#1163: wx wms import tool error
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: wxGUI | Version: svn-develbranch6
Keywords: wms | Platform: MSWindows XP
Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:6 hamish]:
> > Replying to hellik:
> > > AFAICT wget seems to be missing in the nightly WinGrass-build-
environment.
> > and the same seems to be with libxml2.dll
> that should be ok, you can ignore those. it automatically swaps over to
curl if wget isn't there, and it automatically swaps over to our own
parsing if xml2.exe isn't there. the only reason you see those messages is
because "which" on Windows is more noisy than in Gnu/Linux.
> if you think the "which: {wget|xml2}: unknown command" messages are a
big problem we can probably send them to /dev/null.
> Hamish
FYI what I have done to bring r.in.wms at least at msys-command-line of
the latest WinGrass65-nightly build to run:
(1) copied wget to C:\Program Files\GRASS-65-SVN\bin
(2) copied the content from C:\OSGeo4W\share\gdal to C:\Program
Files\GRASS-65-SVN\share\gdal
(3) in C:\Program Files\GRASS-65-SVN\bin there lives grass65svn,
dynamically created by the WinGrass-Installer and started by the icon
WinGrass65+msys, and I've set there GDAL_DATA (see down there):
#! /bin/sh
# File dynamically created by NSIS installer script;
# Written by Marco Pasetti;
# MODULE: GRASS Initialization
# AUTHOR(S): Justin Hickey - Thailand - jhickey@hpcc.nectec.or.th
# PURPOSE: The source file for this shell script is in
# lib/init/grass.src and is the grass startup script. It
# requires a source file because the definition of GISBASE
# is not known until compile time and is substituted from
the
# Makefile. Any command line options are passed to Init.sh.
# COPYRIGHT: (C) 2000-2010 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with
# for details.
# Modified by Marco Pasetti
# added the export PATH instruction to let GRASS work from
# the MSYS environment in the dynamic NSIS installation
trap "echo 'User break!' ; exit" 2 3 9 15
# Set the GISBASE variable
GISBASE="/C/Program Files/GRASS-65-SVN"
export GISBASE
# Set the PATH variable
PATH="$GISBASE/extrabin:$GISBASE/extralib:$PATH"
PATH="$GISBASE/tcl-tk/bin:$GISBASE/sqlite/bin:$GISBASE/gpsbabel:$PATH"
export PATH
# Set the PYTHONPATH variable
PYTHONPATH="$GISBASE/etc/python:$GISBASE/Python25:$PYTHONPATH"
export PYTHONPATH
PYTHONHOME="C:\Program Files\GRASS-65-SVN\Python25"
export PYTHONHOME
if [ -z "$GRASS_PYTHON" ] ; then
GRASS_PYTHON=python
export GRASS_PYTHON
fi
# Set the GRASS_PROJSHARE variable
GRASS_PROJSHARE="C:\Program Files\GRASS-65-SVN\proj"
export GRASS_PROJSHARE
GDAL_DATA="C:\Program Files\GRASS-65-SVN\share\gdal"
export GDAL_DATA
exec "$GISBASE/etc/Init.sh" "$@"
(4)and at least the example from the manpage for ''LANDSAT from OnEarth
server download'' is working in the WinGrass65-delivered msys-commandline
is working:
GRASS 6.5> r.in.wms layers=global_mosaic
mapserver=http://wms.jpl.nasa.gov/wms
.cgi output=wms_global_mosaic
Calculating tiles
Requesting 1 tiles.
Downloading tiles
file: could not find any magic files!
Downloading data
SYSTEM_WGETRC = c:/progra~1/wget/etc/wgetrc
syswgetrc = c:/progra~1/wget/etc/wgetrc
2010-09-19 14:13:01 URL:http://wms.jpl.nasa.gov/wms.cgi [932783] ->
"C:/gisdata
/grassdata/wms_download/wms_global_mosaic__0.geotiff" [1]
All tiles downloaded successfully
Creating output file that is 507P x 459L.
Processing input file
C:\gisdata\grassdata/wms_download/wms_global_mosaic__0.ge
otiff.
0...10...20...30...40...50...60...70...80...90...100 - done.
Rename raster <wms_global_mosaic_tile_0.alpha> to
<wms_global_mosaic.alpha>
Rename raster <wms_global_mosaic_tile_0.blue> to <wms_global_mosaic.blue>
Rename raster <wms_global_mosaic_tile_0.green> to
<wms_global_mosaic.green>
Rename raster <wms_global_mosaic_tile_0.red> to <wms_global_mosaic.red>
Building Color Image
Erstelle Farbtabelle für Ausgabe-Rasterkarte...
100%
Schreibe Rasterkarte <wms_global_mosaic>...
100%
r.composite komplett. Rasterkarte <wms_global_mosaic> erzeugt.
Written: wms_global_mosaic
so maybe share/gdal should also be included in the WinGrass-installer?
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1163#comment:7>
