#1164: newlines in sed scripts not portable for wingrass
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 6.4.1
Component: Default | Version: svn-develbranch6
Keywords: wingrass, sed | Platform: MSWindows XP
Cpu: x86-64 |
Comment(by glynn):
Replying to [comment:2 hamish]:
> > If you want to insert a literal newline, you're supposed to
> > use backslash-newline, i.e.:
> Only gotcha is that the sed expression needs 'single' quotes not
"double" ones to get that to work:
The sed expression requires backslash-newline. How to pass such an
expression to sed depends upon which shell (if any) you are using. With
bash, it's good practice to use single quotes unless you specifically need
> committed to 6.5svn r.in.wms with r43549, a couple of left-hand-side
s/// '\n's remain, will wait and see how those behave
A \n in the pattern is valid.
> (since sed is line by line I'm kinda surprised those would work at all
even when right-hand-side replacement was functional.. shrug).
sed commands work on the "pattern space". sed operates by reading each
line into the pattern space in turn. However, certain commands (e.g. G, N)
append data preceded by a literal newline to the pattern space; this is
one way that newlines can get into the pattern space (substitutions can
also introduce them).
A common sed idiom is "{;N;<commands>;P;D;}". N appends the next line to
the pattern space preceded by a newline, P prints everything up to the
first newline, D deletes everything up to the newline (and suppresses the
automatic reading of the next line). This allows <commands> to work on a
2-line "window", so you can e.g. use "s" commands to match phrases which
might be split over two lines.
> I guess the right hand side was working before because it was using
"double" quotes and the shell was doing the newline replacement, not sed.
Sort of like "echo -e" without asking for it..
No, bash itself doesn't interpret \n as a newline. Without quotes, \n will
evaluate to just n. With single or double quotes, it will evaluate to \n.
It appears that some versions of GNU sed interpret a \n in the replacement
as a newline, contrary to the documentation and the standard (and they do
this even with --posix).
FWIW, sed 4.2 on Linux interprets \n, sed 3.02 on Windows doesn't. I
suspect that it may be a case of Linux systems typically having newer
versions of sed than MSys.
Hang on; the current sed manual says this, under "Reporting Bugs":
Here are a few commonly reported bugs that are not bugs.
Regex syntax clashes (problems with backslashes)
In addition, this version of sed supports several escape characters (some
of which are multi-character) to insert non-printable characters in
scripts (\a, \c, \d, \o, \r, \t, \v, \x). These can cause similar problems
with scripts written for other seds.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1164#comment:3>
