[GRASS-dev] [GRASS GIS] #117: r.digit fails if launched from menu
Reporter: 4everskiff | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.3.0
Component: default | Version: 6.3.0 RCs
Keywords: |
Tested on WinGRASS-6.3.0RC6
There's an error in the following menu command:
Raster -> Develop map -> Digitize raster
while r.digit works fine if launched from command line (both pure command
line and Run GUI command option)
error log reported in attached file
Ticket URL: <http://trac.osgeo.org/grass/ticket/117&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
Resolution: | Keywords:
Comment (by marisn):
There are some small bugfixes pending in Michael's patch list. After
commiting, they have to be backported to 6.3.0. Still with trunk there's
an issue, that guarantee_xmon doesn't work anymore.
Ticket URL: <http://trac.osgeo.org/grass/ticket/117#comment:1&gt;
Comment (by hamish):
is xterm installed?
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/117#comment:2&gt;
If you have no xterm, you might try putting something like this in
~/.grass.bashrc
(if you have rxvt...)
export GRASS_XTERM=rxvt
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/117#comment:3&gt;
I changed grass-xterm-wrapper to automatically look for rxvt if xterm is
not there (r30863)*, but I have zero idea at all how grass-xterm-wrapper
should be handled for native MS Windows installs (but guarantee-xmon is
useless there anyway, as there is no xmons, so don't bother?).
[*] add others as needed (eterm?). I added only rxvt because that's all I
use; xterm is no longer installed by default on Debian.
note r.digit is just a simple front end to r.in.poly, which uses an ascii
format very similar to v.in.ascii's format=standard. Thus creating a new
wxPython raster digitizer to replace the old r.digit should not be /that/
much work.
IMO using r.in.poly is a slightly better approach than v.digit+v.to.rast,
although the latter happening for the backend wouldn't be so bad if it
could be automated.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/117#comment:4&gt;
command line
r.digit works fine if launched from the WinGRASS command line?! This isn't
Cygwin, right?
H
Ticket URL: <http://trac.osgeo.org/grass/ticket/117#comment:5&gt;
You can use "start" to run a command in a new console window.
You need to consume all of the switches up to and including -e, e.g.:
  #!/bin/sh
  # xterm "emulator" for Windows
  while [ "$1" != "-e" ] ; do shift ; done
  shift
  exec start "$@"
There are presumably other cases which use grass-xterm-wrapper, but
it wouldn't surprise me if every one of them did something which
wouldn't work on Windows.
Comment (by 4everskiff):
Replying to [comment:5 hamish]:
isn't Cygwin, right?
Yes, this is WinGRASS (Native Windows Binary) and r.digit works fine if
started from command line (output window, both Run and RunGUI options).
Current WinGRASS release contains rxvt as standard.
Marco Pasetti
Ticket URL: <http://trac.osgeo.org/grass/ticket/117#comment:6&gt;
Hamish:
Marco:
started
> from command line
You can really digitize then view a map created with it? As far as I knew
r.digit needed an interactive xmon window, which is only available if
using X11. It should fail with a "no monitor found" error *after* you give
it a map name.
Perhaps something changed, but this surprises me.
I have backported grass-xterm-wrapper to the 6.3.0 branch, but I hope
others can add more xterm compatible terms to the list as needed.
see also previous discussion:
   http://thread.gmane.org/gmane.comp.gis.grass.devel/14702
   http://thread.gmane.org/gmane.comp.gis.grass.devel/24109
re r20925, I assume that the various distro's x-terminal-emulator wrappers
have gotten their act together re gnome-terminal since last time we tried.
It works for me on debian (points to /usr/bin/gnome-terminal.wrapper which
translates command line options); could Ubuntu users please re-test to see
if r.digit now works from the gis.m menu? (that's where the earlier
problems were reported)
I don't like changing this so late in the RC cycle, but hopefully it helps
more than it harms.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/117#comment:7&gt;
Hamish:
Marco:
started
> from command line
it a map name.
Yep. It uses the R_get_location_with_* functions, so it won't work
without an X monitor.
Replying to [comment:7 hamish]:
Hi Hamish. Sorry, you're right! I was going to open another ticket, while
I realized that it was related to the same problem of that one. In fact,
for both r.digit and v.digit, the command GUI opens, but the tool panel
don't; that means that it's impossible to actually digitize both rasters
and vectors.
What should we do? leave this ticket opened, or close it and add a new
ticket reporting that r.digit and v.digit don't work?
Marco
Ticket URL: <http://trac.osgeo.org/grass/ticket/117#comment:8&gt;
Component: Tcl | Version: 6.3.0 RCs
Changes (by martinl):
  * component: default => Tcl
Ticket URL: <http://trac.osgeo.org/grass/ticket/117#comment:9&gt;
#117: r.digit: make guarantee_xmon fail nicely on WinGrass
  Priority: minor | Milestone: 6.3.0
Changes (by hamish):
  * priority: major => minor
  * summary: r.digit fails if launched from menu => r.digit: make
Comment:
AFAIK the Tcl version of v.digit works fine on native WinGrass, it's only
menu items which call guarantee_xmon that won't work. Those are:
r.digit
r.le.setup
d.path.sh
i.ortho.photo
d.nviz
I have just modified guarantee_xmon in svn (r30966) to fail in a nicer way
if there are no xmons*. It should really return with an error code, and
menu items that call it should act like "guarantee_xmon && d.module" (I've
no idea how to do that in tcl)
[*] the error message is perhaps misleading if the user has 8 xmons
already running, so no free ones. Feel free to improve it.
nicer would be if those menu items were greyed out for WinGrass. again
I've little clue how to do that in Tcl, but this is the shell code version
that could be run at gui startup time before building the menus:
if [ `d.mon -L | grep -c '^x[0-9]'` -lt 1 ] ; then
   HAVE_XMON=0
else
   HAVE_XMON=1
fi
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/117#comment:10&gt;
  Priority: minor | Milestone: 6.4.0
Changes (by neteler):
  * milestone: 6.3.0 => 6.4.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/117#comment:11&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by cmbarton):
  * status: new => closed
* cc: hamish_b@yahoo.com (added)
  * resolution: => fixed
Comment:
I just committed a fix to this, but can't test it on my Mac. At least it
doesn't do any harm on a Mac.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/117#comment:12&gt;
Changes (by marcopx):
  * version: 6.3.0 RCs => 6.3.0
Comment:
Replying to [comment:12 cmbarton]:
> Michael
Hi Michael,
I'll test it as soon as possible. Is it on SVN GRASS trunk?
BTW, the problem is that r.digit doesn't work on windows. Should we really
leave the ticket closed? we probably should open a new ticket, such as:
WinGRASS: r.digit doesn't work
Marco
PS: I created a new OSGEOID, the previous 4everskiff was not actually
appropriate :slight_smile:
Starting from now I will always use the marcopx ID, as in IRC
Ticket URL: <http://trac.osgeo.org/grass/ticket/117#comment:13&gt;
Comment (by martinl):
Replying to [comment:13 marcopx]:
it was committed to 'develbranch_6', see
r31350
'trunk' is dedicated for grass7 demolition, for main development (leading
to 6.4.0) is used 'develbranch_6'
I cannot judge if this fix should be also committed to 'trunk'...
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/117#comment:14&gt;
Marco,
I put this in the development GRASS 6 branch, which is where I think we are
supposed to be working on GUI development at the present--especially for
TclTk--and which will morph into GRASS 6.4.
To be more accurate, it is not that r.digit doesn't work, it is that ANY
command that requires an interactive Xmonitor doesn't work--and won't work
on Windows AFAICT. With TclTk now giving a meaningful message whenever
someone tries to run such a command from the GUI, the TclTk ticket should be
closed.
The other issue, about requiring interactive should indeed be maintained as
an enhancement ticket for GRASS 6.4 and 7. But this will require changes to
the relevent modules' C code. That is, it is not an issue that can be fixed
in the GUI at present.
Michael
Comment:
Michael
Hi Michael,
Marco
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
