[GRASS-dev] [GRASS GIS] #1102: Subgroup option is not "inserted" in command-line
Reporter: jennyturner1980 | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Keywords: | Platform: All
      Cpu: Unspecified |
Until a month ago GRASS WxGUI had a problem on listing Subgroups. That was
fixed but now, subgroup information is not parsed from module to the
command-line output. So this means that, modules that requires subgroup
information, cannot be runned from interface.
This error was obtained in last-week and previous week snapshots in
WinGRASS and Linux (Ubuntu)
Attached image shows that group and sub-group were selected but subgroup
information was not parsed to command-line command.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1102&gt;
Keywords: i.maxlik | Platform: All
      Cpu: Unspecified |
Changes (by hamish):
  * keywords: => i.maxlik
Comment:
try removing the @mapset part from the group names in the dialog options.
A number of imagery modules/imagery library functions don't like them
much.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1102#comment:1&gt;
      Cpu: Unspecified |
Comment(by jennyturner1980):
Regarding Hamish comment:
1- It's not only in i.maxlik but in all functions that requires group and
subgroup (as can be ssen from Screenshot02.png (i.cluster in this case)
2- I tried removing @landsat and it does not work (as can be seen from
Screenshot02.png)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1102#comment:2&gt;
Keywords: i.maxlik, group/subgroup, i.smap, i.cluster, i.gensig, i.gensigset | Platform: All
      Cpu: Unspecified |
Changes (by jennyturner1980):
  * keywords: i.maxlik => i.maxlik, group/subgroup, i.smap, i.cluster,
Comment:
I got exacly the same problem with other functions such as:
- i.smap
- i.cluster
- i.gensig
- i.gensigset
Ticket URL: <https://trac.osgeo.org/grass/ticket/1102#comment:3&gt;
Reporter: jennyturner1980 | Owner: martinl
     Type: defect | Status: assigned
      Cpu: Unspecified |
Changes (by martinl):
* cc: grass-dev@… (added)
  * owner: grass-dev@… => martinl
  * status: new => assigned
Comment:
Please try out the fresh SVN, it should be already fixed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1102#comment:4&gt;
Priority: normal | Milestone: 6.4.1
      Cpu: Unspecified |
  * milestone: 6.4.0 => 6.4.1
Comment:
Still relevant?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1102#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: i.maxlik, group/subgroup, i.smap, i.cluster, i.gensig, i.gensigset
  Platform: All | Cpu: Unspecified
  * status: assigned => closed
  * resolution: => fixed
Comment:
Seems to be OK, please reopen the ticket if needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1102#comment:6&gt;
