#1053: After abort command v.surf.rst from wxGUI vector output of devation (devi)
couldn´t be removed, or overwrited
Reporter: jeleniste | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: v.surf.rst, wxgui, wingrass | Platform: MSWindows XP
Cpu: x86-32 |
Removing vector <devi@hutur_DEM>
Tabulka <devi> připojená k vektorové mapě <devi> neexistuje
Nelze smazat soubor <C:\Documents and Settings\BRMichalek\Dokumenty\GIS
DataBase/JTSK/hutur_DEM/vector/devi/coor>
couldn't be removed
<devi> nothing removed
I run command v.surf.rst with bad parameters (so hungry for time) after
some time i try abort command by button stop, after change of parameters,
command don't run because can't overwrite vector map of deviation (fůag
-overwrite was used), I try to use module g. remove, but layer devi is
broken and module g.remove isn't able to remove this.
Reporter: jeleniste | Owner: grass-dev@…
Component: Vector | Version: 6.4.0 RCs
Cpu: x86-32 |
Comment(by helena):
This appears to be a MSWin issue - I can confirm that on MSwindows
v.surf.rst fails to write either topology or the attribute table (or both)
for the devi file and I had to run v.build on the devi file to use it, but
the result was OK.
I cannot provide more details now because it runs fine on my Mac at home.
Perhaps the path to the vector directory is not built properly (I am just
guessing here, I have not looked at the code),
maybe it needs fixes to handle the spaces in the directory names? I also
noticed that the path above has both \ and / is that correct?
