7 IMO and for 6.x now we'll just have to figure out some work-
around.
#1013: Wxpython - vector georectification fails at i.group
Reporter: rchirgwin | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Imagery | Version: svn-releasebranch64
Resolution: | Keywords: i.group
Platform: All | Cpu: All
Comment (by cmbarton):
In both TclTk and wxPython, the georectification GUI uses GUI code to
create a VREF file for vectors, and to parse the VREF file in the same way
as is done for rasters.
Apparently, something has broken this functionality in the current version
of the wxPython GUI. Unfortunately, I probably won't have time to look at
it for a few weeks.
Unfortunately, this bug seems to be entering the next Debian Stable
("Wheezy"), as the current version in testing still has this bug: the
"Georectify" tool cannot be used with vector maps, as it forces one to
create an imagery group.
Reporter: rchirgwin | Owner: grass-dev@…
Priority: normal | Milestone: 6.4.3
Component: Imagery | Version: 6.4.2
Keywords: i.group | Platform: All
Cpu: All |
Comment(by mmetz):
Replying to [comment:5 neteler]:
> Bug confirmed for 6.4.svn (upcoming 6.4.3).
Groups don't support vectors, the current support in the georectifier GUI
is a hack specific to the georectifier GUI. A workaround is to create a
group with a raster map, then click on the button 'Add vector map to
group...' and continue, but vector rectification will probably fail at a
later stage. Note that vector rectification similar to raster
rectification exists only in GRASS 7, not in GRASS 6. For GRASS 6, the
solution would be to disable vector support in the georectifier GUI and
implement v.group (or g.group supporting both raster and vector maps) in
G7.
Cpu: All |
Comment(by harrikoo):
Yes, it seems that the georectifier runs v.transform in the end, thus
leaving the "rectified" map to the current location and mapset, not to the
target location as one is made to expect. It is easy to move the new
vector map directory to the desired lcation/mapset/vecto -directory.
All in all, the rectifier as it is in 6.4.2 is not useable; but it does
contain working parts, and these could be used to implement a working
solution.
Cpu: All |
Comment(by mmetz):
Replying to [comment:7 harrikoo]:
solution.
What do you mean with not usable? It works fine for raster maps.
