[GRASS-dev] [GRASS GIS] #108: wxgrass: trying to add legend gives UnicodeDecodeError
Reporter: mlennert | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Python | Version: svn-trunk
Keywords: wxgrass legend unicode |
In the map display, clicking on "Add overlay", then on legend, then on OK
in the window that appears, gives the following error:
   File "/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-
gnu/etc/wxpython/gui_modules/mapdisp.py", line 3207, in AddBarscale
self.Map.Render(force=True)
gnu/etc/wxpython/gui_modules/render.py", line 654, in Render
if not layer.Render():
gnu/etc/wxpython/gui_modules/render.py", line 133, in Render
stderr=None)
gnu/etc/wxpython/gui_modules/gcmd.py", line 355, in __init__
message="%s '%s'%s%s%s %s%s" %
UnicodeDecodeError
'ascii' codec can't decode byte 0xc3 in position 17: ordinal not in
range(128)
grass svn-head 20080327 python-wxgtk 2.8.7.1 python 2.4.4
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/108&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
Resolution: | Keywords: wxgrass legend unicode
Comment (by mlennert):
Sorry, forgot to mention that this is on Debian/Etch GNU/Linux.
Ticket URL: <http://trac.osgeo.org/grass/ticket/108#comment:1&gt;
  Reporter: mlennert | Owner: martinl
      Type: defect | Status: assigned
Changes (by martinl):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Ticket URL: <http://trac.osgeo.org/grass/ticket/108#comment:2&gt;
Comment (by martinl):
Should be fixed in trunk now, r30878. For adding legend you need to
specify raster map name in the properties dialog. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/108#comment:3&gt;
Seems to be fixed, but see other error (#107).
However, would it be possible to preset the raster map name to the
currently selected map, if it is a raster ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/108#comment:4&gt;
Replying to [comment:4 mlennert]:
Implemented, see r30922. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/108#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wxgrass legend unicode
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/108#comment:6&gt;
