#1184: "d.vect display=attr" imply grass open process but doesn't close them.
Reporter: met | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.1
Component: Display | Version: 6.4.0
Keywords: display=attr | Platform: MSWindows XP
Cpu: Unspecified |
Using version 6.4.0 or 6.4.0 RC7 the defect shows up, instead of RC6
in which not, operative system Windows XP professional.
When you are using a PAN or ZOOM command, or simply adding a layers,
(looking from windows taskmanager)map display start a "cmd.exe" process.
This process disappear after few seconds but if the option display=attr is
active, doesn't shut down properly:
-at every zoom/pan on map the Map display open a new cmd.exe process that
will never be closed.
-this trend (adding process) go ahead until the Grass doesn't work and
stop following comand .
-even closing Grass before or after its block those process don't
disappear.
-the only way in which a user could shut down those process is the windows
task manager.
example:
'' d.vect map=reteF display=shape,attr
> type=point,area,centroid attrcol='id' ''
Ticket URL: <http://trac.osgeo.org/grass/ticket/1184>
