#112: WinGRASS-6.3.0RC6 fails saving current display geometry to named region in
Tcl GUI
Reporter: 4everskiff | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Tcl | Version: 6.3.0 RCs
Keywords: |
WinGRASS-6.3.0RC6 (self installer):
GRASS crash applying the following command from map display:
"Save current display geometry to named region"
Error message:
Error setting region: child process exited abnormally
The "named region" file is created, though.
When trying to re-do the command using the same name for region, after
pressing "Yes" to "Already existing/Overwrite" alert message, the
following error displays:
Error reading current resolution with g.region: child process exited
Attached the g.region.log
"Zoom to region" command works (reports no errors), but it displays the
standard map region, because (I think) the selected named region has not
been correctly created.
I also tried the same commands using wxpython GUI; both "Save display
geometry to named region" and "Zoom to saved region" work fine.
#112: GRASS-6.3.0RC6 fails saving current display geometry to named region in Tcl
GUI
Resolution: | Keywords:
Changes (by marisn):
* summary: WinGRASS-6.3.0RC6 fails saving current display geometry to
named region in Tcl GUI => GRASS-6.3.0RC6 fails
in Tcl GUI
Comment:
I can confirm this on 32bit Linux with rev. 30826 svn trunk.
Removed Win part from summary.
