#1121: WxPython GUI Hangs when adding Vector Map
Reporter: JonBall | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Display | Version: 6.4.0 RCs
Keywords: | Platform: MSWindows Vista
Cpu: Unspecified |
The WxPython GRASS GIS Layer Manager will hang when trying to add a
vector= layer using the Add Vector Map Layer button. A dialog box opens
and the = user can select an input vector map. Once the map has been
selected, clic= king anything will cause GRASS to hang (rendering GRASS
totally unusable u= nless resorting to the old TCL interface - where the
problem doesn't exist= ). Clicking 'OK' without trying to make any
changes also causes GRASS to hang.
