[GRASS-dev] [GRASS GIS] #1073: G_fatal_error segfault outside of GRASS session
Reporter: kyngchaos | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: | Platform: MacOSX
      Cpu: OSX/Intel |
When any module is run outside of a GRASS session, G_fatal_error itself
segfaults. This causes a loop for a while until the system gives up.
From the OSX crashlog:
OS Version: Mac OS X 10.6.3 (10D573)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_PROTECTION_FAILURE at 0x00007fff5f3fec50
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libgrass_gis.dylib 0x000000010006d364 vfprint_error +
20
1 libgrass_gis.dylib 0x000000010006db22 G_fatal_error +
170
2 libgrass_gis.dylib 0x000000010006d046 G_getenv + 37
3 libgrass_gis.dylib 0x000000010006d468 vfprint_error +
280
4 libgrass_gis.dylib 0x000000010006db22 G_fatal_error +
170
5 libgrass_gis.dylib 0x000000010006d046 G_getenv + 37
6 libgrass_gis.dylib 0x000000010006d468 vfprint_error +
280
7 libgrass_gis.dylib 0x000000010006db22 G_fatal_error +
170
This repeats for about 510 lines. I believe it should be printing a
message that I need to run the module within a GRASS session.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1073&gt;
Resolution: | Keywords:
  Platform: MacOSX | Cpu: OSX/Intel
Comment (by glynn):
Replying to [ticket:1073 kyngchaos]:
In 7.0, r40465 was made to protect against infinite recursion. At that
time, it was determined that the issue couldn't arise with 6.x, but either
that was incorrect or something has changed.
AFAICT, the issue is due to log_error calling G_gisbase(); I have no idea
why it's doing this, as it uses the result as a truth value, but
G_gisbase() ends up calling G_fatal_error() if GISBASE is unset.
In any case, something similar to r40465 will work for 6.x.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1073#comment:1&gt;
Reporter: kyngchaos | Owner: grass-dev@…
Component: LibGIS | Version: 6.4.0 RCs
Keywords: G_fatal_error() | Platform: MacOSX
      Cpu: OSX/Intel |
Changes (by hamish):
  * keywords: => G_fatal_error()
  * component: Default => LibGIS
Comment:
still happening?
I get a complaint about "error while loading shared libraries, cannot open
shared object file: No such file or directory" if I try to run a C module
outside of a GRASS session.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1073#comment:2&gt;
      Cpu: OSX/Intel |
Comment(by glynn):
Replying to [comment:2 hamish]:
open shared object file: No such file or directory" if I try to run a C
module outside of a GRASS session.
That's to be expected; the loader needs LD_LIBRARY_PATH (DYLD_LIBRARY_PATH
on OSX, PATH on Windows) to be set in order to locate the GRASS libraries.
To check for this specific issue, either set PATH and LD_LIBRARY_PATH
(etc) manually, or start a GRASS session then manually unset GISBASE and
GISRC with:
export -n GISBASE GISRC
Ticket URL: <https://trac.osgeo.org/grass/ticket/1073#comment:3&gt;
Priority: normal | Milestone: 6.4.4
      Cpu: OSX/Intel |
Changes (by neteler):
  * milestone: 6.4.0 => 6.4.4
Comment:
Replying to [comment:1 glynn]:
itself segfaults. This causes a loop for a while until the system gives
up.
Backported to 6.5.svn in r52774. Still open for 6.4.svn.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1073#comment:4&gt;
      Cpu: OSX/Intel |
Comment(by hamish):
Replying to [comment:4 neteler]:
itself
up.
time, it
that was
to do now or later?
H
Ticket URL: <https://trac.osgeo.org/grass/ticket/1073#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: G_fatal_error()
  * status: new => closed
  * resolution: => fixed
Comment:
Backported to relbr64 in r60002
Tested with (as per comment:2)
export -n GISBASE GISRC ; g.version -r
No more segfault. Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1073#comment:6&gt;
