[GRASS-dev] [GRASS GIS] #1185: v.in.ogr on WinGrass: "Bad file descriptor"
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Vector | Version: unspecified
Keywords: v.in.ogr, wingrass | Platform: MSWindows XP
      Cpu: Unspecified |
Hi, this was posted to the wiki by "JeeJah".
Not tested, no other idea about it. version and binary build unknown. But
it warrants looking into..
When importing an ESRI shapefile using the v.in.ogr
command the following error may occur:
[Bad file descriptor: Files]
The output vector file is created but GRASS is "unable
to open the vector map."
Sample dialog:
[v.in.ogr dsn=D:\acadia\Skyland\ortho\G_Ortho_Index.shp \
   output=orthoindex01
Projection of input dataset and current location appear to match
Layer: G_Ortho_Index
Please note that the data are left in incosistent stage
and can be corrupted (Thu Sep 30 14:15:16 2010) Command
  aborted (20 sec)]
Solution:
HB: It seems you found a bug: "C:\Program" got sent as the first argument,
and the second half, "Files\GRASS-64\..." was sent as the second argument.
Somewhere some path variable is not quoted correctly to protect against
spaces in pathnames.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1185&gt;
      Cpu: Unspecified |
Comment(by hellik):
Replying to [ticket:1185 hamish]:
But it warrants looking into..
> Sample dialog:
> output=orthoindex01
> aborted (20 sec)]
> Solution:
argument, and the second half, "Files\GRASS-64\..." was sent as the second
argument. Somewhere some path variable is not quoted correctly to protect
against spaces in pathnames.
test with the actual WinGrass64-release (installed in c:\Program
Files\...):
v.in.ogr --verbose dsn=C:\wd\gextension\firestations.shp
output=testvimport
Die Projektionsinformationen des Eingabedatensatzes und der aktuellen
Location scheinen übereinzustimmen.
Layer: firestations
Spaltenname wurde geändert: 'cat' -> 'cat_'
Importiere 71 Objekte der Karte...
Erstelle Topologie für die Vektorkarte <testvimport>...
Registriere Primitive...
71 Primitive registriert
71 Vertices registriert
Erzeuge Flächen...
0 Flächen angelegt
0 Inseln angelegt
Füge Inseln hinzu...
Füge Zentroide hinzu...
Die Topologie wurde erstellt
Anzahl der Knoten: 71
Anzahl der Primitive: 71
Anzahl der Punkte: 71
Anzahl der Linien: 0
Anzahl der Grenzen: 0
Anzahl der Zentroide: 0
Anzahl der Flächen: 0
Anzahl der Inseln: 0
(Fri Oct 01 20:08:31 2010) Command finished (0 sec)
it works. I would vote for closing the ticket.
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1185#comment:1&gt;
      Type: defect | Status: closed
Resolution: invalid | Keywords: v.in.ogr, wingrass
  Platform: MSWindows XP | Cpu: Unspecified
Changes (by hamish):
  * status: new => closed
  * resolution: => invalid
Ticket URL: <https://trac.osgeo.org/grass/ticket/1185#comment:2&gt;
