#1092: WinGrass + R's installation path in %PATH%
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Packaging | Version: svn-releasebranch64
Keywords: wingrass, R | Platform: MSWindows Vista
Cpu: Unspecified |
I have installed the WinGrass64-installer and R 2.11.1 on my
WinVista32-box.
the wingrass-installer delivers a command line.
in the command line during a Grass-session you can change to the
installation folder of R
and then you are able to start R inside a Grass-session.
it would be nice to have the R's installation path in %PATH%, so you can
start R directly
in the WinGrass-delivered command line.
Cpu: Unspecified |
Comment(by hellik):
Replying to [ticket:1092 hellik]:
WinVista32-box.
start R directly
> From the R-Windows-FAQ:
> (http://cran.r-project.org/bin/windows/base/rw-FAQ.html#Does-R-use-the-
Registry_003f)
> "Does R use the Registry?" => this would maybe a starting point
> maybe something for 6.4.1?
> best regards
> Helmut
patches added for Grass64, Grass65, Grass7.
this improves the Grass+R-integration on Windows (in the case R is
installed before a grass-installation).
Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:4 hellik]:
> Replying to [comment:3 neteler]:
> > Looks like a harmless improvement to me which will help the GRASS-R
users a lot.
> > +1 for adding to SVN.
> done for trunk (r42740) and grass65 (r42742) in a slightly different
way.
> Helmut
