#1171: wingrass: include a gpsbabel with XML support
Reporter: hamish | Owner: grass-dev@…
Priority: normal | Milestone: 6.4.1
Component: Packaging | Version: svn-develbranch6
Keywords: gpsbabel, wingrass | Platform: MSWindows XP
Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:3 hamish]:
> see libexpat.dll discussion in:
> https://trac.osgeo.org/osgeo4w/ticket/59
> https://trac.osgeo.org/osgeo4w/ticket/171
> > "there is already a copy of that in osgeo4w/bin/"
> if so, can we copy it over to GRASS-64-SVN/extralib/ ?
> or is the error message accurate and it needs to be found at build-time
to work?
> Hamish
just a little test:
- I've re-installed gpsbabel by the osgeo4w-setup/installer
- gpsbabel.exe lives in c:\osgeo4w/bin with following properties:
C:\wd\mg>gpsbabel --version
GPSBabel Version 1.4.1. http://www.gpsbabel.org
20.07.2010 20:29 845.824 GPSBabel.exe
Usage:
gpsbabel [options] -i INTYPE -f INFILE [filter] -o OUTTYPE -F OUTFILE
gpsbabel [options] -i INTYPE -o OUTTYPE INFILE [filter] OUTFILE
Converts GPS route and waypoint data from one format type to another.
The input type and filename are specified with the -i INTYPE
and -f INFILE options. The output type and filename are specified
with the -o OUTTYPE and -F OUTFILE options.
If '-' is used for INFILE or OUTFILE, stdin or stdout will be used.
In the second form of the command, INFILE and OUTFILE are the
first and second positional (non-option) arguments.
INTYPE and OUTTYPE must be one of the supported file types and
may include options valid for that file type. For example:
'gpx', 'gpx,snlen=10' and 'ozi,snlen=10,snwhite=1'
(without the quotes) are all valid file type specifications.
Options:
-p Preferences file (gpsbabel.ini)
-s Synthesize shortnames
-r Process route information
-t Process track information
-T Process realtime tracking information
-w Process waypoint information [default]
-b Process command file (batch mode)
-c Character set for next operation
-N No smart icons on output
-x filtername Invoke filter (placed between inputs and output)
-D level Set debug level [0]
-l Print GPSBabel builtin character sets and exit
-h, -? Print detailed help and exit
-V Print GPSBabel version and exit
File Types (-i and -o options):
gdb Garmin MapSource - gdb
cat Default category on output (1..16)
bitscategory Bitmap of categories
ver Version of gdb file to generate (1..3)
via (0/1) Drop route points that do not have
an equivalent w
roadbook (0/1) Include major turn points (with
description) from
mapsource Garmin MapSource - mps
snlen Length of generated shortnames
snwhite (0/1) Allow whitespace synth. shortnames
mpsverout Version of mapsource file to generate
(3,4,5)
mpsmergeout (0/1) Merge output with existing file
mpsusedepth (0/1) Use depth values on output (default
is ignore)
mpsuseprox (0/1) Use proximity values on output
(default is ignore)
pcx Garmin PCX5
deficon Default icon name
cartoexploreur (0/1) Write tracks compatible with Carto
Exploreur
garmin Garmin serial/USB protocol
get_posn (0/1) Return current position as a
waypoint
power_off (0/1) Command unit to power itself down
resettime (0/1) Sync GPS time to computer time
category Category number to use for written
waypoints
gtrnctr Garmin Training Center
course (0/1) Write course rather than history,
default yes
sport Sport: Biking (deflt), Running,
MultiSport, Other
geo Geocaching.com .loc
nuke_placer (0/1) Omit Placer name
kml Google Earth (Keyhole) Markup Language
lines (0/1) Export linestrings for tracks and
routes
points (0/1) Export placemarks for tracks and
routes
line_width Width of lines, in pixels
line_color Line color, specified in hex AABBGGRR
floating (0/1) Altitudes are absolute and not
clamped to ground
extrude (0/1) Draw extrusion line from trackpoint
to ground
track (0/1) Write KML track (default = 0)
trackdata (0/1) Include extended data for
trackpoints (default = 1
trackdirection (0/1) Indicate direction of travel in
track icons (defau
units Units used when writing comments
('s'tatute or 'm'
labels (0/1) Display labels on track and
routepoints (default
max_position_point Retain at most this number of position
points (0
gpx GPX XML
suppresswhite (0/1) No whitespace in generated
shortnames
logpoint (0/1) Create waypoints from geocache log
entries
urlbase Base URL for link tag in output
gpxver Target GPX version for output
humminbirdextensio (0/1) Add info (depth) as Humminbird
extension
garminextensions (0/1) Add info (depth) as Garmin extension
vpl Honda/Acura Navigation System VP Log File
Format
mapsend Magellan Mapsend
trkver MapSend version TRK file to generate (3,4)
magellanx Magellan SD files (as for eXplorist)
maxcmts Max number of comments to write
(maxcmts=200)
magellan Magellan SD files (as for Meridian)
(maxcmts=200)
magellan Magellan serial protocol
(maxcmts=200)
baud Numeric value of bitrate (baud=4800)
noack (0/1) Suppress use of handshaking in name
of speed
nukewpt (0/1) Delete all waypoints
nmea NMEA 0183 sentences
snlen Max length of waypoint name to write
gprmc (0/1) Read/write GPRMC sentences
gpgga (0/1) Read/write GPGGA sentences
gpvtg (0/1) Read/write GPVTG sentences
gpgsa (0/1) Read/write GPGSA sentences
date Complete date-free tracks with given date
(YYYYMMD
waypoint
pause Decimal seconds to pause between groups of
strings
append_positioning (0/1) Append realtime positioning data to
the output fil
baud Speed in bits per second of serial port
(baud=4800
gisteq (0/1) Write tracks for Gisteq Phototracker
ozi OziExplorer
pack (0/1) Write all tracks into one file
snlen Max synthesized shortname length
snupper (0/1) UPPERCASE synth. shortnames
snunique (0/1) Make synth. shortnames unique
wptfgcolor Waypoint foreground color
wptbgcolor Waypoint background color
proximity Proximity distance
altunit Unit used in altitude values
proxunit Unit used in proximity values
wbt Wintec WBT-100/200 GPS Download
erase (0/1) Erase device data after download
Supported data filters:
- and a little test with a small gpx-file of a garmin-gps:
C:\wd\mg>gpsbabel -i gpx -f ask_bayern_ll_wgs84.gpx -o gpx -F
testgpsbabel.gpx
GPX: This build excluded GPX support because expat was not installed.
so it seems that Jürgen's updated version didn't find its way to the
officinal osgeo4w-stack?
and see a message in the osgeo4w-ML:
http://lists.osgeo.org/pipermail/osgeo4w-dev/2010-September/001062.html
... of putting a copy on osgeo4w that very likely is going to get out of
date.
what would be the best way to get this working for the WinGrass-builds and
WinGrass-build-environment?
replacing osgeo4w's gpsbabel with a copy of
http://www.gpsbabel.org/download.html?
IMHO gps-data is nowadays a very important data source which should be
imported as default to any gis-software.
best regards
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1171#comment:4>
