#1134: WinGrass - 3D view mode crashes
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Component: wxGUI | Version: svn-trunk
Keywords: wingrass, wxnviz | Platform: MSWindows Vista
Cpu: x86-32 |
after fixing #1125 (wingrass - ctypes - compiling error) there is now the
3d view mode in the wxgui available on the windows platform.
but if you try to switch to the 3d view mode, the whole wxgui crashes and
disappears.
tested with a self compiled WinGrass7 and the nc sample-dataset:
g.region -p
D2/5: G__read_Cell_head
D2/5: G__read_Cell_head_array
D3/5: region item: proj: 99
D3/5: region item: zone: 0
D3/5: region item: north: 320000
D3/5: region item: south: 10000
D3/5: region item: east: 935000
D3/5: region item: west: 120000
D3/5: region item: cols: 1630
D3/5: region item: rows: 620
D3/5: region item: e-w resol: 500
D3/5: region item: n-s resol: 500
D3/5: region item: top: 500
D3/5: region item: bottom: -500
D3/5: region item: cols3: 815
D3/5: region item: rows3: 310
D3/5: region item: depths: 10
D3/5: region item: e-w resol3: 1000
D3/5: region item: n-s resol3: 1000
D3/5: region item: t-b resol: 100
D3/5: region item: north: 228500
D3/5: region item: south: 215000
D3/5: region item: east: 645000
D3/5: region item: west: 630000
D3/5: region item: cols: 1500
D3/5: region item: rows: 1350
D3/5: region item: e-w resol: 10
D3/5: region item: n-s resol: 10
D3/5: region item: top: 1
D3/5: region item: bottom: 0
D3/5: region item: cols3: 1500
D3/5: region item: rows3: 1350
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 228500
south: 215000
west: 630000
east: 645000
nsres: 10
ewres: 10
rows: 1350
cols: 1500
cells: 2025000
GRASS 7.0.svn> D1/5: grass.script.core.start_command(): g.gisenv -n
D3/5: GS_set_att_defaults
D3/5: G_str_to_color(): str = 'white'
D3/5: GS_clear
D3/5: GS_init_view
D3/5: GS_get_aspect(): left=0, right=19, top=19, bottom=0
D3/5: GS_set_focus(): 500.000000,500.000000,0.000000
D3/5: GS_get_zrange(): min=3.1112e-039 max=3.1117e-039
D3/5: GS_set_infocus
D1/5: Nviz_set_light_position(): num = 1 x = 0.680000 y = -0.680000 z =
0.800000 w = 0.000000
D1/5: Nviz_set_light_bright(): num = 1 value = 0.800000 r = 0.800000 g =
0.800000 b = 0.800000
D1/5: Nviz_set_light_color(): num = 1 r = 255/0.800000 g = 255/0.800000 b
= 255/0.800000
D1/5: Nviz_set_light_ambient(): num = 1 value = 0.200000
D1/5: Nviz_set_light_position(): num = 2 x = 0.000000 y = 0.000000 z =
1.000000 w = 0.000000
D1/5: Nviz_set_light_bright(): num = 2 value = 0.500000 r = 0.500000 g =
0.500000 b = 0.500000
D1/5: Nviz_set_light_color(): num = 2 r = 255/0.500000 g = 255/0.500000 b
= 255/0.500000
D1/5: Nviz_set_light_ambient(): num = 2 value = 0.300000
D1/5: G_find_raster2(): name=elevationg7@g7 mapset=
D5/5: gs_num_surfaces(): num=0
D3/5: GS_new_surface():
D5/5: gs_get_new_surface(): id=110658
D5/5: gs_init_surf() id=110658
D5/5: gs_set_defaults(): id=110658
D5/5: gs_set_att_src(): id=110658 desc=5 src=2
D5/5: gs_get_att_src(): id=110658, desc=5
D3/5: id=110658
D3/5: GS_load_att_map(): map=elevationg7@g7
D5/5: gs_get_surf():
D5/5: id=110658
D5/5: gs_set_att_src(): id=110658 desc=1 src=1
D5/5: gs_get_att_src(): id=110658, desc=1
D3/5: region item: format: -1
D3/5: region item: compressed: 1
D3/5: GS_load_att_map(): elevationg7@g7 not loaded in correct form -
loading now
D5/5: gs_get_att_typbuff(): id=110658 desc=1 to_write=1
D1/5: G_find_raster2(): name=elevationg7@g7 mapset=g7
D3/5: Gs_numtype(): fp map detected
D5/5: gs_malloc_att_buff
D5/5: gs_set_att_type(): desc=1, type=32
D5/5: gsds_alloc_typbuff(): 253.800000 Kbytes allocated, current total =
253.800000
D5/5: gs_set_att_type(): desc=1, type=8
D5/5: gsds_alloc_typbuff(): 8100.000000 Kbytes allocated, current total =
8353.800000
D3/5: Gs_loadmap_as_float(): name=elevationg7@g7
D1/5: G_find_raster2(): name=elevationg7 mapset=g7
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1134>
