[GRASS-dev] [GRASS GIS] #1063: v.surf.rst does not properly detect presence of z column AND smoothness column
column
Reporter: dylan | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Vector | Version: svn-develbranch6
Keywords: | Platform: Linux
      Cpu: x86-32 |
When specifying both zcolumn and scolumn to v.surf.rst I get the following
error:
"Only smoothing column defined, zcol or -z flag is missing"
Here is the incantation:
v.surf.rst in=combined_pts scolumn=smooth zcolumn=Elev_Obs
mcurv=combined_mcurv elev=combined_elev aspect=combined_asp
slope=combined_slope dmin=0.1 tension=40 devi=combined_elev_devi --o
I know that this command worked in a previous version of GRASS65, and
commenting out the relevant code block allowed me to get my work done:
// commented these lines
if ((!zcoord || !zcol) && scol)
    G_fatal_error(_("Only smoothing column defined, zcol or -z flag is
missing"));
I looked over main.c in the v.surf.rst directory, but couldn't identify
what is causing this bug.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1063&gt;
column
Reporter: dylan | Owner: grass-dev@…
      Cpu: x86-32 |
Comment(by mmetz):
Hopefully fixed in r43599.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1063#comment:1&gt;
