#1036: empty monitor in i.pr.classify
Reporter: arocha1980 | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Imagery | Version: 6.4.0 RCs
Keywords: i.pr i.pr.classify d.mon | Platform: Linux
Cpu: Unspecified |
While using i.pr.classify i found 2 bugs.
1- from GUI it's not possible to run i.pr.classify due to the fact that it
needs to have d.mon x0
2 (and this one is CRITICAL) First I do d.mon x0 and an empty monitor
appears
Then, when I do:
i.pr.training map=liss.1@Portugal_9 vis_map=liss342@Portugal_9
training=outfile rows=3 cols=3 class=1
No image is displayed only 3 black panels and some instructions in lower-
right panel. Instead of displaying vis_map. And, if I select randomly some
points in the black space and save I get an empty file.
Reporter: arocha1980 | Owner: grass-dev@…
Priority: major | Milestone: 6.4.0
Component: Addons | Version: 6.4.0 RCs
Keywords: i.pr, i.pr.classify, d.mon | Platform: Linux
Cpu: Unspecified |
Description changed by hamish:
Old description:
it needs to have d.mon x0
appears
Then, when I do:
some points in the black space and save I get an empty file.
New description:
appears
