[GRASS-dev] [GRASS GIS] #1110: v.rast.stats locks up on wingrass
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: svn-releasebranch64
Keywords: wingrass, v.rast.stats, v.db.addcol, v.info | Platform: MSWindows XP
      Cpu: x86-32 |
Hi, as reported on the ML:
  http://thread.gmane.org/gmane.comp.gis.grass.user/36116/
the shell script version of v.rast.stats gets stuck on WinGrass.
for me using XP from the msys rxvt command prompt it works about 50% of
the time. Sometimes there was a left over v.info.exe in the ctrl-alt-del
process list, sometimes a db.describe. Adding -x to the shebang only helps
as far as g.parser. I've now added some new debug messages in 6.5svn,
maybe they help determine if it is before or in v.db.addcol ?
^C does not seem to work in the msys rxvt bash session so to kill it I had
to either kill grass or kill the hung process in the ctrl-alt-del process
list at which point the script bailed out.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1110&gt;
      Cpu: x86-32 |
Comment(by hamish):
Yvan wrote:
This is the function and the message :
(Mon Jul 19 15:12:58 2010)
v.rast.stats vector=parcelles_masquees@mercier raster=mntyzeron_5m@mercier
colprefix=mnt
C:/GRASS-64-SVN/scripts/v.rast.stats: line 268: v.db.addcol:
command not found
ERROR: Cannot continue (problem adding columns).
(Mon Jul 19 15:13:06 2010) Command finished (7 sec)
although I've only seen the subprocess freezing manifestation of this.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1110#comment:1&gt;
GRASS GIS <trac <at> osgeo.org> writes:
grass-dev@…
svn-releasebranch64
MSWindows XP
      Cpu: x86-32 |
Comment(by hamish):
v.rast.stats vector=parcelles_masquees <at> mercier raster=mntyzeron_5m <at>
mercier
colprefix=mnt
command not found
I get the same error using Grass 6.4 and 6.5.
Might this be related to the fact, that v.db.addcol is a shell script, the same
as v.rast.stats?
As far as I understand, while starting a shell script under windows, GRASS_SH
(which is set to sh.exe in the environment variables) will start the .bat file
in the /bin directory. This .bat file points to the shell script in the /scripts
directory.
However, once sh.exe started to read the shell script (here v.rast.stats), in
which directory will it search a second shell script referenced in the first
shell script (here v.db.addcol)? In the same?
Is there anything to fix this bug?
Sonja
Priority: normal | Milestone: 6.4.2
      Cpu: x86-32 |
Changes (by hellik):
  * milestone: 6.4.0 => 6.4.2
Ticket URL: <http://trac.osgeo.org/grass/ticket/1110#comment:2&gt;
Priority: critical | Milestone: 6.4.2
      Cpu: x86-32 |
  * priority: normal => critical
Comment:
see also:
http://lists.osgeo.org/pipermail/grass-user/2011-August/061681.html
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1110#comment:3&gt;
      Cpu: x86-32 |
Comment(by hellik):
tested with WinGRASS-6.4.SVN-r47756-1-Setup.exe
there seems to be 2 issues here:
(1) v.rast.stats seems not to be able to invoke v.db.addcol
which is in C:\Program Files\GRASS 6.4.SVN\scripts and has
a wrapper script in C:\Program Files\GRASS 6.4.SVN\bin\v.db.addcol.bat
Replying to [comment:1 hamish]:
> command not found
(2) v.db.addcol seems not to be able to add a column in windows with
the dbf-driver, but it's able with the sqlite-driver
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1110#comment:4&gt;
      Cpu: x86-32 |
Comment(by hamish):
a long standing question is why on the same machine it works sometimes but
not others; and why plenty of other scripts can call each other, seemingly
without any trouble..?
some quick examples,
  - v.in.lines calls the v.in.mapgen script;
  - v.db.renamecol and v.db.join calls the v.db.addcol script.
  - the script version of v.colors calls v.db.addcol too.
  - r.in.wms & i.oif are a bit different, as they call their own support
scripts outside of the normal path. r.in.wms is a tangle, but i.oif should
be easy enough to work through by hand.
any trouble with those?
are you working from the rxvt/msys prompt? the cmd.exe DOS prompt? from
within the GUI?
does that make a difference?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1110#comment:5&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:5 hamish]:
within the GUI?
tested with wingrass-nightly-build WinGRASS-6.4.SVN-r47775-1-Setup.exe
sqlite as db-backend
(1) "GRASS 6.4.SVN with MSYS" => v.rast.stats-wxgui
v.rast.stats --verbose vector=mylakes@g7 raster=elevation@PERMANENT
colprefix=gui
Adding columns ' gui_n INTEGER, gui_min DOUBLE PRECISION, gui_max DOUBLE
PRECISION, gui_range DOUBLE PRECISION, gui_mean DOUBLE PRECISION,
gui_stddev DOUBLE PRECISION, gui_variance DOUBLE PRECISION, gui_cf_var
DOUBLE PRECISION, gui_sum DOUBLE PRECISION'
Processing data (766 categories)...
Processing category 6229 (1/766)
Processing category 11145 (766/766)
Updating the database ...
Statistics calculated from raster map <elevation@PERMANENT> and uploaded
to attribute table of vector map <mylakes>.
Done.
(Sun Aug 21 19:31:02 2011) Command finished (1647 sec)
(2) "GRASS 6.4.SVN with MSYS" in the wxgui-command-console
colprefix=cons
Adding columns ' cons_n INTEGER, cons_min DOUBLE PRECISION, cons_max
DOUBLE PRECISION, cons_range DOUBLE PRECISION, cons_mean DOUBLE PRECISION,
cons_stddev DOUBLE PRECISION, cons_variance DOUBLE PRECISION, cons_cf_var
DOUBLE PRECISION, cons_sum DOUBLE PRECISION'
Done.
(3) "GRASS 6.4.SVN with MSYS" in the wingrass-msys-shell
GRASS 6.4> v.rast.stats --verbose vector=mylakes@g7
  colprefix=msys
Adding columns ' msys_n INTEGER, msys_min DOUBLE PRECISION, msys_max
DOUBLE
PRECISION, msys_range DOUBLE PRECISION, msys_mean DOUBLE PRECISION,
msys_stddev DOUBLE PRECISION, msys_variance DOUBLE PRECISION, msys_cf_var
DOUBLE PRECISION, msys_sum DOUBLE PRECISION'
to
Done.
(4) "GRASS Command Line" - wingrass in text-mode (windows-command-line)
GRASS 6.4.2svn (nc_spm_08)> v.rast.stats --verbose vector=mylakes@g7
raster=elev
ation@PERMANENT colprefix=msdos
Adding columns ' msdos_n INTEGER, msdos_min DOUBLE PRECISION, msdos_max
DOUBLE PRECISION, msdos_range DOUBLE PRECISION, msdos_mean DOUBLE
PRECISION, msdos_stddev DOUBLE PRECISION, msdos_variance DOUBLE PRECISION,
msdos_cf_var DOUBLE PRECISION, msdos_sum DOUBLE PRECISION'
C:/Program Files/GRASS 6.4.SVN/scripts/v.rast.stats: line 285:
v.db.addcol: command not found
FEHLER: Cannot continue (problem adding columns).
(5) GRASS 6.4.SVN (desktop shortcut without msys)
colprefix=owxgui
Adding columns ' owxgui_n INTEGER, owxgui_min DOUBLE PRECISION, owxgui_max
DOUBLE PRECISION, owxgui_range DOUBLE PRECISION, owxgui_mean DOUBLE
PRECISION, owxgui_stddev DOUBLE PRECISION, owxgui_variance DOUBLE
PRECISION, owxgui_cf_var DOUBLE PRECISION, owxgui_sum DOUBLE PRECISION'
285: v.db.addcol: command not found
in case (1), (2), (3) wingrass is started by "C:\Program Files\GRASS
6.4.SVN\msys\msys.bat" /grass/bin/grass64svn -wxpython
in case (4) wingrass is started by "C:\Program Files\GRASS
6.4.SVN\grass64svn.bat" -text
in case (5) wingrass is started by "C:\Program Files\GRASS
6.4.SVN\grass64svn.bat" -wxpython
so it seems that the v.db.addcol-script can't be find by the v.rast.stat-
script when wingrass is started via grass64svn.bat, but it's possible in
wingrass started via msys-way.
best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1110#comment:6&gt;
      Cpu: x86-32 |
Comment(by hamish):
Replying to [comment:6 hellik]:
> v.rast.stat-script when wingrass is started via grass64svn.bat,
> but it's possible in wingrass started via msys-way.
.. interesting.
does v.in.lines work in the grass64svn.bat cases?
C:\> copy con test.dat
167.846717,-46.516653
167.846663,-46.516645
167.846656,-46.516644
167.846649,-46.516644
167.846642,-46.516643
NaN,NaN
167.846520,-46.516457
167.846528,-46.516461
167.846537,-46.516464
167.846535,-46.516486
167.846544,-46.516489
167.846552,-46.516493
^Z
v.in.lines in=test.dat out=two_lines fs=,
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1110#comment:7&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:7 hamish]:
> .. interesting.
> NaN,NaN
> ^Z
would this a example for spearfish- or nc-sample data set?
best regards
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1110#comment:8&gt;
      Cpu: x86-32 |
Comment(by hellik):
simple testcase for nc-sample-dataset
633249.504950,224984.653465
639210.891089,227256.930693
643728.712871,216510.396040
NaN,NaN
630763.366337,216243.069307
637954.455446,215681.683168
643996.039604,215521.287129
(1) "GRASS 6.4.SVN with MSYS" (started by "C:\Program Files\GRASS
6.4.SVN\msys\msys.bat" /grass/bin/grass64svn -wxpython)
v.in.lines --verbose input=J:\test.dat output=twolines2 fs=,
Importing with v.in.ascii ...
Erstelle Topologie für die Vektorkarte <twolines2>...
Registriere Primitive...
2 Primitive registriert
6 Vertices registriert
Erzeuge Flächen...
0 Flächen angelegt
0 Inseln angelegt
Füge Inseln hinzu...
Füge Zentroide hinzu...
Die Topologie wurde erstellt
Anzahl der Knoten: 4
Anzahl der Primitive: 2
Anzahl der Punkte: 0
Anzahl der Linien: 2
Anzahl der Grenzen: 0
Anzahl der Zentroide: 0
Anzahl der Flächen: 0
Anzahl der Inseln: 0
v.in.ascii komplett.
"twolines2@g7" successfully created.
(Mon Aug 22 01:32:33 2011) Command finished (2 sec)
(2) "GRASS 6.4.SVN" (started by "C:\Program Files\GRASS
6.4.SVN\grass64svn.bat" -wxpython)
C:/Program Files/GRASS 6.4.SVN/scripts/v.in.lines: line 126:
v.in.mapgen: command not found
so v.in.lines seems not to work in the grass64svn.bat-case.
best regards
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1110#comment:9&gt;
      Cpu: x86-32 |
Comment(by hellik):
but not others; and why plenty of other scripts can call each other,
seemingly without any trouble..?
adding \bin and \scripts to the %PATH% to
C:\Program Files\GRASS 6.4.SVN\etc\env.bat
helps v.rast.stat to invoke v.db.addcol in the grass64svn.bat-case
rem Set Path to utilities (libraries and bynaries) used by GRASS
set PATH=%GISBASE%\msys\bin;%PATH%
set PATH=%GISBASE%\extrabin;%GISBASE%\extralib;%PATH%
set PATH=%GISBASE%\tcl-
tk\bin;%GISBASE%\sqlite\bin;%GISBASE%\gpsbabel;%PATH%
set PATH=%GISBASE%\bin;%GISBASE%\scripts;%PATH%
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1110#comment:10&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:10 hellik]:
v.rast.stats vector=mylakes@g7 raster=elevation@PERMANENT colprefix=pahk
Done.
(Tue Aug 23 12:34:46 2011) Befehl ausgeführt (1657 sec)
so adding to the path seems to be solution...
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1110#comment:11&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:9 hellik]:
with the path-addition also v.in.lines works in the grass64svn.bat-case.
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1110#comment:12&gt;
      Cpu: x86-32 |
Comment(by hamish):
brilliant!
Ticket URL: <https://trac.osgeo.org/grass/ticket/1110#comment:13&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:4 hellik]:
> > command not found
with the path-addition this issue seems to be solved
all tests above with sqlite as db-backend are working here in all
different wingrass-starting cases.
switching to '''dbf''' as db-backend:
(1) v.rast.stats in the "C:\Program Files\GRASS 6.4.SVN\msys\msys.bat"
/grass/bin/grass64svn -wxpython"-case seems to work here
but
(2) v.rast.stats in grass64svn.bat-case wingrass freezes
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1110#comment:14&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:14 hellik]:
sorry for the noise, DEBUG=3 freezed wingrass.
with DEBUG=0, v.rast.stats with dbf as db-backend also work in grass64svn
.bat-case
(tested several times)
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1110#comment:15&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:13 hamish]:
> brilliant!
committed
r47869 grass64svn
r47870 grass65svn
r47871 grass70svn
please test
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1110#comment:16&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass, v.rast.stats, v.db.addcol, v.info
  Platform: MSWindows XP | Cpu: x86-32
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
Comment:
v.in.lines and v.rast.stats working from DOS prompt in 6.4svn nightly
native wingrass build. closing bug.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1110#comment:17&gt;
