[GRASS-dev] [GRASS GIS] #1026: Problems starting grass7 from tcsh
Reporter: huhabla | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Component: default | Version: svn-trunk
Keywords: tcsh | Platform: Linux
      Cpu: x86-32 |
I am unable to start grass from tcsh.
The following error occurs:
   File "../../dist.i686-pc-linux-gnu/grass70.tmp", line 941, in <module>
     csh_startup()
   File "../../dist.i686-pc-linux-gnu/grass70.tmp", line 670, in
csh_startup
     mail_re = re.compile(r"^ *set *mail *= *")
NameError: global name 're' is not defined
This may be related to a missing regular expression module import?
import re
will fix the bug on my system.
Getting grass7 started in a tcsh using the fix above and trying to start
the gui result in an error:
> r.info
No protocol specified
Unable to access the X Display, is $DISPLAY set properly?
> echo $DISPLAY
:0
Ticket URL: <http://trac.osgeo.org/grass/ticket/1026&gt;
Resolution: | Keywords: tcsh
  Platform: Linux | Cpu: x86-32
Comment (by glynn):
Replying to [ticket:1026 huhabla]:
Yep. This should be fixed by r41652.
> r.info
> echo $DISPLAY
:0
This is a separate issue. However, you might try:
export DISPLAY=unix:0
If that fixes it, it would appear to be an issue with your version of
wxWidgets (possibly using xcb directly rather than Xlib?).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1026#comment:1&gt;
Comment (by huhabla):
Setting the display variable unfortunately does not help:
grass_dev/grass_trunk> r.buffer
grass_dev/grass_trunk> echo $DISPLAY
:0
grass_dev/grass_trunk> setenv DISPLAY unix:0
unix:0
grass_dev/grass_trunk> setenv DISPLAY `hostname`:0
grass_dev/grass_trunk> wx-config --version-full
2.8.10.1
grass_dev/grass_trunk> cat /etc/SuSE-release
openSUSE 11.2 (i586)
VERSION = 11.2
As default the variable DISPLAY set to :0 in my shell, which works with
any other programs outside of grass.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1026#comment:2&gt;
Reporter: huhabla | Owner: grass-dev@…
Component: Default | Version: svn-trunk
      Cpu: x86-32 |
Comment(by neteler):
Is this still an issue?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1026#comment:3&gt;
Keywords: needinfo, tcsh | Platform: Linux
      Cpu: x86-32 |
Changes (by neteler):
  * keywords: tcsh => needinfo, tcsh
Ticket URL: <http://trac.osgeo.org/grass/ticket/1026#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: tcsh
  * keywords: needinfo, tcsh => tcsh
  * status: new => closed
  * resolution: => fixed
Comment:
X Display got removed from GRASS GIS 7 - this report is 5 years old.
Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1026#comment:5&gt;
