#1093: wxModeler does not accept r.mapcalc action
Reporter: timmie | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: wxGUI | Version: unspecified
Keywords: | Platform: Linux
Cpu: Unspecified |
Trying the modeler, it comes not possible to add a action using the
r.mapcalc module.
Keywords: modeler | Platform: Linux
Cpu: Unspecified |
Changes (by martinl):
* cc: grass-dev@… (added)
* keywords: => modeler
Comment:
The reason is that r.mapcalc in GRASS 6.5 doesn't use the parser, in the
result wxGUI cannot generated dialog for this command. Try r.mapcalculator
instead. This problem is not related to GRASS 7 (r.mapcalc uses in GRASS 7
the parser).
Reporter: timmie | Owner: martinl
Type: defect | Status: assigned
Component: wxGUI | Version: svn-develbranch6
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:1 martinl]:
the parser).
If you want "raw" r.mapcalc from the GUI, it wouldn't be particularly hard
to add a front-end script which implements the 7.0 semantics (i.e.
expression= and file= options). E.g. (untested, boilerplate omitted):
if [ -n "$GIS_OPT_EXPRESSION" ] ; then
exec r.mapcalc "$GIS_OPT_EXPRESSION"
elif [ -n "$GIS_OPT_FILE" ] ; then
exec r.mapcalc < "$GIS_OPT_FILE"
else
echo "Either expression= or file= must be given" >&2
exit 1
fi
hard to add a front-end script which implements the 7.0 semantics (i.e.
