[GRASS-dev] [GRASS GIS] #1152: d.out.file + cairo: errors writing the image
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Display | Version: unspecified
Keywords: d,out.file, cairo | Platform: Linux
      Cpu: x86-64 |
in 6.4/6.5svn d.out.file with -c for the Cairo driver is having problems
writing to the file. ISTR this was discussed on the ML recently, with the
explanation something like that `d.mon start=` returns without waiting?
G65> d.out.file -c landsat
Saving display from Monitor: [x0] to <landsat.png>.
Image size [1115 x 988]
  100%
ERROR: Cairo_draw_bitmap: Failed to create source
WARNING: Socket is already in use or not accepting connections.
WARNING: Use d.mon to select a monitor
ERROR: No graphics device selected
WARNING: Error - Monitor 'cairo' was not running
Screen export complete. (writing the file may take a small amount of time)
Image crop [1115 x 987]
Done.
the image is a large (7000x8000) raster with a d.grid and d.text
decorations over the top of it. I tried pushing in a `sleep 1` before each
d.* command from d.save, but no luck.
on a simple low-res image it does fine, as does running with the regular
PNG driver. same behavior on multiple machines & different linux distros.
(deb/ubu)
perhaps the solution is setting one of the display driver direct rendering
enviro variables?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1152&gt;
      Cpu: x86-64 |
Comment(by hamish):
using `sync` instead of `sleep` seems to work, but I doubt it is the best
solution or portable to MSys.
Index: d.out.file
--- d.out.file (revision 43358)
+++ d.out.file (working copy)
@@ -350,11 +350,21 @@
  if [ "$GIS_FLAG_T" -eq 1 ] ; then
     # skip flood filling of background
- dsave=`d.save -a | grep -v '^d.erase'`
+ if [ "$GRAPHICS_DRIVER" != "cairo" ] ; then
+ dsave=`d.save -a | grep -v '^d.erase'`
+ else
+ #wait for it to catch up
+ dsave=`d.save -a | grep -v '^d.erase' | sed -e 's/^d\./sync; d./'`
+ fi
  else
- dsave=`d.save -a`
+ dsave=`d.save -a`
+ else
+ dsave=`d.save -a | sed -e 's/^d\./sync; d./'`
+ fi
  fi
  d.mon start=$GRAPHICS_DRIVER $BEQUIET
    # 'd.info -b' for white band removal
    BOX=`d.info -b | cut -f2 -d':'`
Ticket URL: <https://trac.osgeo.org/grass/ticket/1152#comment:1&gt;
      Cpu: x86-64 |
Comment(by glynn):
Replying to [comment:1 hamish]:
That's sheer coincidence. "sync" waits for modified blocks to be written
to disk. This could take several seconds, or it could return immediately.
In this case, the problem is:
The monitor process is terminating via G_fatal_error(). Once that happens,
subsequent d.* commands will fail however long you wait. Using
GRASS_RENDER_IMMEDIATE=TRUE will prevent this (the command provoking the
error will fail, but subsequent commands will succeed), but that's a
workaround. The fix is to sync the cairo driver to 7.0, where the issue
has been fixed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1152#comment:2&gt;
Keywords: d.out.file, cairo | Platform: Linux
      Cpu: x86-64 |
Changes (by hamish):
  * keywords: d,out.file, cairo => d.out.file, cairo
Comment:
Replying to [comment:2 glynn]:
> issue has been fixed.
erm, the whole thing? (attached diff is 50k without the new files)
Hamish
ps- fwiw Markus has just backported the "Use 64-byte header to ensure
frame buffer alignment (trac #937)" from 65 to 64.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1152#comment:3&gt;
      Cpu: x86-64 |
Comment(by glynn):
Replying to [comment:3 hamish]:
No; the 7.0 version won't work as-is in 6.x due to the substantial changes
to the graphics architecture.
I mean: modify lib/cairodriver/Draw_bitmap.c so that it resembles the
version in 7.0, but not so much that it doesn't compile or run.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1152#comment:4&gt;
      Cpu: x86-64 |
Comment(by hamish):
lib/cairodriver/Draw_bitmap.c changes backported to 6.5svn in r43698.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1152#comment:5&gt;
Keywords: d.out.file, cairo | Platform: All
      Cpu: All |
Changes (by glynn):
  * platform: Linux => All
  * cpu: x86-64 => All
Comment:
BTW, this is a duplicate of #1123 (which I've closed as "duplicate", as
this one has more content).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1152#comment:6&gt;
      Cpu: All |
Comment(by hamish):
Replying to [comment:6 glynn]:
> "duplicate", as this one has more content).
ok, thanks. for the record the test case given in #1123 is the best way I
know to trigger the bug. I've just tested in 6.5svn+the backported fix and
it works, while relbr6.4 fails (as expected).
if someone else could test the 6.5svn version on another platforms (i.e.
Mac and WinGrass) we can backport it to 6.4 as well.
I guess WinGrass users might have to select cairo mode from the wx GUI
preferences?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1152#comment:7&gt;
      Cpu: All |
Comment(by hellik):
Replying to [comment:7 hamish]:
I know to trigger the bug. I've just tested in 6.5svn+the backported fix
and it works, while relbr6.4 fails (as expected).
preferences?
> Hamish
AFAIK there's no cairo-support in WinGrass at the moment (see
http://trac.osgeo.org/osgeo4w/ticket/72).
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1152#comment:8&gt;
      Cpu: All |
Comment(by martinl):
+1 for backport before 6.4.1
Ticket URL: <http://trac.osgeo.org/grass/ticket/1152#comment:9&gt;
      Cpu: All |
Comment(by hamish):
Replying to [comment:9 martinl]:
done in r44628 (but not tested)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1152#comment:10&gt;
      Cpu: All |
Replying to [comment:10 hamish]:
so can we close this ticket?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1152#comment:11&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: d.out.file, cairo
  Platform: All | Cpu: All
  * status: new => closed
  * resolution: => fixed
Comment:
tested; it's fixed.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1152#comment:12&gt;
