[GRASS-dev] [GRASS GIS] #1159: v.in.ascii fails with long text file in WinGRASS-6.4.0-1
Reporter: lponti | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Vector | Version: 6.4.0
Keywords: v.in.ascii | Platform: MSWindows 7
      Cpu: x86-32 |
My settings: WinGRASS-6.4.0-1 on Windows 7. Performing example v.in.ascii
task showed in manual:
v.in.ascii input=coords.txt output=mymap
works fine in Spearfish location.
Using this text file:
https://docs.google.com/leaf?id=0B0EpsfMZ-
IZYNGZlNWZkMWEtNzhiNS00OGRiLTgyNzctYzk4ODUxODk1NzI1&sort=name&layout=list&num=50
in a latlong location with the following command:
v.in.ascii
input=C:\cygwin\home\andy\models_temp\Bloomday_Olive_11set10_Avg
output=test_US_import fs=\t
yields an error:
v.in.ascii
Scanning input for column types...
Maximum input row length: 31
Maximum number of columns: 3
Minimum number of columns: 3
Column: 1 type: double
Column: 2 type: double
Column: 3 type: double
Importando punti ...
Populating table...
ERROR: Could not close attribute table. The DBMI driver did not accept all
attributes
Trying same test with an old (May 29) WinGRASS-6.4.svn installed on the
same machine (same command), everything seems ok:
v.in.ascii --overwrite
Populating table...
Building topology for vector map <test_US_import>...
Registering primitives...
    10001157 primitives registered
1157 vertices registered
Building areas...
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 1154
Number of primitives: 1157
Number of points: 1157
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
v.in.ascii completo.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [ticket:1159 lponti]:
I've tried this with the nc-sample-dataset in a WinVista32-box with the
WinGrass64-installer:
=> point mode
v.out.ascii --verbose input=firestations@PERMANENT
output=C:\wd\grassascii\pointmodeout.txt dp=4 columns=LOCATION,CITY
v.in.ascii -n --verbose input=C:\wd\grassascii\pointmodeout.txt
output=testvascii_import
BUG in description, Option 'point' in <format> doesn't exist.
BUG in descriptions, Option 'Standard' in <format> doesn't exist.
Scanne die Eingabe zur Ermittelung der Spaltentypen...
Maximale Länge der Inputzeile: 69
Maximale Anzahl der Spalten: 5
Minimale Anzahl der Spalten: 5
Column: 3 type: integer
Column: 4 type: string length: 30
Column: 5 type: string length: 13
Importiere Punkte...
Fülle Tabelle...
ERROR: Could not close attribute table. DBMI-driver doesn't accept all
attributes.
the message above is partly translated from german to english.
and with DEEBUG=3
output=testvascii_import2
BUG in Beschreibungen, Option 'Punkt' in <format> existiert nicht.
BUG in Beschreibungen, Option 'Standard' in <format> existiert nicht.
D2/3: Vect_open_new(): name = testvascii_import2
D1/3: Vect_set_thresh(): thresh = 0.000000
D1/3: V1_open_new_nat(): name = testvascii_import2
D1/3: Vect_get_thresh(): thresh = 0.000000
D1/3: dig__write_head()
D1/3: write coor size (0) to head
D2/3: coor body offset 14
D3/3: dig_init_plus()
D1/3: dig_spidx_init()
D3/3: dig_cidx_init()
D3/3: Vect_hist_command()
D3/3: G_recreate_command()
D2/3: G__read_Cell_head
D2/3: G__read_Cell_head_array
D3/3: region item: proj: 99
D3/3: region item: zone: 0
D3/3: region item: north: 228513
D3/3: region item: south: 214975.5
D3/3: region item: east: 645012
D3/3: region item: west: 629992.5
D3/3: region item: cols: 527
D3/3: region item: rows: 475
D3/3: region item: e-w resol: 28.5
D3/3: region item: n-s resol: 28.5
D3/3: region item: top: 1
D3/3: region item: bottom: 0
D3/3: region item: cols3: 527
D3/3: region item: rows3: 475
D3/3: region item: depths: 1
D3/3: region item: e-w resol3: 28.5
D3/3: region item: n-s resol3: 28.5
D3/3: region item: t-b resol: 1
D3/3: row 1 : 68 chars
D3/3: row 2 : 66 chars
D3/3: row 3 : 56 chars
D3/3: row 4 : 47 chars
D3/3: row 5 : 56 chars
D3/3: row 6 : 55 chars
D3/3: row 7 : 45 chars
D3/3: row 8 : 49 chars
D3/3: row 9 : 46 chars
D3/3: row 10 : 48 chars
D3/3: row 11 : 49 chars
D3/3: row 12 : 48 chars
D3/3: row 13 : 48 chars
D3/3: row 14 : 50 chars
D3/3: row 15 : 49 chars
D3/3: row 16 : 52 chars
D3/3: row 17 : 58 chars
D3/3: row 18 : 53 chars
D3/3: row 19 : 51 chars
D3/3: row 20 : 52 chars
D3/3: row 21 : 52 chars
D3/3: row 22 : 46 chars
D3/3: row 23 : 48 chars
D3/3: row 24 : 53 chars
D3/3: row 25 : 47 chars
D3/3: row 26 : 49 chars
D3/3: row 27 : 51 chars
D3/3: row 28 : 50 chars
D3/3: row 29 : 48 chars
D3/3: row 30 : 53 chars
D3/3: row 31 : 51 chars
D3/3: row 32 : 52 chars
D3/3: row 33 : 50 chars
D3/3: row 34 : 49 chars
D3/3: row 35 : 56 chars
D3/3: row 36 : 50 chars
D3/3: row 37 : 53 chars
D3/3: row 38 : 52 chars
D3/3: row 39 : 62 chars
D3/3: row 40 : 53 chars
D3/3: row 41 : 57 chars
D3/3: row 42 : 57 chars
D3/3: row 43 : 51 chars
D3/3: row 44 : 51 chars
D3/3: row 45 : 49 chars
D3/3: row 46 : 46 chars
D3/3: row 47 : 52 chars
D3/3: row 48 : 50 chars
D3/3: row 49 : 51 chars
D3/3: row 50 : 59 chars
D3/3: row 51 : 56 chars
D3/3: row 52 : 56 chars
D3/3: row 53 : 53 chars
D3/3: row 54 : 56 chars
D3/3: row 55 : 52 chars
D3/3: row 56 : 51 chars
D3/3: row 57 : 48 chars
D3/3: row 58 : 51 chars
D3/3: row 59 : 49 chars
D3/3: row 60 : 59 chars
D3/3: row 61 : 47 chars
D3/3: row 62 : 57 chars
D3/3: row 63 : 55 chars
D3/3: row 64 : 58 chars
D3/3: row 65 : 61 chars
D3/3: row 66 : 54 chars
D3/3: row 67 : 51 chars
D3/3: row 68 : 50 chars
D3/3: row 69 : 32 chars
D3/3: row 70 : 59 chars
D3/3: row 71 : 60 chars
D1/3: Vect_default_field_info(): map = testvascii_import2
field = 1
D2/3: drv = dbf db = $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
D3/3: Vect_subst_var(): in =
$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/, map =
testvascii_import2, mapset = user1
D3/3: -> C:\gisdata\grassdata/nc_spm_08/user1/dbf/
D3/3: db_start_driver_open_database():
   drvname = dbf, dbname =
D2/3: dbDbmscap(): opendir [c:\Program
Files\GRASS-64\driver\db\]
D3/3: win_spawn: args = C:\windows\system32\cmd.exe /c
""c:\Program Files\GRASS-64\driver\db\dbf.exe""
D2/3: DBF: db__driver_open_database() name =
'C:\gisdata\grassdata/nc_spm_08/user1/dbf/'
D2/3: db.name = C:\gisdata\grassdata/nc_spm_08/user1/dbf/
D2/3: add_table(): table = helli name = helli.dbf
D2/3: add_table(): table = testvascii_import name =
testvascii_import.dbf
D2/3: Begin transaction
D3/3: Field number <1>, name <(null)>
D3/3: Vect_check_dblink: field 1
D1/3: Vect_write_dblinks(): map = testvascii_import2, mapset
= user1
D1/3: dbln file: C:\gisdata\grassdata/nc_spm_08/user1/vector
/testvascii_import2/dbln
D1/3: 1 testvascii_import2 cat
$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ dbf
D1/3: Dblinks written
D3/3: create table testvascii_import2 ( cat integer, dbl_1
double precision, dbl_2 double precision, int_1 integer,
str_1 varchar(30), str_2 varchar(13) )
D3/3: SQL statement parsed successfully: create table
testvascii_import2 ( cat integer, dbl_1 double precision,
dbl_2 double precision, int_1 integer, str_1 varchar(30),
str_2 varchar(13) )
D2/3: find_table(): table = testvascii_import2
D2/3: ? helli
D2/3: ? testvascii_import
D3/3: Doing SQL command <1> on DBF table... (see
include/sqlp.h)
D2/3: add_table(): table = testvascii_import2 name =
testvascii_import2.dbf
D2/3: ? helli
D2/3: ? testvascii_import2
D3/3: add_column(): tab = 2, type = 2, name = cat, width =
11, decimals = 0
D3/3: add_column(): tab = 2, type = 3, name = dbl_1, width =
20, decimals = 6
D3/3: add_column(): tab = 2, type = 3, name = dbl_2, width =
20, decimals = 6
D3/3: add_column(): tab = 2, type = 2, name = int_1, width =
11, decimals = 0
D3/3: add_column(): tab = 2, type = 1, name = str_1, width =
30, decimals = 0
D3/3: add_column(): tab = 2, type = 1, name = str_2, width =
13, decimals = 0
= user1
= user1
D3/3: Vect_write_line(): name = testvascii_import2, format =
0, level = 1
D3/3: insert into testvascii_import2 values ( 1,
620856.9586, 230066.3831, 1, '6804 Carpenter Fire Station
Rd', 'Morrisville')
D3/3: SQL statement parsed successfully: insert into
testvascii_import2 values ( 1, 620856.9586, 230066.3831, 1,
'6804 Carpenter Fire Station Rd', 'Morrisville')
D2/3: ? helli
D2/3: load_table_head(): tab = 2, C:\gisdata\grassdata/nc_sp
m_08/user1/dbf//testvascii_import2.dbf
D3/3: Doing SQL command <3> on DBF table... (see
include/sqlp.h)
D2/3: load_table(): tab = 2
0, level = 1
D3/3: insert into testvascii_import2 values ( 2,
625331.9186, 229990.8216, 2, '100 Morrisville-Carpenter Rd',
'Morrisville')
testvascii_import2 values ( 2, 625331.9186, 229990.8216, 2,
'100 Morrisville-Carpenter Rd', 'Morrisville')
D2/3: ? helli
include/sqlp.h)
0, level = 1
D3/3: insert into testvascii_import2 values ( 3,
615797.6655, 213363.9926, 3, '3045 New Hill Holleman Rd',
'Apex')
testvascii_import2 values ( 3, 615797.6655, 213363.9926, 3,
'3045 New Hill Holleman Rd', 'Apex')
D2/3: ? helli
include/sqlp.h)
0, level = 1
D3/3: insert into testvascii_import2 values ( 4,
623113.7142, 219859.0622, 4, '210 N. Salem St.', 'Apex')
testvascii_import2 values ( 4, 623113.7142, 219859.0622, 4,
D2/3: ? helli
include/sqlp.h)
0, level = 1
D3/3: insert into testvascii_import2 values ( 5,
627926.2843, 203208.6161, 5, '301 S. Fuquay Av', 'Fuquay-
Varina')
testvascii_import2 values ( 5, 627926.2843, 203208.6161, 5,
'301 S. Fuquay Av', 'Fuquay-Varina')
D2/3: ? helli
include/sqlp.h)
0, level = 1
D3/3: insert into testvascii_import2 values ( 6,
634666.6648, 207474.4939, 6, '5617 Hilltop Rd', 'Fuquay-
Varina')
testvascii_import2 values ( 6, 634666.6648, 207474.4939, 6,
'5617 Hilltop Rd', 'Fuquay-Varina')
D2/3: ? helli
include/sqlp.h)
0, level = 1
D3/3: insert into testvascii_import2 values ( 7, 642099.61,
208679.4695, 7, '9115 Sauls Rd', 'Raleigh')
testvascii_import2 values ( 7, 642099.61, 208679.4695, 7,
D2/3: ? helli
include/sqlp.h)
0, level = 1
D3/3: insert into testvascii_import2 values ( 8,
636078.5716, 213276.0477, 8, '7401 Ten-Ten Rd', 'Raleigh')
testvascii_import2 values ( 8, 636078.5716, 213276.0477, 8,
D2/3: ? helli
include/sqlp.h)
0, level = 1
D3/3: insert into testvascii_import2 values ( 9,
630420.5003, 215694.0281, 9, '4501 Ten-Ten Rd', 'Apex')
testvascii_import2 values ( 9, 630420.5003, 215694.0281, 9,
D2/3: ? helli
include/sqlp.h)
0, level = 1
D3/3: insert into testvascii_import2 values ( 10,
627041.5491, 224084.2533, 10, '1401 Old Apex Rd', 'Cary')
testvascii_import2 values ( 10, 627041.5491, 224084.2533,
include/sqlp.h)
0, level = 1
D3/3: insert into testvascii_import2 values ( 71,
623658.6433, 209478.2433, 71, '1140 Avent Ferry Rd', 'Holly
Springs')
testvascii_import2 values ( 71, 623658.6433, 209478.2433,
71, '1140 Avent Ferry Rd', 'Holly Springs')
D2/3: ? helli
include/sqlp.h)
D2/3: Commit transaction
D2/3: save_table 0
D2/3: save_table 1
D2/3: save_table 2
D2/3: Write table to tempfile:
'C:\gisdata\grassdata/nc_spm_08/user1/.tmp/6896.dbf'
D2/3: Write 71 rows
D2/3: Written 71 records
Fülle Tabelle...
ERROR: Konnte Attributetabelle nicht schliessen. Der DBMI-Treiber hat
nicht alle Attribute akzeptiert.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:1&gt;
      Cpu: x86-32 |
Comment(by hamish):
[file is 3 column 'x y fp_value', with CRLF newlines]
tested in 6.4.0svn and 6.5svn on linux, works fine there.
v.in.ascii in=Bloomday_Olive_11set10_Avg.dat fs=tab out=test_US_import
(only thing I changed was 'fs=tab'; I think it is good to explicitly give
x= and y=..)
does it work if you switch to the SQLite DB backend?
(see db.connect module help page)
what if you add "columns='x double, y double, value varchar(20)'" ?
or "-z z=3" ? (but no columns= to avoid creating a table at all)
Helmut:
I suspect this is because somewhere the options got translated as well as
the option descriptions:
v.in.ascii/in.c:
format_opt->descriptions = _("point;simple x,y[,z] list;"
                              "standard;GRASS vector ASCII format");
"point" and "standard" must match exactly the line:
  format_opt->options = "point,standard"
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1159#comment:2&gt;
      Cpu: x86-32 |
Comment(by lponti):
Replying to [comment:2 hamish]:
> [...] I think it is good to explicitly give x= and y=..
Right, I forgot that. For sake of completeness, it does not help in this
case:
v.in.ascii input=Bloomday_Olive_11set10_Avg output=test_US_import fs=tab
x=1 y=2 z=0
Populating table...
attributes
Neither does specifying column type:
x=1 y=2 z=0 columns='x double, y double, value varchar(20)'
Column number 3 <value> defined as string has double values
Populating table...
attributes
Same with third column as double:
x=1 y=2 z=0 columns='x double, y double, value double'
Populating table...
attributes
db.connect driver=sqlite
database=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
db.connect -p
driver:sqlite
database:$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
schema:
group:
This does not work:
x=1 y=2 z=0
Populating table...
attributes
nor does this:
x=1 y=2 z=0 columns=x double, y double, value varchar(20)
Populating table...
attributes
or this:
x=1 y=2 z=0 columns=x double, y double, value double
Populating table...
attributes
Note: the --overwrite flag does not work because of Ticket #1158, so after
each v.in.ascii one needs to run g.remove twice on output file.
See above.
This works in sqlite (but no table, as you said):
x=1 y=2 -z z=3
Building areas...
0 areas built
0 isles built
Number of nodes: 1156
Number of lines: 0
Number of areas: 0
Number of isles: 0
(Wed Sep 15 10:19:46 2010) Command finished (0 sec)
and with dbf (surprisingly the --overwrite flag works):
v.in.ascii --overwrite input=Bloomday_Olive_11set10_Avg
output=test_US_import fs=tab x=1 y=2 -z z=3
Vector map <test_US_import> already exists and will be overwritten
Building areas...
0 areas built
0 isles built
Number of lines: 0
Number of areas: 0
Number of isles: 0
Sounds like the table is the problem?
Luigi
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:3&gt;
      Cpu: x86-32 |
Comment(by hamish):
The error message in question is from v.in.ascii/in.c,
if (driver) {
     G_message(_("Populating table..."));
     db_commit_transaction(driver);
     if(db_close_database_shutdown_driver(driver) == DB_FAILED)
         G_fatal_error(_("Could not close attribute table. The DBMI driver
did not accept all attributes"));
db_close_database_shutdown_driver() can be found in
lib/db/dbmi_client/db.c
it is not clear from the code which failed, closing the database or
shutting down the driver. I'll add debug messages to tell that, maybe
later today.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1159#comment:4&gt;
      Cpu: x86-32 |
Comment(by hamish):
level 2 debug messages added to db_close_database_shutdown_driver() in
trunk and devbr6
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:5&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:5 hamish]:
trunk and devbr6
tested with a self compiled Grass65 in the Osgeo4w-stack (WinVista32)
nc-sample-data-set
test ascii-point file created with
v.out.ascii input=firestations@PERMANENT
output=C:\wd\grassascii\firestation_ascii_point_g56.txt columns=CITY
this reimported with:
v.in.ascii -n input=C:\wd\grassascii\firestation_ascii_point_g56.txt
output=vinascii_with_table
D2/3: Vect_open_new(): name = vinascii_with_table
D1/3: V1_open_new_nat(): name = vinascii_with_table
D3/3: row 1 : 45 chars
D3/3: row 2 : 45 chars
D3/3: row 3 : 38 chars
D3/3: row 4 : 38 chars
D3/3: row 5 : 46 chars
D3/3: row 6 : 47 chars
D3/3: row 7 : 40 chars
D3/3: row 8 : 41 chars
D3/3: row 9 : 38 chars
D3/3: row 10 : 39 chars
D3/3: row 11 : 38 chars
D3/3: row 12 : 39 chars
D3/3: row 13 : 39 chars
D3/3: row 14 : 39 chars
D3/3: row 15 : 42 chars
D3/3: row 16 : 42 chars
D3/3: row 17 : 42 chars
D3/3: row 18 : 42 chars
D3/3: row 19 : 42 chars
D3/3: row 20 : 42 chars
D3/3: row 21 : 42 chars
D3/3: row 22 : 42 chars
D3/3: row 23 : 41 chars
D3/3: row 24 : 42 chars
D3/3: row 25 : 42 chars
D3/3: row 26 : 42 chars
D3/3: row 27 : 42 chars
D3/3: row 28 : 41 chars
D3/3: row 29 : 41 chars
D3/3: row 30 : 45 chars
D3/3: row 31 : 45 chars
D3/3: row 32 : 42 chars
D3/3: row 33 : 41 chars
D3/3: row 34 : 42 chars
D3/3: row 35 : 42 chars
D3/3: row 36 : 42 chars
D3/3: row 37 : 45 chars
D3/3: row 38 : 46 chars
D3/3: row 39 : 46 chars
D3/3: row 40 : 42 chars
D3/3: row 41 : 46 chars
D3/3: row 42 : 46 chars
D3/3: row 43 : 42 chars
D3/3: row 44 : 42 chars
D3/3: row 45 : 42 chars
D3/3: row 46 : 42 chars
D3/3: row 47 : 42 chars
D3/3: row 48 : 42 chars
D3/3: row 49 : 41 chars
D3/3: row 50 : 42 chars
D3/3: row 51 : 42 chars
D3/3: row 52 : 39 chars
D3/3: row 53 : 37 chars
D3/3: row 54 : 42 chars
D3/3: row 55 : 42 chars
D3/3: row 56 : 42 chars
D3/3: row 57 : 41 chars
D3/3: row 58 : 42 chars
D3/3: row 59 : 41 chars
D3/3: row 60 : 46 chars
D3/3: row 61 : 38 chars
D3/3: row 62 : 46 chars
D3/3: row 63 : 41 chars
D3/3: row 64 : 41 chars
D3/3: row 65 : 48 chars
D3/3: row 66 : 45 chars
D3/3: row 67 : 42 chars
D3/3: row 68 : 42 chars
D3/3: row 69 : 39 chars
D3/3: row 70 : 47 chars
D3/3: row 71 : 48 chars
Maximale Länge der Inputzeile: 49
Maximale Anzahl der Spalten: 4
Minimale Anzahl der Spalten: 4
D1/3: Vect_default_field_info(): map = vinascii_with_table
field = 1
vinascii_with_table, mapset = user1
[c:\OSGeo4W\apps\grass\grass-6.5.svn\driver\db\]
"c:\OSGeo4W\apps\grass\grass-6.5.svn\driver\db\dbf.exe"
Column: 4 type: string length: 13
D1/3: Vect_write_dblinks(): map = vinascii_with_table,
mapset = user1
/vinascii_with_table/dbln
D1/3: 1 vinascii_with_table cat
D3/3: create table vinascii_with_table ( cat integer, dbl_1
str_1 varchar(13) )
vinascii_with_table ( cat integer, dbl_1 double precision,
dbl_2 double precision, int_1 integer, str_1 varchar(13) )
D2/3: find_table(): table = vinascii_with_table
D2/3: ? helli
include/sqlp.h)
D2/3: add_table(): table = vinascii_with_table name =
vinascii_with_table.dbf
D2/3: ? helli
D2/3: ? vinascii_with_table
D3/3: add_column(): tab = 1, type = 2, name = cat, width =
11, decimals = 0
D3/3: add_column(): tab = 1, type = 3, name = dbl_1, width =
20, decimals = 6
D3/3: add_column(): tab = 1, type = 3, name = dbl_2, width =
20, decimals = 6
D3/3: add_column(): tab = 1, type = 2, name = int_1, width =
11, decimals = 0
D3/3: add_column(): tab = 1, type = 1, name = str_1, width =
13, decimals = 0
mapset = user1
mapset = user1
D3/3: Vect_write_line(): name = vinascii_with_table, format
= 0, level = 1
D3/3: insert into vinascii_with_table values ( 1,
620856.95858763, 230066.38313211, 1, 'Morrisville')
vinascii_with_table values ( 1, 620856.95858763,
D2/3: ? helli
D2/3: load_table_head(): tab = 1, C:\gisdata\grassdata/nc_sp
m_08/user1/dbf//vinascii_with_table.dbf
include/sqlp.h)
D2/3: load_table(): tab = 1
= 0, level = 1
D3/3: insert into vinascii_with_table values ( 2,
625331.91859749, 229990.82160763, 2, 'Morrisville')
vinascii_with_table values ( 2, 625331.91859749,
D2/3: ? helli
include/sqlp.h)
= 0, level = 1
D3/3: insert into vinascii_with_table values ( 3,
615797.66547487, 213363.99261983, 3, 'Apex')
vinascii_with_table values ( 3, 615797.66547487,
D2/3: ? helli
include/sqlp.h)
= 0, level = 1
D3/3: insert into vinascii_with_table values ( 4,
623113.71424165, 219859.06222161, 4, 'Apex')
vinascii_with_table values ( 4, 623113.71424165,
D2/3: ? helli
include/sqlp.h)
= 0, level = 1
D3/3: insert into vinascii_with_table values ( 5,
627926.28432081, 203208.6160536, 5, 'Fuquay-Varina')
vinascii_with_table values ( 5, 627926.28432081,
D2/3: ? helli
include/sqlp.h)
include/sqlp.h)
= 0, level = 1
D3/3: insert into vinascii_with_table values ( 68,
649833.80593756, 219907.29347997, 68, 'Raleigh')
vinascii_with_table values ( 68, 649833.80593756,
D2/3: ? helli
include/sqlp.h)
= 0, level = 1
D3/3: insert into vinascii_with_table values ( 69,
622136.90859827, 220306.42922513, 69, 'Apex')
vinascii_with_table values ( 69, 622136.90859827,
D2/3: ? helli
include/sqlp.h)
= 0, level = 1
D3/3: insert into vinascii_with_table values ( 70,
625889.8783814, 211478.01839282, 70, 'Holly Springs')
vinascii_with_table values ( 70, 625889.8783814,
D2/3: ? helli
include/sqlp.h)
= 0, level = 1
D3/3: insert into vinascii_with_table values ( 71,
623658.64334595, 209478.24330292, 71, 'Holly Springs')
vinascii_with_table values ( 71, 623658.64334595,
D2/3: ? helli
include/sqlp.h)
D2/3: save_table 0
D2/3: save_table 1
'C:\gisdata\grassdata/nc_spm_08/user1/.tmp/6460.dbf'
D2/3: Write 71 rows
Fülle Tabelle...
D2/3: db_close_database() result: 0 (0 means success)
D2/3: db_shutdown_driver() failed
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:6&gt;
      Cpu: x86-32 |
Comment(by hamish):
ok, thanks,
D2/3: Write 71 rows
Fülle Tabelle...
ok, from Luigi's tests we know it is DB backend independent, and from
Helmut's test we know it is the driver shutdown not the closing of the
database.
(could you run with "LANG=C v.in.ascii ..."? I can guess the meaning but
my deutsch is not as good as your english..)
in 6.5svn db_shutdown_driver() for WinGrass effectively boils down to:
#include <stdlib.h>
#include <process.h>
#include <grass/dbmi.h>
#include "macros.h"
   \brief Closedown the driver, and free the driver structure
   <b>Note:</b> the management of the memory for the driver structure
   probably should be handled differently.
   db_start_driver() could take a pointer to driver structure as
   an argument, instead of returning the pointer to allocated
   then there would be no hidden free required
   \param driver db driver
   \return status (?)
int db_shutdown_driver(dbDriver * driver)
     int status;
     db__set_protocol_fds(driver->send, driver->recv);
     DB_START_PROCEDURE_CALL(DB_PROC_SHUTDOWN_DRIVER);
     /* close the communication FILEs */
     fclose(driver->send);
     fclose(driver->recv);
     driver->send = NULL;
     driver->recv = NULL;
     /* wait for the driver to finish */
     status = -1;
     /* TODO: convert status to something like from wait? */
     _cwait(&status, driver->pid, WAIT_CHILD);
     driver->pid = 0;
     /* free the driver structure. THIS IS GOOFY */
     free(driver);
     return status;
but that's about all the help I can give,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:7&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:7 hamish]:
attributes.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:8&gt;
      Cpu: x86-32 |
Comment(by glynn):
The MSVCRT documentation for _cwait() says:
The value of procHandle passed to _cwait should be the value returned by
the call to the _spawn function that created the specified process.
Except, db_start_driver() no longer uses spawn(), it uses G_spawn_ex(),
which uses CreateProcess(). See r42651 (7.0) and r42654 (6.5).
You may need to back-port G_wait() (in lib/gis/spawn.c) from 7.0 and use
that. On Unix, it doesn't matter, as both approaches result in driver->pid
containing a pid_t corresponding to the child process.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1159#comment:9&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:9 glynn]:
by
My test mentioned above was in WinGrass65.
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1159#comment:10&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:10 hellik]:
to:
by
G_spawn_ex(), which uses CreateProcess(). See r42651 (7.0) and r42654
(6.5).
> Helmut
I've tested this now in a self built WinGrass7 (nc-sampledata)
v.out.ascii --verbose input=myfireg7@g7 layer=1
output=C:\wd\grassascii\firestation_ascii_point_g7.txt columns=CITY
format=point
and the a re-import with v.in.ascii
input=C:\wd\grassascii\firestation_ascii_point_g7.txt
output=vinasciig7withtable2
D2/3: Vect_open_new(): name = vinasciig7withtable2
D1/3: G_find_vector2(): name=vinasciig7withtable2 mapset=g7
D1/3: V1_open_new_nat(): name = vinasciig7withtable2
D1/3: write coor size (9850026457038848) to head
D2/3: coor body offset 17179869202
D1/3: Vect_open_sidx(): name = vinasciig7withtable2 mapset=
g7 mode = new
D3/3: region item: north: 228500
D3/3: region item: south: 215000
D3/3: region item: east: 645000
D3/3: region item: west: 630000
D3/3: region item: cols: 1500
D3/3: region item: rows: 1350
D3/3: region item: e-w resol: 10
D3/3: region item: n-s resol: 10
D3/3: region item: cols3: 1500
D3/3: region item: rows3: 1350
D3/3: region item: e-w resol3: 10
D3/3: region item: n-s resol3: 10
D1/3: Vect_default_field_info(): map = vinasciig7withtable2
field = 1
D2/3: drv = sqlite db =
$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db, map =
vinasciig7withtable2, mapset = g7
D3/3: -> C:\gisdata\grassdata/nc_spm_08/g7/sqlite.db
   drvname = sqlite, dbname =
D2/3: dbDbmscap(): opendir [C:\Program
Files\GRASS-70-SVN\driver\db\]
""C:\Program Files\GRASS-70-SVN\driver\db\sqlite.exe""
D3/3:
db_driver_open_database()
D3/3: name = 'C:\gisdata\grassdata/nc_spm_08/g7/sqlite.db'
D2/3: name2 = 'C:\gisdata\grassdata/nc_spm_08/g7/sqlite.db'
D3/3: execute: BEGIN
D3/3: Vect_check_dblink: field 1, name vinasciig7withtable2
D1/3: Vect_write_dblinks(): map = vinasciig7withtable2,
mapset = g7
D1/3: dbln file: C:\gisdata\grassdata/nc_spm_08/g7/vector/vi
nasciig7withtable2/dbln
D1/3: 1/vinasciig7withtable2|vinasciig7withtable2|cat|$GISDB
ASE/$LOCATION_NAME/$MAPSET/sqlite.db|sqlite
D3/3: create table vinasciig7withtable2 ( cat integer, dbl_1
str_1 varchar(13) )
D3/3: execute: create table vinasciig7withtable2 ( cat
integer, dbl_1 double precision, dbl_2 double precision,
D3/3: db__create_index()
D3/3: SQL: create unique index vinasciig7withtable2_cat on
vinasciig7withtable2 ( cat )
mapset = g7
mapset = g7
D3/3: Vect_write_line(): name = vinasciig7withtable2, format
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 1,
D3/3: execute: insert into vinasciig7withtable2 values ( 1,
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 2,
D3/3: execute: insert into vinasciig7withtable2 values ( 2,
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 3,
D3/3: execute: insert into vinasciig7withtable2 values ( 3,
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 4,
D3/3: execute: insert into vinasciig7withtable2 values ( 4,
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 5,
D3/3: execute: insert into vinasciig7withtable2 values ( 5,
D3/3: execute: insert into vinasciig7withtable2 values ( 67,
651050.34524882, 232036.68777768, 67, 'Raleigh')
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 68,
D3/3: execute: insert into vinasciig7withtable2 values ( 68,
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 69,
D3/3: execute: insert into vinasciig7withtable2 values ( 69,
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 70,
D3/3: execute: insert into vinasciig7withtable2 values ( 70,
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 71,
D3/3: execute: insert into vinasciig7withtable2 values ( 71,
D3/3: execute: COMMIT
D3/3: db_close_database()
Fülle Tabelle...
attributes.
also here again the following message about the dbmi-driver:
attributes.
'''BUT''' the ascii-vector-data (also the table-data) is imported, you can
add the imported data in the map display and are able to open the
attribute table in the attribute table manager.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:11&gt;
      Cpu: x86-32 |
Comment(by glynn):
This issue applies to all branches and to the 6.4.0 release. And to RC7;
RC6 was the last version to use _spawnl(). All later versions are likely
to be broken on Windows, where db_shutdown_driver() will report failure.
The driver itself should terminate correctly, but the client will believe
that it failed.
Of the many calls to db_shutdown_driver(), only one actually checks the
return code. That is the one in db_close_database_shutdown_driver(), which
will return DB_FAILED.
Of the many calls to db_close_database_shutdown_driver(), only one
actually checks the return code, and that one is in v.in.ascii.
The net result is that v.in.ascii terminates with a fatal error rather
than calling Vect_build() and Vect_close().
This can be "fixed" by removing the check of the return code. We should
actually fix db_shutdown_driver(), but in the meantime, we may as well get
v.in.ascii working (and why should v.in.ascii be any different to all of
the other modules?)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:12&gt;
#1159: v.in.ascii points import fails in WinGRASS-6.4.0-1
Priority: blocker | Milestone: 6.4.1
      Cpu: x86-32 |
Changes (by hamish):
  * priority: normal => blocker
Comment:
even
echo "10|10|abcd" | v.in.ascii out=test
fails for WinGrass (tested in 6.5svn). agree to disable the test while we
find a solution in the dev branches; suggest to replace the 6.4.0.exe
WinGrass installer link ASAP with a nightly build after that is done,
until we release 6.4.1 (which we should start planning for pretty soon).
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:13&gt;
      Cpu: x86-32 |
Comment(by hamish):
patch to replace G_fatal_error() with G_debug() message applied to 6.5svn
with r43550. please test..
is this failing in grass7 as well?
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:14&gt;
      Cpu: x86-32 |
Comment(by lponti):
Replying to [comment:14 hamish]:
6.5svn with r43550. please test..
> Hamish
Applied Glynn's patch
http://osgeo-org.1803224.n2.nabble.com/v-in-ascii-fails-with-long-text-
file-in-WinGRASS-6-4-0-1-tp5530779p5553622.html
to changeset 4359 releasebranch_6_4, compiled following instructions at
<http://trac.osgeo.org/grass/wiki/CompileOnWindows&gt;, and it works for the
your simple test (see
<http://trac.osgeo.org/grass/ticket/1159#comment:13&gt;\):
     GRASS 6.4> echo "10|10|abcd" | v.in.ascii out=test
     Maximum input row length: 11
     Column: 3 type: string length: 4
      100%
     Populating table...
     Building topology for vector map <test>...
     1 primitives registered
     1 vertices registered
     Building areas...
      100%
     0 areas built
     0 isles built
      100%
     Number of nodes: 1
     Number of points: 1
     Number of lines: 0
     Number of areas: 0
     Number of isles: 0
The point can be displayed, and the dbf table seems ok. Also works using a
longer sample text file I previously linked
     GRASS 6.4> v.in.ascii --overwrite input=Bloomday_Olive_11set10_Avg
     ATTENZIONE: Vector map <test_US_import> already exists and will be
                 overwritten
      100%
     Populating table...
     Building areas...
      100%
     0 areas built
     0 isles built
      100%
     Number of lines: 0
     Number of areas: 0
     Number of isles: 0
Related ticket 1158 <http://trac.osgeo.org/grass/ticket/1158&gt; seems to
persist:
input=C:/cygwin/home/andy/models_temp/Bloomd
                 overwritten
     ATTENZIONE: Unable to delete file
'C:\cygwin\home\andy/latlong/luigi/vector/test_US_import/hist'
     ERRORE: Unable to delete vector map <test_US_import>
Still not entirely clear to me which variable I am supposed to set in
order to get full English messages.
Thanks and regards,
Luigi
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:15&gt;
      Cpu: x86-32 |
Comment(by hamish):
Replying to [comment:15 lponti]:
> Applied Glynn's patch [...], compiled [...], and it works for the
> your simple test
> Also works using a longer sample text file I previously linked
great. will port to other branches ASAP
> set in order to get full English messages.
perhaps:
GRASS> LANG=C v.in.ascii ...
? (anyway the idea is to have it be understandable to as many people as
possible & be able to grep the code for the exact message text; if it's
only 98% english it's not a problem if those other conditions are met)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1159#comment:16&gt;
      Cpu: x86-32 |
Comment(by hamish):
r43550 backported to 6.4 in r43601. I don't see
db_close_database_shutdown_driver() in trunk so not applied there.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1159#comment:17&gt;
      Cpu: x86-32 |
Comment(by glynn):
Replying to [comment:17 hamish]:
> I don't see db_close_database_shutdown_driver() in trunk
http://trac.osgeo.org/grass/browser/grass/trunk/vector/v.in.ascii/main.c#L524
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:18&gt;
      Cpu: x86-32 |
Comment(by hamish):
eye be blind. louder version of debug message applied to trunk in r43610
so it is not forgotten.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:19&gt;
