[GRASS-dev] [GRASS GIS] #1154: r.drain hangs using an r.walk surface
Reporter: abevan | Owner: grass-dev@…
     Type: defect | Status: new
Component: Raster | Version: svn-trunk
Keywords: r.drain | Platform: MacOSX
      Cpu: OSX/Intel |
GRASS 7.0.svn (spearfish):~ > r.walk -k -n elevation=elevation.10m
friction=elevation.10m coordinate=603289,4925264 output=anisoA
outdir=anisoAdir lambda=0
[[BR]]
Walking costs are a=0.720000 b=6.000000 c=1.999800 d=-1.999800
Lambda is 0.000000
Slope_factor is -0.212500
Will need at least 9.23 MB of disk space
Will need at least 12.29 MB of memory
Reading raster maps <elevation.10m@PERMANENT> and
<elevation.10m@PERMANENT>, initializing output...
100%
Initializing directional output
100%
Finding cost path
100%
Writing output raster map anisoA...
100%
Writing movement direction file anisoAdir...
100%
r.walk complete. Peak cost value: 18025.341210.
[[BR]]
GRASS 7.0.svn (spearfish):~ > r.drain -c -d input=anisoA indir=anisoAdir
output=fromAtoB coordinate=595080,4918109 --v
[[BR]]
Directional drain selected... checking for direction raster
direction read: 67.500000, neighbour found: 675
direction read: 22.500000, neighbour found: 225
direction read: 90.000000, neighbour found: 900
direction read: 0.000000, neighbour found: 0
direction read: 180.000000, neighbour found: 1800
Ticket URL: <https://trac.osgeo.org/grass/ticket/1154&gt;
      Cpu: OSX/Intel |
Comment(by mmetz):
fixed in r43478, please test
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1154#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.drain
  Platform: MacOSX | Cpu: OSX/Intel
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:1 mmetz]:
> Markus M
Works fine:
GRASS 7.0.svn (spearfish60_grass7):~ > g.region rast=elevation.10m
GRASS 7.0.svn (spearfish60_grass7):~ > r.walk -k -n
elevation=elevation.10m \
friction=elevation.10m start_coordinate=603289,4925264 output=anisoA \
Lambda is 0.000000
Will need at least 70.89 MB of disk space
Will need at least 86.53 MB of memory
  100%
  100%
Finding cost path
  100%
  100%
  100%
r.walk complete. Peak cost value: 18230.616166.
GRASS 7.0.svn (spearfish60_grass7):~ > d.mon wx0
GRASS 7.0.svn (spearfish60_grass7):~ > d.rast elevation.10m
  100%
GRASS 7.0.svn (spearfish60_grass7):~ > d.rast anisoA
  100%
GRASS 7.0.svn (spearfish60_grass7):~ > d.rast anisoAdir
  100%
GRASS 7.0.svn (spearfish60_grass7):~ > r.drain -c -d input=anisoA
indir=anisoAdir output=fromAtoB start_coordinate=595080,4918109
Writing raster map <fromAtoB>...
  100%
Ticket URL: <http://trac.osgeo.org/grass/ticket/1154#comment:2&gt;
