#1173: v.surf.rst: bug in handling Output deviations vector point file
Reporter: mmetz | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Vector | Version: svn-releasebranch64
Keywords: vector, rst library | Platform: All
Cpu: All |
The output deviations vector file name is passed as char* to
IL_init_params_2d() in the rst library which is a bug:
main.c: In function ‘main’:
main.c:686: warning: passing argument 41 of ‘IL_init_params_2d’ from
incompatible pointer type
/home/markus/src/grass-6.4.svn/dist.i686-pc-linux-
gnu/include/grass/interpf.h:82: note: expected ‘struct FILE *’ but
argument is of type ‘char *’
Applies to all branches.
A possible solution could be to change IL_init_params_2d and make argument
number 41 a char* because the vector deviation points file has already
been created by v.surf.rst when IL_init_params_2d is called, so FILE * is
not an option.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1173>
