[GRASS-dev] [GRASS GIS] #1166: r.tileset: projection string munching on wingrass
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Default | Version: svn-develbranch6
Keywords: r.tileset, wingrass | Platform: MSWindows XP
      Cpu: x86-64 |
while running r.in.wms at the MSys prompt on WinGrass with the NASA
OnEarth Landsat man page example, the r.tileset part does some weird
things to the +proj4 strings.
to see them, you need to add some debug messages to the r.tileset script,
line ~233:
         g.message -i message="[$p_source_proj]"
         g.message -i message="[$p_dest_proj]"
also I changed "message 3 ... $CS2CS" just above that to "g.message -i
message=..." so the cs2cs command line would show up.
the weirdness displayed by that g.message is:
echo "589980.0 4913700.0" | cs2cs -f "\.8\f" '+proj=utm' '+zone=13'
'+a=6378206.4' '+rf=294.9786982' '+no_defs'
'+nadgrids=c;C:\PROGRA~1\GRASS-~1\msys\Program
Files\GRASS-65-SVN\etc\nad\conus' '+to_meter=1.0' +to +init=epsg;4326
namely "+nadgrids=c;C:\PROGRA~1\..." starting with "c;" and
"+init=epsg:4326" becoming "+init=epsg;4326" (with an ';' instead of a
`g.proj -j` by itself looks fine.
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1166&gt;
      Cpu: x86-64 |
Comment(by hamish):
quite strange, maybe related to the g.message "%.8f" bug? (#1162)
GRASS 6.5> g.proj -j
+proj=utm
+zone=13
+a=6378206.4
+rf=294.9786982
+no_defs
+nadgrids=c:/Program Files/GRASS-65-SVN/etc/nad/conus
+to_meter=1.0
GRASS 6.5> g.message message="`g.proj -j`"
+proj=utm
+zone=13
+a=6378206.4
+rf=294.9786982
+no_defs
+to_meter=1.0
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1166#comment:1&gt;
      Cpu: x86-64 |
Comment(by hamish):
simplified even further:
GRASS 6.5> g.message "+c:"
+c:
GRASS 6.5> g.message "+c:/"
+c;C:\PROGRA~1\GRASS-~1\msys
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1166#comment:2&gt;
      Cpu: x86-64 |
Comment(by hamish):
GRASS 6.5> g.message ":/"
GRASS 6.5> g.message "/"
C:/PROGRA~1/GRASS-~1/msys
Ticket URL: <https://trac.osgeo.org/grass/ticket/1166#comment:3&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [ticket:1166 hamish]:
> Hi,
script, line ~233:
> thanks,
> Hamish
I don't know if it's related to this (maybe worth for an extra ticket?).
in the osgeo4w-stack there are in C:\OSGeo4W\share following folder with a
lot projection informations:
C:\OSGeo4W\share\epsg_csv
C:\OSGeo4W\share\gdal
C:\OSGeo4W\share\proj
but only the proj-folder-content is included in WinGrass-installer.
I've tested r.in.wms in WinGrass64 and r.in.gdalwarp/gdalwarp couldn't
find the needed gcs.csv etc. files.
Should the other folders also be included in the WinGrass-Installer?
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1166#comment:4&gt;
      Cpu: x86-64 |
Comment(by hamish):
Replying to [comment:4 hellik]:
> couldn't find the needed gcs.csv etc. files.
fwiw, r.in.wms is known to be partly not working in 6.4.0 wingrass, pls
use latest 6.5svn for testing that.
also gdalwarp will fail if the target SRS contains a NTv2 +nadgrids file
path with a space in it. No known solution (see thread on PROJ4 mailing
list).
The Location wizard seems to be able to find the share/epsg file, so some
of the support files must be getting copied...
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1166#comment:5&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:5 hamish]:
see also http://trac.osgeo.org/grass/ticket/1163#comment:7
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1166#comment:6&gt;
      Cpu: x86-64 |
Comment(by glynn):
Replying to [comment:3 hamish]:
MSys converts any argument which "looks like" a filename to Windows syntax
when executing any command outside of the MSys "filesystem". The "mkpath"
command in Rules.make (in 7.0) relies upon this (via tools/g.echo) to
construct a valid PYTHONPATH.
This "feature" is one reason why shell scripts will never be robust on
Windows. Any shell aiming for Unix-compatibility can't use native Windows
filenames due to the use of ":" in *PATH variables, but Windows programs
won't understand whatever Unix-style filenames it uses, so it has to
perform translation. Which falls down when something which looks like a
filename isn't one (and also when it needs to translate but doesn't; e.g.
when Init.sh writes $GISDBASE into $GISRC, it doesn't get translated).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1166#comment:7&gt;
      Cpu: x86-64 |
Comment(by hamish):
fortunately
r.mapcalc "sum / count"
doesn't get expanded, only when `:` or nothing precedes the `/`. perhaps
there are other string combinations that trigger it off.
hmm, I wonder about "`( a ? b : c ) / d`" style r.mapcalc expressions..?
... surely the MSys people would have added some enivro variable which
would let you temporarily turn this behaviour off ... (one would hope)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1166#comment:8&gt;
      Cpu: x86-64 |
Comment(by glynn):
Replying to [comment:8 hamish]:
> fortunately
That's because "sum / count" (which is a single "word" because of the
quotes) doesn't "look like" a filename. If you omit the quotes (which
should work in 6.x, not in 7.0):
~ $ args r.mapcalc sum / count
argv[ 0] = 'C:\msys\1.0\local\bin\args.exe'
argv[ 1] = 'r.mapcalc'
argv[ 2] = 'sum'
argv[ 3] = 'C:/msys/1.0'
argv[ 4] = 'count'
Ticket URL: <https://trac.osgeo.org/grass/ticket/1166#comment:9&gt;
      Cpu: x86-64 |
Comment(by hamish):
m.proj is another one that fails.. wingrass 6.5svn daily build from the
last day or two, Windows XP Pro from MSys's rxvt, in the spearfish
dataset:
GRASS 6.5> export PROJ_DEBUG=5
GRASS 6.5> echo "-103.75|44.5" | m.proj -i
input parameters=[+proj=longlat +datum=WGS84]
output parameters=[ '+proj=utm' '+zone=13' '+a=6378206.4'
'+rf=294.9786982'
'+no_defs' '+nadgrids=c;C:\PROGRA~1\GRASS-~1\msys\Program
Files\GRASS-65-SVN\etc\nad\conus' '+to_meter=1.0']
* * 0.00
pj_open_lib(proj_def.dat): call fopen(C:\Program
Files\GRASS-65-SVN\proj\proj_def.dat) - succeeded
pj_open_lib(c;C:\PROGRA~1\GRASS-~1\msys\Program
Files\GRASS-65-SVN\etc\nad\conus):
Files\GRASS-65-SVN\proj\c;C:\PROGRA~1\GRASS-~1\msys\Program
Files\GRASS-65-SVN\etc\nad\conus) - failed
Rel. 4.7.1, 23 September 2009
<cs2cs.exe>: while processing file: <stdin>, line 1
pj_transform(): Unknown error
this time it's the path name that's getting munched, or otherwise mangled.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1166#comment:10&gt;
Priority: major | Milestone: 6.4.3
Keywords: r.tileset, wingrass, msys | Platform: MSWindows XP
      Cpu: x86-64 |
Changes (by hamish):
  * keywords: r.tileset, wingrass => r.tileset, wingrass, msys
  * priority: normal => major
  * milestone: 6.4.1 => 6.4.3
Ticket URL: <https://trac.osgeo.org/grass/ticket/1166#comment:11&gt;
Priority: major | Milestone: 6.4.4
Component: Packaging | Version: svn-develbranch6
      Cpu: x86-64 |
  * component: Default => Packaging
  * milestone: 6.4.3 => 6.4.4
Comment:
still an issue from the msys bash prompt in latest nightly builds.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1166#comment:12&gt;
