[GRASS-dev] [GRASS GIS] #1142: r.in.poly fails in LL
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: svn-releasebranch64
Keywords: r.in.poly | Platform: Unspecified
      Cpu: Unspecified |
As reported on the -dev list, r.in.poly is not working in lat/long
locations.
http://lists.osgeo.org/pipermail/grass-dev/2010-August/051769.html
http://lists.osgeo.org/pipermail/grass-dev/2010-August/051773.html
apparently it works in 6.3.0 but fails in 6.4.0svn. (I can reproduce it
too)
Remember to run g.region first(?),
g.region s=34 n=37 w=-79 e=-77 res=0:01 -p
r.in.poly in=- out=test << EOF
A
  -78.254 35.82
  -78.005 36.201
  -77.707 36.135
  -77.84 35.853
  -78.196 35.721
  -78.254 35.82
= 1 coord
EOF
r.univar test
I have tested r.digit in 6.4.0svn, which is just a front-end to r.in.poly,
and it works. The .tmp file it creates looks like this:
AREA
  78:10:08.695652W 36:36:33.569132N
  78:39:25.217391W 35:39:15.62701N
  78:08:24.347826W 34:56:25.85209N
  77:26:57.391304W 35:43:53.440514N
  77:37:23.478261W 36:31:38.392283N
  78:00:17.391304W 35:34:37.813505N
  78:14:12.173913W 35:50:15.434084N
  77:58:50.434783W 36:32:13.118971N
  78:08:59.130435W 36:38:00.385852N
= 3 label
I suspect if you try r.in.poly with D:M:Sh coord notation in it will work.
I have just build 6.4.0rc2, and there it still works there. Will try newer
RCs later to try and narrow down the time of this change.
Also, r.in.poly should really be creating geodesic lines between vertices
when in a lat/long location. need to check that too.
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1142&gt;
      Cpu: Unspecified |
Comment(by helena):
I copied both of your files above into a txt file and used it with
r.in.poly and it worked. r.digit worked as well.
I went back to the original email and copied the file again and it worked
fine. And I made sure the region is set right.
I bet that they had something wrong with how the region was set up
although the region coordinates that they sent were Ok.
So I think you can close it,
Helena
P.S. Among several files with different formatting that work, I still have
this one that is giving NULLs
(perhaps some typo that I don't see)
AREA
  78:25:00.0W 35:82:00.0N
  78:00:00.0W 36:20:00.0N
  77:70:00.0W 36:13:00.0N
  77:84:00.0W 35:85:00.0N
= 1 coord
Ticket URL: <https://trac.osgeo.org/grass/ticket/1142#comment:1&gt;
Priority: normal | Milestone: 6.4.0
      Cpu: Unspecified |
Changes (by marisn):
  * priority: major => normal
Comment:
Everything seems to work just fine on AMD64 with current 6.4. svn, if
region is set correctly. IMHO this is the real bug, as r.in.* should not
be affected by current region.
As goes for Helena's second example - minutes exceed 60 (35:82:00.0N) and
thus whole line gets ignored.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1142#comment:2&gt;
      Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:2 marisn]:
I'm going to go back and retest this, I'm sure when I first tested it I
had run g.region first..
> IMHO this is the real bug, as r.in.* should not be affected by current
region.
That r.in.poly, r.in.xyz, and v.to.rast do not set region for you is not a
bug. These modules ''create'' raster maps not ''import'' existing arrays.
There is no good way to decide on what the resolution should be, and
how/if to align the grid to the bounding box. These are decisions the user
must make for themselves and are a critical, and very useful, fundamental
feature of the workflow.
and thus
That should give a warning, as should "No features found in current
region" (ala d.vect). I think to make that "nothing found" warning a
G_message() though, so you can shut it up with --quiet. (fixed region may
be what you want)
cheers,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1142#comment:3&gt;
      Cpu: Unspecified |
Comment(by cmbarton):
r.in.poly only works with cell maps and transforms any floats to integer.
Perhaps this is part of the problem? We've run into odd results in non LL
regions that ultimately were a result of this.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1142#comment:4&gt;
      Cpu: Unspecified |
Comment(by hamish):
tested again in 6.4.0svn, seems ok.
additional warnings would be nice, but fwiw the man page already says:
NOTES
        The data will be imported using the current region settings
        to set the new raster map's bounds and resolution. Any fea-
        tures falling outside the current region will be cropped. The
        region settings are contolled with the g.region module.
and
  [...] To give meaning to the features, the "="
        indicates that the feature currently being processed has cat-
        egory value cat# (which must be an integer) and a label
        (which may be more than one word, or which may be omitted).
bad coord warnings improved in 6.5svn, trunk in r43330, r43331.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1142#comment:5&gt;
      Cpu: Unspecified |
Comment(by neteler):
Hamish, do you plan to backport r43331? Otherwise it may be closed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1142#comment:6&gt;
      Type: defect | Status: closed
  Priority: normal | Milestone: 6.4.1
Resolution: fixed | Keywords: r.in.poly
  Platform: Unspecified | Cpu: Unspecified
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
  * milestone: 6.4.0 => 6.4.1
Comment:
backported to relbr64 by markusN in r43572.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1142#comment:7&gt;
