[GRASS-dev] [GRASS GIS] #1101: WinGrass7 + scripts are not found in the command line
  Reporter: hellik | Owner: grass-dev@…
      Type: defect | Status: closed
Component: Packaging | Version: svn-trunk
Resolution: fixed | Keywords: wingrass, scripts
       CPU: Unspecified | Platform: MSWindows Vista
Changes (by hellik):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:15 wenzeslaus]:
> See also:
> * #580 WinGRASS: $GISBASE/etc/gui/scripts/ require something like
$(EXE) to run
> * #1871 winGRASS 7: solve python distribution
> * #2138 winGRASS6.4.svn - addon python script status?
> * #2150 Cannot call Python scripts from Python on MS Windows
> * [http://lists.osgeo.org/pipermail/grass-dev/2013-October/065896.html
Handling of Python scripts on MS Windows]
> * [http://lists.osgeo.org/pipermail/grass-dev/2014-February/067373.html
Handling of Python scripts on MS Windows] (question how QGIS and OSGeo4W
works)
> * r54612 - source:grass/trunk/mswindows -
[http://lists.osgeo.org/pipermail//grass-dev/2013-January/061451.html
wingrass: attempt to define python file association]
tested with
System Info
GRASS version: 7.0.3RC1
GRASS SVN Revision: 67443
Build Date: 2015-12-31
Build Platform: i386-w64-mingw32
GDAL/OGR: 1.11.3
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
it works; closing ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1101#comment:16&gt;
Dear GRASS developers,
I'm wondering what represents the most desirable approach to integrate R scripts into GRASS so that they are part of the FOSS community. It seems like the integration with R represents a fairly important component of GRASS, which relies on R for many geostatistical operations and machine learning algorithms. There are numerous publications that describe workflows using GRASS and R, but rarely are these publicly available.
Like many R-GRASS users, I have a collection of R scripts that interact with GRASS to perform various workflows. I have debated about converting these to Python using Rpy2, although this package can be a difficult to install on all platforms and depends on specific versions of R and Python. I noticed that Moritz Lennert recently developed a GRASS add on which consists of simply writing out the R commands to a temporary script for R to run. Based on this, I have converted some of my scripts which include random forest classification on both raster and vector data, random forest presence prediction, and spectral separability so that they can be accessed directly from the GRASS GUI.
Does this represent a desirable or even acceptable approach for embedding R scripts into grass add ons, or is Rpy2 the 'official' approach. Also, there are other alternatives to Rpy2 like PypeR which have the both conveniences and inconveniences, so should these also be considered? Or should we look at having a feature like in QGIS processing where R scripts can be launched directly with GUI options?
Steve
approach.
I wouldn't consider my approach in any way official, but AFAIK, rpy2 does not have any "official" status in GRASS either. In my particular case (v.class.mlR) this was a quick and dirty hack for a course I had to teach. The difficulty of getting rpy2 installed on the lab machines on short notice was one of the motivations not to use it. I also agree that dependency on rpy2 can be a nuisance and has caused me some headaches with other modules, before. However, the approach I used (and others have used before) is a bit unwieldy and makes maintaining such modules a bit of a pain.
So, I'm curious to hear the opinions of others...
Moritz
approach.
bit of a pain.
See [1] for a related issue.
Moritz
[1] https://trac.osgeo.org/grass/ticket/1290
Thank you Moritz,
Yes I have also had difficulties with Rpy2 apart from on Linux. Also, Rpy2 is quite onerous in terms of effort required to integrate R scripts into Python. Your solution certainly works, but as you mentioned it makes the R script harder to maintain. PypeR is another alternative and is straightforward to install and is simpler from a user perspective.
I would also be interested in hearing opinions from 'true' developers who have much greater expertise than myself in this area.
Kind regards,
Steve
On Jan 4, 2016, at 2:31 AM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
approach.
bit of a pain.
Moritz
I by any stretch of imagination a developer, but I did use the combination of shell or pythons script with R, basically following the approach you described, having a python or shell script write a R script to a text file and run it. I think it can work well, and not that much harder to maintain. But I also would be very interested to learn how to do this better. I also would be interested to see the randomForest scripts you mentioned Steven, are you already sharing it somewhere?
As you mentioned, there are probably many people using / writing R scripts that interact with GRASS. For some it will be easier, or it may be more logical for them, to turn these into R packages rather than writing a GRASS addon. It would be nice if there would be some kind of repository where people share such code (github perhaps?). I am sure there are existing ones on e.g., github, so perhaps just a GRASS-wiki page listing existing repositories would be enough. I know there is https://grasswiki.osgeo.org/wiki/R_statistics, but I don't think there is an place on the GRASS website, wiki or trac to share/list R code? Would this be of interest to create such page (on the Wiki perhaps?).
Paulo
On 04-01-16 16:14, Steven Pawley wrote:
Thank you Moritz,
Kind regards,
Steve
approach.
bit of a pain.
Moritz
grass-dev mailing list
grass-dev@lists.osgeo.org
Paulo van Breugel <p.vanbreugel@gmail.com> writes:
somewhere?
I am one of those. I have thought about making a GRASS (or QGIS) addon /
plugin, but I stayed with the R package. I have a complete simulation
written in R which uses spatial data from GRASS, does simulations, and
returns the results to GRASS.
To run the simulations in itself is a three liner in R.
Different people use different repos (I use e.g. github and gitlab) so
creating another place where I should publish my code would be not
really an option. What would be an idea to make it easy (probably even
easier even than editing a wiki page?) to add a repo to a list of
projects which integrate R in GRASS or GRASS in R, and which could
indicate the last commit to aser if the repos are current or just
archives from e.g. papers or finished projects.
My repo is private at the moment, but I plan to make it open in the next
few weeks.
A brief presentation about a very similar simulation model can be
found at
https://github.com/rkrug/INTECOL_2013_Optimizing
My gitlab repos (most or all private at the moment) are at
https://gitlab.com/rkrug/asm
and the simulation is at (also still private but it will change soon)
For reference, my github page is at
Rainer
Paulo
Thank you Moritz,
Kind regards,
Steve
approach.
bit of a pain.
Moritz
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
> somewhere?
+1 That would be something quick to implement. However, what form did you
have in mind, if not a wiki page? I wouldn't mind creating such page, but
perhaps first some further ideas on the best form from others as well.
few weeks.
found at
Thanks for sharing, interesting. Looking forwards seeing some further code
Rainer
> Paulo
>> Thank you Moritz,
>> Kind regards,
>> Steve
>>>>> approach.
to
that
modules a
>>>> bit of a pain.
>>> Moritz
>> _______________________________________________
Rainer M. Krug
PGP: 0x0F52F982
    > I by any stretch of imagination a developer, but I did use the
    > combination of shell or pythons script with R, basically
    following the
    > approach you described, having a python or shell script write a
    R
    > script to a text file and run it. I think it can work well, and
    not
    > that much harder to maintain. But I also would be very
    interested to
    > learn how to do this better. I also would be interested to see
    the
    > randomForest scripts you mentioned Steven, are you already
    sharing it
    > somewhere?
    > As you mentioned, there are probably many people using / writing
    R
    > scripts that interact with GRASS. For some it will be easier, or
    it
    > may be more logical for them, to turn these into R packages
    rather
    > than writing a GRASS addon.
    addon /
    simulation
    and
    > It would be nice if there would be some kind of repository where
    > people share such code (github perhaps?). I am sure there are
    existing
    > ones on e.g., github, so perhaps just a GRASS-wiki page listing
    > existing repositories would be enough. I know there is
    > https://grasswiki.osgeo.org/wiki/R_statistics, but I don't think
    there
    > is an place on the GRASS website, wiki or trac to share/list R
    code?
    > Would this be of interest to create such page (on the Wiki
    perhaps?).
    gitlab) so
    even
you have in mind, if not a wiki page? I wouldn't mind creating such
page, but perhaps first some further ideas on the best form from
others as well.
I thought about a field, where I just add the link to the repository and
some info (Author, short description, possibly License type, ...) and
this is automatically added to the page including information from the
repo like last updated, link to the README, ... But this might be
getting to complicated. But I know it from my side - editing a wiki page
is often a "will do later" thing.
Also a system where there is an form where one fills in the info and it
is emailed to somebody to add it to the wiki would work.
    the next
    few weeks.
    found at
code
Thanks - I will keep you posted.
Coming back to the initial question:
What we would need in the meantime is possibly a discussion, on how R
functions could be used in an automated way - i.e. something along the
lines of an R package, which contains a set of defined functions like:
getFunctionNames() :: which returns the function names which can be
called from GRASS
getFunctionInterface(functionName) :: which returns the arguments of the
function functionName (similar to the interfaceDescription (I think it
is called differently) in GRASS commands)
would make it possible to just
1) load any R package which has these functions
2) and get all function names and arguments needed
3) and just call the R function in an easy way like
   g.call.R package=PACKAGENAME function=FUNCTIONNAME
   arguments="arguments for the R function)
The function could than be executed by using either a relatively simple python or
direct Rscript approach.
Also, one could even dynamically load an R package and construct all the
calls including help, so they could be called by using
   g.call.R.PACKAGENAME.FUNCTIONNAME arg1=ARG1 arg2=ARG2
From the R side, this would be relatively easy to include, (there are
the packages rgrass7 and spgrass6 to interact with GRASS 7 and 6) and it
I think that it should not be to difficult to implement on the GRASS side.
This would than be very similar to the approach which rgrass7 (and
spgrass6) are using by querying the interface and than doing the
checking, and if everything seems consistent, call the GRASS command.
Just some thoughts,
Rainer
    soon)
    Rainer
    > Paulo
    > On 04-01-16 16:14, Steven Pawley wrote:
    >> Thank you Moritz,
    >> Yes I have also had difficulties with Rpy2 apart from on
    >> Linux. Also, Rpy2 is quite onerous in terms of effort required
    to
    >> integrate R scripts into Python. Your solution certainly works,
    but
    >> as you mentioned it makes the R script harder to maintain.
    PypeR is
    >> another alternative and is straightforward to install and is
    simpler
    >> from a user perspective.
    >> I would also be interested in hearing opinions from 'true'
    >> developers who have much greater expertise than myself in this
    area.
    >> Kind regards,
    >> Steve
    >>> On Jan 4, 2016, at 2:31 AM, Moritz Lennert
    >>>> On 04/01/16 10:28, Moritz Lennert wrote:
    >>>>> On 03/01/16 23:54, Steven Pawley wrote:
    >>>>> Like many R-GRASS users, I have a collection of R scripts
    that
    >>>>> interact with GRASS to perform various workflows. I have
    debated
    >>>>> about converting these to Python using Rpy2, although this
    package
    >>>>> can be a difficult to install on all platforms and depends
    on
    >>>>> specific versions of R and Python. I noticed that Moritz
    Lennert
    >>>>> recently developed a GRASS add on which consists of simply
    writing
    >>>>> out the R commands to a temporary script for R to run.
    >>>>> Does this represent a desirable or even acceptable approach
    for
    >>>>> embedding R scripts into grass add ons, or is Rpy2 the
    'official'
    >>>>> approach.
    >>>> I wouldn't consider my approach in any way official, but
    AFAIK, rpy2
    >>>> does not have any "official" status in GRASS either. In my
    particular
    >>>> case (v.class.mlR) this was a quick and dirty hack for a
    course I had to
    >>>> teach. The difficulty of getting rpy2 installed on the lab
    machines on
    >>>> short notice was one of the motivations not to use it. I also
    agree that
    >>>> dependency on rpy2 can be a nuisance and has caused me some
    headaches
    >>>> with other modules, before. However, the approach I used (and
    others
    >>>> have used before) is a bit unwieldy and makes maintaining
    such modules a
    >>>> bit of a pain.
    >>>> So, I'm curious to hear the opinions of others...
    >>> See [1] for a related issue.
    >>> Moritz
    >>> [1] https://trac.osgeo.org/grass/ticket/1290
    >> _______________________________________________
    >> grass-dev mailing list
    >> grass-dev@lists.osgeo.org
    >> http://lists.osgeo.org/mailman/listinfo/grass-dev
    Rainer M. Krug
    PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
     following the
     R
     not
     interested to
     the
     sharing it
     > somewhere?
     R
     it
     rather
     addon /
     simulation
     and
     existing
     there
     code?
     perhaps?).
     gitlab) so
     even
others as well.
Creating an automated form, etc wouldn't be something I could do, but I wouldn't mind maintaining a a list on the GRASS wiki based on information from a user form. Perhaps a Google form? Any ideas / opinions on this from the devs?
     the next
     few weeks.
     found at
code
called from GRASS
Sounds like a good approach to me (just from a user perspective, no clue about the implementation details).
Just some thoughts,
Rainer
     soon)
          Rainer
     > Paulo
     to
     but
     PypeR is
     simpler
     area.
     >> Kind regards,
     >> Steve
     that
     debated
     package
     on
     Lennert
     writing
     for
     'official'
     >>>>> approach.
     AFAIK, rpy2
     particular
     course I had to
     machines on
     agree that
     headaches
     others
     such modules a
     >>>> bit of a pain.
     >>> Moritz
     Rainer M. Krug
     PGP: 0x0F52F982
