#1082: r.random cover= gets stray data in first and last rows
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: r.random | Platform: Linux
Cpu: x86-32 |
spearfish:
g.region rast=elevation.dem
r.random in=elevation.dem cover=fields n=10000 rast=randout
WARNING: Only [6248] random points created
the resulting "randout" map is nicely filled with random dots but on the
first and last row of the output raster map there are chunks of solid dots
which are created no matter what you do.
a more obvious example:
r.random in=elevation.dem cover=fields n=5 rast=randout
Collecting Stats...
100%
Writing raster map <randout> ...
WARNING: Only [3] random points created
# ok, so we should expect n=3 in the output map...
r.univar randout | grep -w 'n:'
n: 248
stray blocks of cells are in the same place regardless of n=.
also, for cover= it would be nice if random.c looped while(nt) so that it
ran in multiple passes and you got as many points as you asked for, not
less. (like v.random.cover addon does for points)
I thought about adding nt++ inside is_null_value(cover){...} in the column
for-loop to counter-act the nt--, but I worry that may harm the overall
randomness "density" of the rows for-loop. (just a hunch, I haven't proven
that to myself)
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1082>
