[GRASS-dev] [GRASS GIS] #1064: v.in.mapgen fails to load coastline from NOAA's National Geophysical Data Center
Center
Reporter: vesnikos | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.in.mapgen, mapgen, NOAA | Platform: Linux
      Cpu: x86-32 |
when im trying to input a costline in mapgen format taken from the said
site, I encounter the following:
v.in.mapgen input=/home/nikos/datagis/coastline/6888.dat output=coastline
   File "/home/nikos/grass7/grass-7.0.svn/scripts/v.in.mapgen", line 198,
in <module>
     main()
   File "/home/nikos/grass7/grass-7.0.svn/scripts/v.in.mapgen", line 129,
in main
     outf.write(" %.8f %.8f %.8f\n" % tuple(map(float,point)))
ValueError: invalid literal for float(): #
GRASS 7.0.svn (wsg84):~/grass7/bin > v.in.mapgen
in <module>
     main()
   File "/home/nikos/grass7/grass-7.0.svn/scripts/v.in.mapgen", line 170,
in main
     user = user, host = host)
   File "/usr/lib/python2.6/string.py", line 172, in substitute
     return self.pattern.sub(convert, self.template)
   File "/usr/lib/python2.6/string.py", line 162, in convert
     val = mapping[named]
KeyError: 'proj'
with the following command:
v.in.mapgen -f input=/home/nikos/datagis/coastline/6888.dat
output=coastline
in <module>
     main()
in main
Im attaching the said coastline for further investigation.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1064&gt;
Center
      Type: defect | Status: closed
Resolution: duplicate | Keywords: v.in.mapgen, mapgen, NOAA
  Platform: Linux | Cpu: x86-32
Changes (by vesnikos):
  * status: new => closed
  * resolution: => duplicate
Comment:
oops I've duplicated it by mistake.
here's the other :
http://trac.osgeo.org/grass/ticket/1065
Ticket URL: <http://trac.osgeo.org/grass/ticket/1064#comment:1&gt;
