#1039: i.group segmentation fault using full path name
Reporter: huhabla | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Imagery | Version: svn-trunk
Keywords: group | Platform: Linux
Cpu: x86-32 |
i.group produces a segmentation fault when called with full path name.
GRASS 7.0.svn (spearfish60):~/src/grass7.0/grass_trunk > g.list group
imagery group files available in mapset <user1>:
input_0 soil_group
GRASS 7.0.svn (spearfish60):~/src/grass7.0/grass_trunk > i.group -g
group=soil_groupsoil.br.depth@PERMANENT
soils@PERMANENT
soils.Kfactor@PERMANENT
soils.Tfactor@PERMANENT
soils.ph@PERMANENT
soils.range@PERMANENT
i.group complete.
GRASS 7.0.svn (spearfish60):~/src/grass7.0/grass_trunk > valgrind
--tool=memcheck /home/soeren/src/grass7.0/grass_trunk/dist.i686-pc-linux-
gnu/bin/i.group -g group=soil_group
==5684== Memcheck, a memory error detector.
==5684== Copyright (C) 2002-2007, and GNU GPL'd, by Julian Seward et al.
==5684== Using LibVEX rev 1854, a library for dynamic binary translation.
==5684== Copyright (C) 2004-2007, and GNU GPL'd, by OpenWorks LLP.
==5684== Using valgrind-3.3.1, a dynamic binary instrumentation framework.
==5684== Copyright (C) 2000-2007, and GNU GPL'd, by Julian Seward et al.
==5684== For more details, rerun with: -v
==5684==
==5684== Invalid read of size 4
==5684== at 0x8048FFF: main (main.c:112)
==5684== Address 0x672d78a1 is not stack'd, malloc'd or (recently) free'd
==5684==
==5684== Process terminating with default action of signal 11 (SIGSEGV)
==5684== Access not within mapped region at address 0x672D78A1
==5684==
==5684== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 3 from 1)
==5684== malloc/free: in use at exit: 824 bytes in 28 blocks.
==5684== malloc/free: 32 allocs, 4 frees, 1,683 bytes allocated.
==5684== For counts of detected errors, rerun with: -v
==5684== searching for pointers to 28 not-freed blocks.
==5684== checked 76,300 bytes.
==5684==
==5684== LEAK SUMMARY:
==5684== definitely lost: 35 bytes in 1 blocks.
==5684== possibly lost: 0 bytes in 0 blocks.
==5684== still reachable: 789 bytes in 27 blocks.
==5684== suppressed: 0 bytes in 0 blocks.
==5684== Rerun with --leak-check=full to see details of leaked memory.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1039>
