[GRASS-dev] [GRASS GIS] #1117: WinGrass7 - wxgui not starting
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Component: Packaging | Version: svn-trunk
Keywords: wingrass | Platform: MSWindows Vista
      Cpu: Unspecified |
tested with WinGRASS-7.0.SVN-r42866-1-Setup.exe and
WinGRASS-7.0.SVN-r42881-1-Setup.exe
the location wizard is opening, but after choosing a location, the wxgui
crashes:
GRASS 7.0.svn> Der Befehl "g.list" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
   File "C:\Program Files\GRASS-70-SVN\etc\gui\wxpython\wxgui.py", line
1597, in <module>
     sys.exit(main())
1590, in main
     app = GMApp(workspaceFile)
1512, in __init__
     wx.App.__init__(self, False)
   File "C:\OSGeo4W\apps\Python25\lib\site-packages\wx-2.8-msw-
unicode\wx\_core.py", line 7935, in __init__
     self._BootstrapApp()
unicode\wx\_core.py", line 7509, in _BootstrapApp
     return _core_.PyApp__BootstrapApp(*args, **kwargs)
1533, in OnInit
     workspace = self.workspaceFile)
179, in __init__
     self.NewDisplay(show=False)
1112, in NewDisplay
     auimgr=self._auimgr, showMapDisplay=show)
   File "c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
mingw32/etc/gui/wxpython/gui_modules/layertree.py", line 120, in __init__
     Map=self.Map, auimgr=self.auimgr)
mingw32/etc/gui/wxpython/gui_modules/mapdisp.py", line 285, in __init__
     self.MapWindow.ZoomHistory(self.Map.region['n'],
KeyError: 'n'
and a error-message pops up (see attached image).
a self-built WinGrass7-installer, at least with r42871, is starting
normally.
best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1117&gt;
Keywords: wingrass, wxgui | Platform: MSWindows Vista
      Cpu: x86-32 |
Changes (by hellik):
  * keywords: wingrass => wingrass, wxgui
  * cpu: Unspecified => x86-32
Comment:
Replying to [ticket:1117 hellik]:
> Hi,
> normally.
tested again with a self-built WinGrass7-installer at r42884, WinGrass7
starts normally.
maybe a messed build-environment for the WinGrass-nightly builds?
best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1117#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass, wxgui
  Platform: MSWindows Vista | Cpu: x86-32
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:1 hellik]:
> > Hi,
> > normally.
starts normally.
> best regards
> Helmut
closing the ticket after a more than a year successfull testing.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1117#comment:2&gt;
      Type: defect | Status: reopened
Resolution: | Keywords: wingrass, wxgui
Changes (by mmetz):
  * status: closed => reopened
  * resolution: fixed =>
Comment:
Replying to [comment:2 hellik]:
Bad news: I tested
http://wingrass.fsv.cvut.cz/grass70/WinGRASS-7.0.SVN-r50400-1-Setup.exe
and does not work on xp. Exactly nothing happens. When executing the start
bat files from the windows command line, there seems to be a problem with
an unquoted path somewhere.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1117#comment:3&gt;
Comment(by hellik):
Replying to [comment:3 mmetz]:
> Bad news: I tested
> Markus M
now it seems to be another issue than the original one, connected to the
switch to python272 with wingrass standalone/wingrass-osgeo4w.
tested here on win7-64bit with WinGRASS-7.0.SVN-r50415-1-Setup.exe,
wingrass is starting here on my side.
there seems to be some other issues related to the switch, but maybe it's
worth to open another ticket.
I suggest to close this ticket.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1117#comment:4&gt;
Changes (by mmetz):
  * status: reopened => closed
Comment:
Replying to [comment:4 hellik]:
it's worth to open another ticket.
r50415 is working for me too, closing ticket.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1117#comment:5&gt;
