#1131: Global LFS for wingrass
Reporter: mmetz | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: libgis | Version: svn-trunk
Keywords: LFS,wingrass | Platform: MSWindows 7
Cpu: All |
Comment(by mmetz):
Replying to [comment:14 glynn]:
> > Alternatively, we could not redefine existing functions/types, but
define functions/types for grass, e.g.
> #define g_off_t off64_t
> #define g_fseeko fseeko64
> #define g_ftello ftello64
> #define g_lseek lseek64
> /* use _stati64 compatible with MSVCRT < 6.1 */
> #define g_stat _stati64
> #define g_fstat _fstati64
> If you take this route, these should be functions rather than macros
(IMHO, g_off_t is a non-starter).
I think I understand. How about in config.h.in
/* use own off_t definition */
#define _OFF_T_
#define _off_t off64_t
#define off_t off64_t
/* fseeko and ftello are safe because not defined by MINGW */
#define HAVE_FSEEKO
#define fseeko fseeko64
#define ftello ftello64
/* lseek is not safe, defined in io.h */
#define HAVE_LSEEK64
/* stat and fstat are not safe, defined in stat.h */
#define HAVE__STATI64
#define HAVE__FSTATI64
#define _STRUCT_STAT_
typedef struct _stati64 STRUCT_STAT;
in lib/gis/seek.c new function G_lseek()
off_t G_lseek(int fd, off_t offset, int whence)
#ifdef HAVE_LSEEK64
return lseek64(fd, offset, whence);
#else
return lseek(fd, offset, whence);
#endif
in lib/gis/paths.c
int G_stat(const char *file_name, STRUCT_STAT *buf)
#ifdef HAVE__STATI64
return _stati64(file_name, buf);
#else
return stat(file_name, buf);
#endif
int G_lstat(const char *file_name, STRUCT_STAT *buf)
#ifdef __MINGW32__
return G_stat(file_name, buf);
#else
return lstat(file_name, buf);
#endif
Then update other libs and modules accordingly...
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1131#comment:16>
