[GRASS-dev] [GRASS GIS] #1143: WinGrass64RC7 - db.execute
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Database | Version: 6.4.0 RCs
Keywords: wingrass, db.execute | Platform: MSWindows Vista
      Cpu: x86-32 |
in WinGRASS-6.4.0RC7-1-Setup.exe, db.execute is greyed out in the wxgui-
pulldown-menue Database -> Query -> SQL statement (=db.execute).
after typing db.execute in the wxgui-command-line, the whole wxgui
freezes.
but in the msys-commandline I get the help for db.execute
GRASS 6.4> db.execute --help
Beschreibung:
  Führt jegliche SQL-Abfrage aus.
Schlüsselwörter:
  Datenbank, Attributtabelle, SQL
Benutzung:
  db.execute [-i] [input=name] [driver=name] [database=name]
    [--verbose] [--quiet]
Flags:
   -i Ignoriere SQL-Fehler und fahre fort.
  --v Detaillierter Ausgabemodus
  --q Schweigsamer Ausgabemodus
Parameter:
      input Name der Datei, die SQL-Befehle enthält.
     driver Treibername
              Optionen:
dbf,dbf.manifest,odbc,odbc.manifest,ogr,ogr.manifest,
                       pg,pg.manifest,sqlite,sqlite.manifest
               Standard: dbf
   database Datenbankname
               Standard: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
and with
GRASS 6.4> db.execute --ui
in the msys-commandline, the db.execute-wxgui pops up.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1143&gt;
Priority: blocker | Milestone: 6.4.0
      Cpu: x86-32 |
Changes (by martinl):
  * priority: normal => blocker
Ticket URL: <http://trac.osgeo.org/grass/ticket/1143#comment:1&gt;
      Cpu: x86-32 |
Comment(by martinl):
Replying to [ticket:1143 hellik]:
hopefully fixed in r43388.
freezes.
seems to work on my PC.
Martin
Ticket URL: <https://trac.osgeo.org/grass/ticket/1143#comment:2&gt;
      Cpu: x86-32 |
Replying to [comment:2 martinl]:
wxgui-pulldown-menue Database -> Query -> SQL statement (=db.execute).
freezes.
Could anyone confirm that the bug was fixed? The only one blocker for
6.4.0... Thanks.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1143#comment:3&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:3 martinl]:
freezes.
6.4.0... Thanks.
there seems to be no nightly build from last night
(http://josef.fsv.cvut.cz/wingrass/grass64/). so I have to compile for
myself first.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1143#comment:4&gt;
      Cpu: x86-32 |
Replying to [comment:4 hellik]:
myself first.
hm, the Windows server is not responding. I need to ask the admin... So
unfortunately the builds are missing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1143#comment:5&gt;
      Cpu: x86-32 |
Comment(by hellik):
freezes.
6.4.0... Thanks.
myself first.
> Helmut
starting grass64 inside
C:\OSGeo4W\usr\src\grass64svn\bin.i686-pc-mingw32
db.execute isn't greyed out and db.execute also works from the wxgui-
commandline, there's no GUI-freezing.
I'll build locally a WinGrass64-installer and try this also.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1143#comment:6&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass, db.execute
  Platform: MSWindows Vista | Cpu: x86-32
Changes (by hellik):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:6 hellik]:
the wxgui-pulldown-menue Database -> Query -> SQL statement (=db.execute).
wxgui freezes.
for 6.4.0... Thanks.
myself first.
> > Helmut
> Helmut
also tried with a self built WinGrass64-installer (r43388) - installed in
C:\Program Files\GRASS-64-SVN - all works fine now.
thanks for the fix.
I'll close the ticket.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1143#comment:7&gt;
Replying to [comment:5 martinl]:
myself first.
daily builds are back.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1143#comment:8&gt;
