[GRASS-dev] [GRASS GIS] #1119: snap parameter in v.in.ogr's manual not explained
Reporter: nikos | Owner: grass-dev@…
     Type: defect | Status: new
Priority: trivial | Milestone: 6.4.0
Component: Docs | Version: unspecified
Keywords: snap, description, manual | Platform: Unspecified
      Cpu: Unspecified |
The manual of v.in.ogr informs only that "snap=float" and that "Snapping
threshold for boundaries, '-1' for no snap, Default: -1".
The manual links to "v.clean", yet IMHO, I shouldn't need more than just
typing "v.in.ogr help" in the command line to be informed that snap values
define "max. distance to another vertex in map units, degrees for latlon"
(Will propose a diff at some point, not very soon though)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1119&gt;
      Cpu: Unspecified |
Comment(by neteler):
Is this correct for the snap parameter in v.in.ogr: "max. distance to
Ticket URL: <http://trac.osgeo.org/grass/ticket/1119#comment:1&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:1 neteler]:
Yes, has always been so. Do you want it to be changed to "max. distance to
another vertex in map units, meters for latlon" ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1119#comment:2&gt;
      Cpu: Unspecified |
The wish is to have the current method documented in
vector/v.in.ogr/description.html.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1119#comment:3&gt;
Priority: trivial | Milestone: 6.4.4
      Cpu: Unspecified |
Changes (by neteler):
  * milestone: 6.4.0 => 6.4.4
Comment:
Nikos, which documentation change do you want to see?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1119#comment:4&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:4 neteler]:
Explanation added to trunk in r52825.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1119#comment:5&gt;
      Type: enhancement | Status: closed
  Priority: trivial | Milestone: 6.4.3
Component: Docs | Version: svn-releasebranch64
Resolution: fixed | Keywords: snap, description, manual
  Platform: Unspecified | Cpu: Unspecified
  * status: new => closed
  * type: defect => enhancement
  * version: unspecified => svn-releasebranch64
  * resolution: => fixed
  * milestone: 6.4.4 => 6.4.3
Comment:
Documentation change backported along with some more documentation.
Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1119#comment:6&gt;
