[GRASS-dev] [GRASS GIS] #1079: wxpython GUI error in d.vect
Reporter: Lluis | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Keywords: Display, d.vect, wxpython, add vector layer, no response | Platform: MSWindows XP
      Cpu: x86-32 |
When I am starting GRASS ('''wxpython GUI''') in a __Windows OS__, there
is an error when I try to display a vector map (d.vect) '''using the icon
on the GUI'''. If I do it through the command line (d.vect roads)
automatically the vector layer is displayed but, if I try to do it using
the add vector map layer button, the software hangs itself (is not
responding)...
I've downloaded: http://josef.fsv.cvut.cz/wingrass/grass64/WinGRASS-6.4.
SVN-r42329-1-Setup.exe
In my ubuntu 9.10 GRASS64 -wxpython it works properly but most of my
students are Windows users.
Thanks in advance
Lluís
Ticket URL: <http://trac.osgeo.org/grass/ticket/1079&gt;
  Priority: blocker | Milestone: 6.4.0
Resolution: | Keywords: Display, d.vect, wxpython, add vector layer, no response
  Platform: MSWindows XP | Cpu: x86-32
Changes (by Lluis):
  * priority: critical => blocker
Ticket URL: <http://trac.osgeo.org/grass/ticket/1079#comment:1&gt;
Comment (by martinl):
Replying to [ticket:1079 Lluis]:
responding)...
Are you running from MSYS or CMD? Seems to be duplicate of #1020.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1079#comment:2&gt;
Resolution: | Keywords: wingrass, d.vect
Changes (by martinl):
  * keywords: Display, d.vect, wxpython, add vector layer, no response =>
               wingrass, d.vect
Ticket URL: <http://trac.osgeo.org/grass/ticket/1079#comment:3&gt;
  Reporter: Lluis | Owner: grass-dev@…
      Type: defect | Status: closed
Resolution: duplicate | Keywords: wingrass, d.vect
  * status: new => closed
  * resolution: => duplicate
Ticket URL: <https://trac.osgeo.org/grass/ticket/1079#comment:4&gt;
