[GRASS-dev] [GRASS GIS] #1046: Compile error in gui/wxpython using make -j8
Reporter: huhabla | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: minor | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: make -j8, wxGUI | Platform: Linux
      Cpu: x86-32 |
Using "make -j8" for compilation produces and error in gui/wxpython.
Running make again solves the problem. Maybe a dependency issue?
make[1]: Leaving directory `/home/soeren/src/grass_dev/grass_trunk'
GRASS GIS compilation log
Started compilation: Mi 28. Apr 12:29:36 CEST 2010
Errors in:
/home/soeren/src/grass_dev/grass_trunk/gui/wxpython
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Mi 28. Apr 12:30:38 CEST 2010
make: *** [default] Fehler 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/1046&gt;
Component: Compiling | Version: svn-trunk
Resolution: | Keywords: make -j8, wxGUI
  Platform: Linux | Cpu: x86-32
Changes (by martinl):
  * component: wxGUI => Compiling
Ticket URL: <http://trac.osgeo.org/grass/ticket/1046#comment:1&gt;
Comment (by glynn):
Replying to [ticket:1046 huhabla]:
Please provide the error message.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1046#comment:2&gt;
Comment (by huhabla):
Replying to [comment:2 glynn]:
Here it is:
GISBASE="/1/gebbert/src/grass_dev/grass_trunk/dist.i686-pc-linux-gnu" \
         python gui_modules/menudata.py > menustrings.py
python -m py_compile /1/gebbert/src/grass_dev/grass_trunk/dist.i686-pc-
linux-gnu/etc/gui/wxpython/gui_modules/globalvar.py
   File "gui_modules/menudata.py", line 40, in <module>
     import globalvar
   File
"/1/gebbert/src/grass_dev/grass_trunk/gui/wxpython/gui_modules/globalvar.py",
line 25, in <module>
     import grass.script as grass
ImportError: No module named grass.script
make[3]: *** [menustrings.py] Error 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/1046#comment:3&gt;
Comment (by glynn):
Replying to [comment:3 huhabla]:
I think that it needs this:
--- gui/wxpython/Makefile (revision 41749)
+++ gui/wxpython/Makefile (working copy)
@@ -34,6 +34,7 @@
  menustrings.py: gui_modules/menudata.py xml/menudata.xml
         GISBASE="$(GISBASE)" \
+ PYTHONPATH="$(GISBASE)/etc/python" \
         $(PYTHON) $< > $@
  #doxygen:
Ticket URL: <http://trac.osgeo.org/grass/ticket/1046#comment:4&gt;
Comment (by glynn):
Hopefully fixed in 7.0 with r42077.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1046#comment:5&gt;
      Type: defect | Status: closed
Resolution: worksforme | Keywords: make -j8, wxGUI
Changes (by huhabla):
  * status: new => closed
  * resolution: => worksforme
Comment:
Replying to [comment:5 glynn]:
Works for me with make -j2, make -j4 and make -j8.
Thanks Glynn
Ticket URL: <http://trac.osgeo.org/grass/ticket/1046#comment:6&gt;
