[GRASS-dev] [GRASS GIS] #1105: un-red the trac theme
  Reporter: hamish | Owner: grass-dev@…
      Type: task | Status: new
  Priority: minor | Milestone: Website
Component: Website | Version:
Resolution: | Keywords: trac theme
Comment (by nikosa):
Replying to [comment:6 neteler]:
> I wonder where to insert style changes:
> `/var/www/trac/grass/templates/site_css.cs`
> is empty. No other css file on the server...
See
https://trac.edgewall.org/wiki/TracInterfaceCustomization#SiteAppearance
Also, useful notes lower down in the
https://trac.edgewall.org/wiki/TracInterfaceCustomization#ProjectTemplates
section:
  ''The appearance of each individual Trac environment, ie instance of a
project, can be customized independently of other projects, even those
hosted on the same server. The recommended way is to use a `site.html`
template whenever possible, see
[https://trac.edgewall.org/wiki/TracInterfaceCustomization#SiteAppearance
#SiteAppearance]. '''Using `site.html` means changes are made to the
original templates as they are rendered, and you should not normally need
to redo modifications whenever Trac is upgraded.''' If you do make a copy
of `theme.html` or any other Trac template, you need to migrate your
modifiations to the newer version. If not, new Trac features or bug fixes
may not work as expected.''
Ticket URL: <https://trac.osgeo.org/grass/ticket/1105#comment:7&gt;
