GDAL
1
#1133: ps.map doesn’t accept more than 10 ‘labels’ instructions
Reporter: clerici | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: | Platform: Linux
Cpu: Unspecified |
To check with Spearfish data:[[BR]]
v.label labels=archlab map=archsites column=str1[[BR]]
ps.map in=label.txt out=archlab.ps
label.txt (with 11 labels instructions):[[BR]]
labels archlab[[BR]]
end[[BR]]
end[[BR]]
end[[BR]]
end[[BR]]
end[[BR]]
end[[BR]]
end[[BR]]
end[[BR]]
end[[BR]]
end[[BR]]
end[[BR]]
The error message is:[[BR]]
ERROR: archlab in esercizi : no more label files allowed[[BR]]
With less than 11 labels instructions the ps map is successfully
created.[[BR]]
Greetings[[BR]]
A. Clerici
Ticket URL: <http://trac.osgeo.org/grass/ticket/1133>
GDAL
2
Reporter: clerici | Owner: hamish
Priority: minor | Milestone: 6.4.1
Component: ps.map | Version: svn-develbranch6
Keywords: labels | Platform: Linux
Cpu: All |
Changes (by hamish):
* cc: grass-dev@… (added)
* component: default => ps.map
* priority: normal => minor
* owner: grass-dev@… => hamish
* version: 6.4.0 RCs => svn-develbranch6
* milestone: 6.4.0 => 6.4.1
* keywords: => labels
* type: defect => enhancement
* cpu: Unspecified => All
Comment:
see
source:grass/trunk/ps/ps.map/r_labels.c
and MAXLABELS in
source:grass/trunk/ps/ps.map/labels.h
just edit labels.h to however big you want it, and recompile.
(how many do you want?)
since the "labels" files are just text, to work around it you
can just go into $MAPSET/paint/labels/ and do
cat * > all_labels
to combine them all into a single labels file. (they will
remember thier own font sizes, colors, etc)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1133#comment:1>
GDAL
3
Component: Ps.map | Version: svn-develbranch6
Cpu: All |
Comment(by hamish):
max number of label instructions bumped to 50 in devbr6 and trunk.
(r43608,9)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1133#comment:2>
GDAL
4
Priority: minor | Milestone: 6.4.2
Cpu: All |
* milestone: 6.4.1 => 6.4.2
Comment:
now backported to 6.4svn as well. closing bug.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1133#comment:3>
GDAL
5
Type: enhancement | Status: closed
Resolution: fixed | Keywords: labels
Platform: Linux | Cpu: All
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/1133#comment:4>
