#1111: trouble getting started
Reporter: RonL | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
I am a first-time user of Version 6.4.0RC5 on Ubuntu 9.10. I had no
problem installing the software from Synaptic or extracting spearfish60
into /home/.../grassdata. Using the GUI, I select "spearfish60" and
"user1", then hit "Enter GRASS." A dialog box appears that says: "g.proj
or projection error: ERROR: G-getenv(): Variable LOCATION_NAME not set."
Can you help?
this one is not your fault, there was a bug (#654) in the edition of RC5
that ubuntu shipped with Karmic. You'll probably find a newer version
(RC6) available for download from UbuntuGIS? The newer version is much
updated. https://wiki.ubuntu.com/UbuntuGIS
