[GRASS-dev] [GRASS GIS] #1157: WinGrass-Installer should include a working gdal-version which is built against
against
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Packaging | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: All |
from the user-ML
http://lists.osgeo.org/pipermail/grass-user/2010-September/057851.html
>>Dear all,
>>I have just installed Wingrass7 from
>>[http://josef.fsv.cvut.cz/wingrass/grass70/\]
>>When it is started the locations which work well with Grass6.4 version,
>>there is the error: Unable to get current geographic extent. Force
>>quitting wxGUI. Please run manual g.region to fix
>>problem....Importerror: No module named agw.customtreectrl
>>Or when I make new location by Location wizard there is the error: ..
>>[Error 2] No such file or directory: 'C:\\Program Files\\
>>GRASS-70-SVN\\etc\\proj-parms.table'
>>Please help me what should I do?
>>Thank you
>>Thy
>I can confirm this.
>at the moment the nightly WinGrass7-builds are built against gdal17 from
osgeo4w,
>which is in a preliminary status at the moment.
>I build from time to time WinGrass7 for my own with gdal16 from osgeo4w
and there are
>no such error messages.
>best regards
>Helmut
it seems to be a mixing of different gdal-versions.
WinGrass70 is built against gdal17. but in WinGrass7 (installed by the
installer) there is
only gdal15 in the path and available in the WinGrass7-command-line, but
no gdal17.
AFAIK there are some important changes from gdal15 to gdal17. so a
WinGrass7 built against gdal17
isn't working with gdal15 in the path?
so maybe the WinGrass7-installer built against gdal17 should be adapted in
that way to adopt gdal17 as the regular version
of gdal?
best regards
Helmut
related to the nightly WinGrass-builds, all branches and the recommended
way of compiling wingrass in the wiki (both inside the osgeo4w-stack).
at the moment WinGrass64 and WinGrass65 are built against gdal16,
WinGrass70 against gdal17. but in the WinGrassXX-installer only gdal15 is
available in the path, but no gdal16/gdal17 and all dependecies
(GDAL_DATA, GDAL_DRIVER_PATH,
PYTHONPATH=%OSGEO4W_ROOT%\apps\gdal-16\pymod,
PATH=%OSGEO4W_ROOT%\apps\gdal-16\bin; the same for gdal17; see gdal16.bat
or gdal17.bat in C:\OSGeo4W\bin) living in C:\OSGeo4W\apps\gdal-16 or
C:\OSGeo4W\apps\gdal-17 are included.
the wingrass-installer should include a working gdal-version which the
WinGrass-version is installed against.
best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1157&gt;
against
      Cpu: All |
Comment(by hellik):
Replying to [ticket:1157 hellik]:
ok, I see also in the error message above:
[Error 2] No such file or directory: 'C:\\Program Files\\GRASS-70-SVN\\etc
\\proj-parms.table'
in C:\Program Files\GRASS-64\etc there are following files:
proj-desc.table
projections
proj-parms.table
proj-units.table
but in C:\Program Files\GRASS-70-SVN\etc there is only
projections
and the other files are missing.
so maybe there is additional to the gdal-version issue also an issue with
the files mentioned above?
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1157#comment:1&gt;
against
      Cpu: All |
Comment(by hellik):
Replying to [comment:1 hellik]:
Files\\GRASS-70-SVN\\etc\\proj-parms.table'
> proj-desc.table
> projections
> proj-parms.table
> proj-units.table
> projections
with the files mentioned above?
> Helmut
a comparison
  Verzeichnis von C:\Program Files\GRASS-64\etc
04.09.2010 00:30 <DIR> .
04.09.2010 00:30 <DIR> ..
03.09.2010 22:39 38.828 bmif_to_cell.exe
03.09.2010 23:18 629 bmif_to_cell.exe.manifest
03.09.2010 22:13 44.671 clean_temp.exe
03.09.2010 23:18 625 clean_temp.exe.manifest
04.09.2010 00:28 <DIR> colors
03.09.2010 22:08 1.697 colors.desc
03.09.2010 23:03 17.792 current_time_s_ms.exe
03.09.2010 23:18 639 current_time_s_ms.exe.manifest
04.09.2010 00:28 <DIR> d.polar
03.09.2010 22:55 13.806 d.rast.edit.tcl
03.09.2010 22:08 5.050 datum.table
03.09.2010 22:08 6.882 datumtransform.table
04.09.2010 00:28 <DIR> db.test
04.09.2010 00:28 <DIR> dm
03.09.2010 22:14 28.045 echo.exe
03.09.2010 23:18 613 echo.exe.manifest
03.09.2010 22:08 980 element_list
03.09.2010 22:08 6.117 ellipse.table
03.09.2010 22:14 18.524 epsg_option.tcl
03.09.2010 22:14 9.631 file_option.tcl
03.09.2010 22:08 123.801 FIPS.code
04.09.2010 00:30 41.590 fontcap
03.09.2010 23:35 41.302 fontcap.tmpl
04.09.2010 00:28 <DIR> form
03.09.2010 22:17 36.245 frame.create
03.09.2010 22:17 34.522 frame.dumper
03.09.2010 22:17 37.615 frame.list
03.09.2010 22:17 37.425 frame.select
03.09.2010 22:23 2.441 g.mapsets.tcl
04.09.2010 00:28 <DIR> gem
03.09.2010 22:14 30.370 gis_set.tcl
04.09.2010 00:28 <DIR> gm
03.09.2010 22:29 5.143 grass-interface.dtd
03.09.2010 22:14 459 grass-run.bat
03.09.2010 22:14 999 grass-run.sh
03.09.2010 22:14 535 grass-xterm-wrapper
03.09.2010 22:14 414 grass_intro
03.09.2010 23:02 832 grass_write_ascii.style
03.09.2010 22:10 21.408 grocat.exe
03.09.2010 23:18 617 grocat.exe.manifest
04.09.2010 00:28 <DIR> gtcltk
04.09.2010 00:28 <DIR> gui
03.09.2010 22:08 24.658 gui.tcl
03.09.2010 22:31 64.495 i.ask.exe
03.09.2010 23:18 615 i.ask.exe.manifest
03.09.2010 22:31 44.674 i.find.exe
03.09.2010 23:18 617 i.find.exe.manifest
04.09.2010 00:28 <DIR> i.oif
03.09.2010 22:14 5.641 Init.bat
03.09.2010 22:13 27.498 Init.sh
03.09.2010 22:14 550 license
04.09.2010 00:28 <DIR> lister
03.09.2010 22:13 34.223 lock.exe
03.09.2010 23:18 613 lock.exe.manifest
03.09.2010 22:46 37.742 modcats.exe
03.09.2010 23:18 619 modcats.exe.manifest
03.09.2010 22:46 35.174 modcolr.exe
03.09.2010 23:18 619 modcolr.exe.manifest
03.09.2010 22:46 69.225 modhead.exe
03.09.2010 23:18 619 modhead.exe.manifest
03.09.2010 22:46 35.552 modhist.exe
03.09.2010 23:18 619 modhist.exe.manifest
03.09.2010 22:19 23.640 mon.list
03.09.2010 22:19 35.657 mon.release
03.09.2010 22:19 38.187 mon.select
03.09.2010 22:19 36.092 mon.start
03.09.2010 22:19 33.176 mon.status
03.09.2010 22:19 35.223 mon.stop
03.09.2010 22:19 31.626 mon.which
03.09.2010 23:34 0 monitorcap
04.09.2010 00:28 <DIR> msgs
04.09.2010 00:28 <DIR> nad
04.09.2010 00:28 <DIR> nviz2.2
04.09.2010 00:28 <DIR> ogr_csv
04.09.2010 00:28 <DIR> paint
03.09.2010 22:39 38.948 poly_to_bmif.exe
03.09.2010 23:18 629 poly_to_bmif.exe.manifest
03.09.2010 22:26 1.505 proj-desc.table
03.09.2010 22:26 8.040 proj-parms.table
03.09.2010 22:26 480 proj-units.table
03.09.2010 22:08 2.916 projections
03.09.2010 22:13 368 prompt.sh
03.09.2010 22:09 3.150 psdriver.ps
04.09.2010 00:28 <DIR> python
04.09.2010 00:28 <DIR> r.in.wms
03.09.2010 22:49 138.484 r.watershed.ram.exe
03.09.2010 23:18 635 r.watershed.ram.exe.manifest
03.09.2010 22:49 168.031 r.watershed.seg.exe
03.09.2010 23:18 635 r.watershed.seg.exe.manifest
03.09.2010 22:13 23.033 run.exe
03.09.2010 23:18 611 run.exe.manifest
04.09.2010 00:29 721 run_gmkfontcap.bat
04.09.2010 00:29 652 run_gmkfontcap.bat.manifest
03.09.2010 22:13 75.811 set_data.exe
03.09.2010 23:18 621 set_data.exe.manifest
03.09.2010 22:08 25.112 state27
03.09.2010 22:08 20.617 state83
04.09.2010 00:28 <DIR> symbol
04.09.2010 00:28 <DIR> v.digit
03.09.2010 22:14 6 VERSIONNUMBER
03.09.2010 22:14 31 welcome
03.09.2010 22:14 398.346 winlocale.exe
03.09.2010 23:18 623 winlocale.exe.manifest
04.09.2010 00:28 <DIR> wxpython
and
  Verzeichnis von C:\Program Files\GRASS-70-SVN\etc
13.09.2010 23:54 <DIR> .
13.09.2010 23:54 <DIR> ..
13.09.2010 04:17 61.113 clean_temp.exe
13.09.2010 23:52 <DIR> colors
13.09.2010 04:15 1.621 colors.desc
13.09.2010 04:14 44.464 current_time_s_ms.exe
13.09.2010 23:52 <DIR> d.polar
13.09.2010 04:15 5.050 datum.table
13.09.2010 04:15 6.882 datumtransform.table
13.09.2010 23:52 <DIR> db.test
13.09.2010 04:17 44.447 echo.exe
13.09.2010 04:15 980 element_list
13.09.2010 04:15 6.117 ellipse.table
13.09.2010 04:15 123.801 FIPS.code
13.09.2010 23:54 41.662 fontcap
13.09.2010 04:25 34.940 fontcap.tmpl
13.09.2010 23:52 <DIR> form
13.09.2010 04:24 5.143 grass-interface.dtd
13.09.2010 04:17 416 grass_intro
13.09.2010 04:16 45.344 grocat.exe
13.09.2010 23:52 <DIR> gtcltk
13.09.2010 23:52 <DIR> gui
13.09.2010 04:22 60.709 i.find.exe
13.09.2010 04:17 552 license
13.09.2010 04:17 50.665 lock.exe
13.09.2010 04:15 2.950 projections
13.09.2010 04:15 3.010 psdriver.ps
13.09.2010 23:52 <DIR> python
13.09.2010 23:52 <DIR> r.in.wms
13.09.2010 04:17 43.019 run.exe
13.09.2010 23:53 765 run_gmkfontcap.bat
13.09.2010 23:53 652 run_gmkfontcap.bat.manifest
13.09.2010 04:15 25.112 state27
13.09.2010 04:15 20.617 state83
13.09.2010 23:52 <DIR> symbol
13.09.2010 04:17 8 VERSIONNUMBER
13.09.2010 04:17 33 welcome
13.09.2010 04:17 418.332 winlocale.exe
13.09.2010 04:23 4.438 wxpyimgview_gui.py
this comparison is based on the official WinGrass6.4.0-installer (built by
me) and the nightly WinGrass7.0-build (from
http://josef.fsv.cvut.cz/wingrass/grass70/).
as to note, by a self compiled WinGrass70, the above error doesn't occur.
so maybe this ticket should be separeted into following two:
- packaging error for nightly WinGrass70-builds
- original task mentioned in the subject:
against
best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1157#comment:2&gt;
against
      Type: defect | Status: closed
Component: Packaging | Version: svn-releasebranch64
Resolution: fixed | Keywords: wingrass
  Platform: MSWindows Vista | Cpu: All
Changes (by hellik):
  * keywords: => wingrass
  * platform: Unspecified => MSWindows Vista
  * status: new => closed
  * resolution: => fixed
  * version: unspecified => svn-releasebranch64
Comment:
fixed by commits of #1271
Ticket URL: <http://trac.osgeo.org/grass/ticket/1157#comment:3&gt;
