#1150: Cannot open vector for editing in digitize toolbar in GRASS 7.0
Reporter: PvB | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Vector | Version: unspecified
Keywords: | Platform: Linux
Cpu: x86-64 |
When opening the vector digitizing toolbar I can not select a vector layer
for editing. The vector layer is open (existing or just newly created) in
the layer manager, and is shown in the drop down box in the digitizing
toolbar, but selecting it doesn't do anything.
Component: wxGUI | Version: unspecified
Cpu: x86-64 |
Changes (by marisn):
* component: Vector => wxGUI
Comment:
Check out console output and You will see nice error message:
File "/home/maris/soft/grass_trunk/dist.x86_64-unknown-
linux-gnu/etc/gui/wxpython/gui_modules/vdigit.py", line 230,
in __init__
mapwindow)
linux-gnu/etc/gui/wxpython/vdigit/grass7_wxvdigit.py", line
330, in __init__
this = _grass7_wxvdigit.new_Digit(*args)
TypeError: in method 'new_Digit', argument 2 of type
'wxWindow *'
linux-gnu/etc/gui/wxpython/gui_modules/mapdisp_window.py",
line 337, in CheckPseudoDC
self.pdc.SetBackground(wx.Brush(self.GetBackgroundColour()))
384, in SetBackground
def SetBackground(self, *args): return
_grass7_wxvdigit.PseudoDC_SetBackground(self, *args)
TypeError: in method 'PseudoDC_SetBackground', argument 2 of
type 'wxBrush const &'
linux-gnu/etc/gui/wxpython/gui_modules/toolbars.py", line
1263, in OnSelectMap
self.StartEditing(self.layers[selection])
1311, in StartEditing
GError(parent = self.parent,
NameError
global name 'GError' is not defined
Reporter: PvB | Owner: martinl
Priority: normal | Milestone: 6.5.0
Keywords: wxVdigit | Platform: Linux
Cpu: x86-64 |
Comment(by PvB):
OK, so this also is true for GRASS 7.0? I see that in 6.4 the whole module
is removed, but in GRASS 7.0 the module is there (well, one can open the
menu bar).
Cpu: x86-64 |
Comment(by martinl):
Replying to [comment:4 PvB]:
module is removed, but in GRASS 7.0 the module is there (well, one can
open the menu bar).
not removed, just disabled in GRASS 6.4. You can compile it manually
Cpu: x86-64 |
Comment(by PvB):
Ah, ok, thanks. I am most concerned with getting it to work in GRASS 7
though. Just out of curiosity I tried your suggestion, but for grass 7.
The only output that it gives me is
"make: Nothing to be done for `first'".
This seems to be the same or similar as what was reported here: http
://osgeo-org.1803224.n2.nabble.com/No-module-named-grass7-wxvdigit-
td3102096.html.
