[GRASS-dev] [GRASS GIS] #110: db/drivers/dbf fail to build due to undefined reference to 'SASetupDefaultHooks'
Reporter: marisn | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: |
Revision: 30825
OS: Ubuntu 7.10 64bit
gcc -L/home/dace/soft/grass_trunk/dist.x86_64-unknown-linux-gnu/lib -Wl,
--export-dynamic -Wl,-rpath-link,/home/dace/soft/grass_trunk/dist.x86_64-
unknown-linux-gnu/lib -o /home/dace/soft/grass_trunk/dist.x86_64-
unknown-linux-gnu/driver/db/dbf OBJ.x86_64-unknown-linux-gnu/column.o OBJ.
x86_64-unknown-linux-gnu/cursor.o OBJ.x86_64-unknown-linux-gnu/db.o OBJ.
x86_64-unknown-linux-gnu/dbfexe.o OBJ.x86_64-unknown-linux-gnu/describe.o
OBJ.x86_64-unknown-linux-gnu/driver.o OBJ.x86_64-unknown-linux-gnu/error.o
OBJ.x86_64-unknown-linux-gnu/execute.o OBJ.x86_64-unknown-linux-
gnu/fetch.o OBJ.x86_64-unknown-linux-gnu/listtab.o OBJ.x86_64-unknown-
linux-gnu/main.o OBJ.x86_64-unknown-linux-gnu/select.o OBJ.x86_64-unknown-
linux-gnu/str.o OBJ.x86_64-unknown-linux-gnu/table.o OBJ.x86_64-unknown-
linux-gnu/create_table.o -lgrass_dbmidriver -lgrass_dbmibase -lgrass_gis
-lgrass_datetime -lz -lgrass_dbstubs -lgrass_dbmibase -lgrass_gis
-lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz
-lgrass_gis -lgrass_datetime -lz -lgrass_dbmibase -lgrass_gis
-lgrass_datetime -lz -lgrass_sqlp -lgrass_shape -lgrass_dbstubs
-lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis
-lgrass_datetime -L/usr/lib -lgdal1.4.0 -lm -lz
gnu/lib/libgrass_shape.so: undefined reference to `SASetupDefaultHooks'
collect2: ld returned 1 exit status
make: *** [/home/dace/soft/grass_trunk/dist.x86_64-unknown-linux-
gnu/driver/db/dbf] Error 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/110&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
Keywords: |
Revision: 30825
/home/dace/soft/grass_trunk/dist.x86_64-unknown-linux-gnu/lib/libgrass_shape.so:
Those calls were added in the latest revision:
    r30804 | neteler | 2008-03-30 10:21:48 +0100 (Sun, 30 Mar 2008) | 1 line
    sync'ed to GDAL SVN-trunk: gdal/ogr/ogrsf_frmts/shape/
They appear to be part of GDAL, so GDAL is now a dependency of the DBF
driver:
    r30820 | neteler | 2008-03-30 20:23:55 +0100 (Sun, 30 Mar 2008) | 1 line
    added GDALLIBS for SASetupDefaultHooks
You say that you're using r30825, and your link command has -lgdal, so
it may be that you need a newer version of GDAL.
Markus: is this change really necessary? Specifically, is the
GDAL-isation actually necessary?
AFAICT, apart from some sanity checks in SHPReadObject(), the change
is almost entirely down to using GDAL's custom I/O interface.
I would have thought it would be better to just add the sanity checks
and do without GDAL's I/O interface, particularly as the code can only
ever use the default hooks (which presumably are just the stdio
function).
Resolution: | Keywords: dbf
Changes (by marisn):
  * keywords: => dbf
Comment:
On 32bit Gentoo box with gdal-1.5.0 GRASS trunk rev. 30831 compiles just
fine, but any module, that uses dbf, fails with error:
dbmi: Protocol error
WARNING:Cannot open select cursor
(gdb) run -a map=geology@PERMANENT east_north=592948.879668,4927119.3361
distance=296.261682243
Starting program: /home/ddd/soft/grass_trunk/dist.i686-pc-linux-
gnu/bin/v.what -a map=geology@PERMANENT
east_north=592948.879668,4927119.3361 distance=296.261682243
[Thread debugging using libthread_db enabled]
[New Thread 0xb751e6d0 (LWP 17661)]
East: 592948.879668
North: 4927119.3361
Map: geology
Mapset: PERMANENT
Objekta tips: Laukums
Kavadrātmetri: 10056250.000
Hektāri: 1005.625
Akri: 2484.893
Kvadrātjūdzes: 3.8826
Līmenis: 1
Kategorija: 6
Driver: dbf
Database: /home/ddd/hdo/maris/gis_dati/spearfish60/PERMANENT/dbf/
Table: geology
Key column: cat
BRĪDINĀJUMS:Cannot open select cursor
Program received signal SIGPIPE, Broken pipe.
[Switching to Thread 0xb751e6d0 (LWP 17661)]
0xb7fb0410 in __kernel_vsyscall ()
(gdb) bt
#0 0xb7fb0410 in __kernel_vsyscall ()
#1 0xb79b7453 in write () from /lib/libc.so.6
#2 0xb79651d7 in _IO_file_write () from /lib/libc.so.6
#3 0xb7964e85 in ?? () from /lib/libc.so.6
#4 0xb7965136 in _IO_file_xsputn () from /lib/libc.so.6
#5 0xb795b19f in fwrite () from /lib/libc.so.6
#6 0xb7f77f4b in db__send (buf=0xbfe42d70, size=4) at xdr.c:80
#7 0xb7f78c55 in db__send_int (n=101) at xdrint.c:9
#8 0xb7f78d22 in db__start_procedure_call (procnum=101) at
xdrprocedure.c:11
#9 0xb7edc3b9 in db_close_database (driver=0x80e5730) at c_closedb.c:17
#10 0xb7a5d948 in F_generate (drvname=0x80e3e18 "dbf",
     dbname=0x809ec88
"/home/ddd/hdo/maris/gis_dati/spearfish60/PERMANENT/dbf/",
tblname=0x80e3df8 "geology",
     key=0x80e3e08 "cat", keyval=6, frmname=0x0, frmmapset=0x0,
edit_mode=1, format=2, form=0xbfe447dc)
     at generate.c:88
#11 0x0804a864 in what (east=592948.87966800004, north=4927119.3361,
maxdist=296.261682243, width=7, mwidth=9,
     topo=0, showextra=1) at what.c:276
#12 0x08049ae4 in main (argc=5, argv=0xbfe42db0) at main.c:175
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:1&gt;
Comment (by kyngchaos):
Looking at the GDAL copy of the shapelib, I see that SASetupDefaultHooks
is in a new file: shp_vsi.c. This should probably be added to GRASS'
copy.
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:2&gt;
Ack, shp_vsi.c is a GDAL thing - it's an interface between shapelib and
GDAL's VSI service. Maybe we need to go back to the previous shapelib?
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:3&gt;
'SASetupDefaultHooks' (SHAPELIB)
Changes (by neteler):
* cc: warmerdam (added)
  * summary: db/drivers/dbf fail to build due to undefined reference to
              'SASetupDefaultHooks' => db/drivers/dbf fail to
Comment:
Doesn't http://trac.osgeo.org/grass/changeset/30820 fix the problem? It
did so for me.
I think that we should fix it instead of reverting to the older and buggy
SHAPELIB.
The last years it was always in sync.
PS: I cc to Frank for further insights.
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:4&gt;
Comment (by hamish):
Any clarification on if it will work with GDAL < 1.5.0?
(I can test that, later)
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:5&gt;
Comment (by neteler):
Question to Frank: Should we stop syncing SHAPELIB from GDAL? I dunno.
At least it will become hard to backport SHAPELIB fixes in future.
Comment from Glynn:
On Mon, Mar 31, 2008 at 2:26 PM, Glynn Clements <glynn@gclements.plus.com>
> driver:
> function).
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:6&gt;
Comment (by glynn):
Replying to [comment:4 neteler]:
did so for me.
The new code only works with very recent versions of GDAL.
buggy SHAPELIB.
By all means sync the bugfixes, but not the gdal-isation.
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:7&gt;
Comment (by rouault):
kyngchaos gave the solution.
All you need to do is to replace the implementation of shp_vsi.c that is
done in GDAL by the one which is most appropriate to GRASS if there is an
abstraction I/O layer in GRASS (I don't know GRASS). One of the solutions
is just to do a trivial implementation thats maps the VSI_SHP_Open
/VSI_SHP_Seek/VSI_SHP_Write/VSI_SHP_Read/VSI_SHP_Flush/VSI_SHP_Tell_VSI_SHP_Close
to fopen/fseek/fwrite/fread/fflush/ftell/fclose.
And you should be able to continue to sync dbfopen.c, shpopen.c and
shapefil.h
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:8&gt;
As suggested by Frank, I have added safileio.c:
http://trac.osgeo.org/grass/changeset/30934
If I now remove the GDAL dependency from db/driver/dbf/Makefile it does
not compile. If I keep it, it compiles. Problem solved?
On Wed, Apr 9, 2008 at 7:01 PM, Frank Warmerdam <warmerdam pobox.com>
wrote:
> Folks,
> I'm just trying to catch up on this topic. There is already a stdio
> based implementation in shapelib itself. I have attached it,and it is
> normally in a file called safileio.c.
> I'm afraid I'm uncertain of the implications of mixing the Shapelib 1.3
> code with GDAL's using Shapelib 1.2. It seems potentially like it
could
> be a problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:9&gt;
Frank,
a question remains: how to get updates for safileio.c?
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:10&gt;
Comment (by martinl):
Replying to [comment:9 neteler]:
well, it is possible now to compile shapelib and dbf driver. Copying
vector map using dbf driver fails
GRASS 6.3.svn (spearfish60):~/smetiste/grass_trunk > g.copy vect=soils,s
Copy vector <soils@PERMANENT> to current mapset as <s>
WARNING: Cannot open select cursor: 'select * from soils where 0 = 1'
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:11&gt;
Nope.
First, the Makefile doesn't actually compile safileio.c.
Once that's fixed (remove the LIB_OBJS setting), you get an error
because safileio.c is out of sync with shapefil.h:
  safileio.c:185: error: structure has no member named `Remove'
  safileio.c:188: error: structure has no member named `Atof'
Synchronising the versions of those two files should eliminate the
problem.
Even R. suggests: if running Linux i386 or amd64, 'valgrind --trace-
children=yes db.select xxxxx' will report memory errors on all forked
processes. Currently discussed in gdal (IRC)
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:12&gt;
Comment (by dylan):
Replying to [comment:12 neteler]:
Here is my output (Debian/Unstable x86 32-bit)
valgrind --trace-children=yes db.select bugsites
==9294== Memcheck, a memory error detector.
==9294== Copyright (C) 2002-2007, and GNU GPL'd, by Julian Seward et al.
==9294== Using LibVEX rev 1804, a library for dynamic binary translation.
==9294== Copyright (C) 2004-2007, and GNU GPL'd, by OpenWorks LLP.
==9294== Using valgrind-3.3.0-Debian, a dynamic binary instrumentation
framework.
==9294== Copyright (C) 2000-2007, and GNU GPL'd, by Julian Seward et al.
==9294== For more details, rerun with: -v
==9294==
==9295== Memcheck, a memory error detector.
==9295== Copyright (C) 2002-2007, and GNU GPL'd, by Julian Seward et al.
==9295== Using LibVEX rev 1804, a library for dynamic binary translation.
==9295== Copyright (C) 2004-2007, and GNU GPL'd, by OpenWorks LLP.
==9295== Using valgrind-3.3.0-Debian, a dynamic binary instrumentation
framework.
==9295== Copyright (C) 2000-2007, and GNU GPL'd, by Julian Seward et al.
==9295== For more details, rerun with: -v
==9295==
framework.
==9295==
==9295== Use of uninitialised value of size 4
==9295== at 0x44F6F4C: VSIFReadL (cpl_vsil.cpp:423)
==9295== by 0x461EAA1: VSI_SHP_Read (shp_vsi.c:53)
==9295== by 0x40EC994: DBFOpenLL (in
/usr/local/grass-6.3.svn/lib/libgrass_shape.6.3.svn.so)
==9295== by 0x40EC5A9: DBFOpen (in
==9295== by 0x804F237: load_table_head (in
/usr/local/grass-6.3.svn/driver/db/dbf)
==9295== by 0x804BA51: execute (in
==9295== by 0x804EC11: db__driver_open_select_cursor (in
==9295== by 0x402B82D: db_d_open_select_cursor (in
/usr/local/grass-6.3.svn/lib/libgrass_dbmidriver.6.3.svn.so)
==9295== by 0x402BE9D: db_driver (in
==9295== by 0x804EBAB: main (in /usr/local/grass-6.3.svn/driver/db/dbf)
==9295==
==9295== Invalid read of size 4
==9295== at 0x44F6F63: VSIFReadL (cpl_vsil.cpp:423)
==9295== Address 0x4f46424c is not stack'd, malloc'd or (recently) free'd
==9295==
==9295== Process terminating with default action of signal 11 (SIGSEGV)
==9295== Access not within mapped region at address 0x4F46424C
==9295==
==9295== ERROR SUMMARY: 2 errors from 2 contexts (suppressed: 109 from 1)
==9295== malloc/free: in use at exit: 84,377 bytes in 52 blocks.
==9295== malloc/free: 82 allocs, 30 frees, 121,294 bytes allocated.
==9295== For counts of detected errors, rerun with: -v
==9295== searching for pointers to 52 not-freed blocks.
==9295== checked 3,163,220 bytes.
==9295==
==9295== LEAK SUMMARY:
==9295== definitely lost: 32 bytes in 2 blocks.
==9295== possibly lost: 67 bytes in 2 blocks.
==9295== still reachable: 84,278 bytes in 48 blocks.
==9295== suppressed: 0 bytes in 0 blocks.
==9295== Rerun with --leak-check=full to see details of leaked memory.
==9294==
==9294== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 23 from 1)
==9294== malloc/free: in use at exit: 6,881 bytes in 74 blocks.
==9294== malloc/free: 148 allocs, 74 frees, 276,120 bytes allocated.
==9294== For counts of detected errors, rerun with: -v
==9294== searching for pointers to 74 not-freed blocks.
==9294== checked 118,464 bytes.
==9294==
==9294== LEAK SUMMARY:
==9294== definitely lost: 3,949 bytes in 8 blocks.
==9294== possibly lost: 0 bytes in 0 blocks.
==9294== still reachable: 2,932 bytes in 66 blocks.
==9294== suppressed: 0 bytes in 0 blocks.
==9294== Rerun with --leak-check=full to see details of leaked memory.
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:13&gt;
Comment (by dylan):
with GRASS (r30956) and GDAL (r14266) I no longer get DBMI errors.
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:14&gt;
Nope.
problem.
I've committed a temporary fix for this; however, it involved manually
fixing safileio.c to be compatible with shapefil.h. It would be
preferable to use matching versions of the original GDAL files.
In the Valgrind log, it's clear that it was the GDAL's SASetupDefaultHooks
version that was used. I guess that if things are right now with GRASS
r30956, it's because safileio.c has been added to the GRASS tree now, and
that its SASetupDefaultHooks version that is used now.
However, it's really risky to have a library 'A', namely GRASS, that
contains SHAPELIB symbols and that links with another library 'B', namely
GDAL, that also contains SHAPELIB symbols...
I'm not sure there's a guarantee that the symbols that will be used will
come entirely from library 'A' or entirely from library 'B'. I'd be afraid
that there's a mix... And here, you really want that the GRASS DBF driver
uses its SHAPELIB symbols, not the GDAL ones.
To be really safe, I would recommend a change to SHAPELIB to add
decoration to all its symbols, like that
#ifndef SHAPELIBDECORATE
#define SHAPELIBDECORATE(x) x
#endif
DBFHandle SHPAPI_CALL
       SHAPELIBDECORATE(DBFOpen)( const char * pszDBFFile, const char *
pszAccess );
       SHAPELIBDECORATE(DBFOpenLL) ( const char * pszDBFFile, const char *
pszAccess,
                  SAHooks *psHooks );
       SHAPELIBDECORATE(DBFCreate) ( const char * pszDBFFile );
       SHAPELIBDECORATE(DBFCreateLL)( const char * pszDBFFile, SAHooks
*psHooks );
int SHPAPI_CALL
       SHAPELIBDECORATE(DBFGetFieldCount)( DBFHandle psDBF );
int SHPAPI_CALL
       SHAPELIBDECORATE(DBFGetRecordCount) ( DBFHandle psDBF );
int SHPAPI_CALL
       SHAPELIBDECORATE(DBFAddField) ( DBFHandle hDBF, const char *
pszFieldName,
                    DBFFieldType eType, int nWidth, int nDecimals );
The shapelib included within GDAL would be compiled with :
#define SHAPELIBDECORATE(x) GDAL##x
The shapelib included within GRASS would be compiled with :
#define SHAPELIBDECORATE(x) GRASS##x
That's a rather heavy and boring change to SHAPELIB headers and sources,
and to GRASS and GDAL source code, but that would solve definitely the
problems.
(Side node, we should do the samething in GDAL with libtiff...)
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:15&gt;
Comment (by warmerdam):
I'm not keen on applying the decoration idea in GDAL or shapelib upstream.
But manually renaming the functions in the copy kept in GRASS would avoid
any problems.
Alternatively we could treat shapelib more as an external dependency (at
least optionally) for GDAL and GRASS so one copy can be easily shared.
Potentially GRASS could also just depend on GDAL for it's shapelib instead
of having an embedded copy.
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:16&gt;
