[GRASS-dev] [GRASS GIS] #110: db/drivers/dbf fail to build due to undefined reference to 'SASetupDefaultHooks'
2008/3/31, Glynn Clements <glynn@gclements.plus.com>:
> Reporter: marisn | Owner: grass-dev@lists.osgeo.org
> Type: defect | Status: new
> Priority: critical | Milestone: 6.4.0
> Component: default | Version: svn-trunk
> Keywords: |
> Revision: 30825
> OS: Ubuntu 7.10 64bit
> /home/dace/soft/grass_trunk/dist.x86_64-unknown-linux-gnu/lib/libgrass_shape.so:
> undefined reference to `SASetupDefaultHooks'
Those calls were added in the latest revision:
    r30804 | neteler | 2008-03-30 10:21:48 +0100 (Sun, 30 Mar 2008) | 1 line
    sync'ed to GDAL SVN-trunk: gdal/ogr/ogrsf_frmts/shape/
They appear to be part of GDAL, so GDAL is now a dependency of the DBF
driver:
    r30820 | neteler | 2008-03-30 20:23:55 +0100 (Sun, 30 Mar 2008) | 1 line
    added GDALLIBS for SASetupDefaultHooks
You say that you're using r30825, and your link command has -lgdal, so
it may be that you need a newer version of GDAL.
Markus: is this change really necessary? Specifically, is the
GDAL-isation actually necessary?
with 1.5.0b1 building dbf driver fails
/hardmnt/schiele0/ssi/landa/temp/grass_trunk/dist.x86_64-unknown-linux-gnu/lib/libgrass_shape.so:
I have upgraded GDAL to 1.6.0dev, then I was able to compile dbf driver.
Martin
AFAICT, apart from some sanity checks in SHPReadObject(), the change
is almost entirely down to using GDAL's custom I/O interface.
I would have thought it would be better to just add the sanity checks
and do without GDAL's I/O interface, particularly as the code can only
ever use the default hooks (which presumably are just the stdio
function).
grass-dev mailing list
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
