[GRASS-dev] [GRASS GIS] #1061: Merge DB connet/DB Login/DB Test in one module
Reporter: vesnikos | Owner: grass-dev@lists.osgeo.org
Priority: minor | Milestone: 7.0.0
Component: default | Version: svn-trunk
Keywords: | Platform: Linux
      Cpu: x86-32 |
It just doesnt make sense:
With the first you set the connection, with the second you Log at the db
(in both you can choose the driver,) and with the third you test the
connection
Its a bit confusing
Ticket URL: <http://trac.osgeo.org/grass/ticket/1061&gt;
Component: Database | Version: svn-trunk
Resolution: | Keywords: db.connect, db.login
  Platform: Linux | Cpu: x86-32
Changes (by martinl):
  * keywords: => db.connect, db.login
  * component: default => Database
Ticket URL: <http://trac.osgeo.org/grass/ticket/1061#comment:1&gt;
  Reporter: vesnikos | Owner: grass-dev@…
      Type: enhancement | Status: closed
Resolution: invalid | Keywords: db.connect, db.login
  * status: new => closed
  * resolution: => invalid
Comment:
I think it perfectly follows logic of little Unix programs which are doing
just one thing. I would say that we will stay with that. The GUI front-end
is another question.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1061#comment:2&gt;
