[GRASS-dev] [GRASS GIS] #1083: Wingrass7 - versioned libgrass needed for start, unversioned libgrass needed for wxnviz
needed for wxnviz
Reporter: hellik | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Component: Packaging | Version: svn-trunk
Keywords: wingrass, wxnviz, libgrass | Platform: MSWindows Vista
      Cpu: x86-32 |
from the dev-ml
(http://lists.osgeo.org/pipermail/grass-dev/2010-June/050750.html)
>-----Ursprüngliche Nachricht-----
>Von: Martin Landa
>Gesendet: 05.06.2010 23:58:48
>An: Hamish
>Betreff: Re: [GRASS-dev] WinGrass65 + import gui_modules.nviz_tools as
nviz_tools: ImportError
>Hi,
>2010/6/5 Hamish
>> I haven't been paying too much attention, but it would seem to me that
if
>> you are moving libraries out of the private $GISBASE tree and into the
>> public osgeo4w lib dir, removing the versioning from the files is the
last
>> thing you'd want to do.
>Helmut is trying to do the opposite thing. He is moving grass libs
>from public osgeo4w lib dir into the private $GISBASE tree. It's quite
>reasonable approach for WinGRASS installer.
I will revert r42490, because WinGrass7 (from the WinGrass-installer)
seems to need versioned libgrass_*.7.0.svn.dll in C:\Program Files\GRASS-
70-SVN\extralib for
starting and unversioned libgrass_*.dll C:\Program Files\GRASS-70-SVN\lib
for
wxnviz. with r42490 WinGrass7 isn't starting, with reverted r42490
WinGrass7 is
starting but wxnviz (3D view mode) isn't working.
I will open a ticket because a duplication of files should be avoided.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1083&gt;
needed for wxnviz
Reporter: hellik | Owner: grass-dev@…
      Cpu: x86-32 |
Changes (by martinl):
* cc: martinl (added)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1083#comment:1&gt;
needed for wxnviz
      Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass, wxnviz, libgrass
  Platform: MSWindows Vista | Cpu: x86-32
Changes (by hellik):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [ticket:1083 hellik]:
> from the dev-ml
closing ticket, wingrass7 starts and wxnviz works.
reopen if needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1083#comment:2&gt;
