[GRASS-dev] [GRASS GIS] #1186: WinGrass7 - v.krige not working
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Component: Vector | Version: svn-trunk
Keywords: wingrass, v.krige | Platform: MSWindows Vista
      Cpu: x86-32 |
tested with WinGRASS-7.0.SVN-r43746-1-Setup.exe
(1) v.krige in "''Raster -> Interpolate Surface -> Ordinary or block
kriging''" is greyed out
(2)v.krige-wx-gui from the wx-command-line is starting, but following
error message if selecting the vector data
   File "C:\Program Files\GRASS-70-SVN\etc\gui\wxpython\gui_m
odules\menuform.py", line 1797, in OnUpdateDialog
fn(**kwargs)
   File "c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
mingw32/etc/gui/wxpython/gui_modules/gselect.py", line 722,
in InsertColumns
TypeError
int() argument must be a string or a number, not 'NoneType'
there seems to be a hangover from the building environment.
after fill in all requirements for v.krige, there are following errors:
v.krige.py --verbose input=vrandomp@g7 column=zvalue output=testrastout
model=Exp block=4 range=7 nugget=6 sill=7 output_var=testrastvarout
Loading packages, please wait...
Processing 2025000 cells. Computing time raises
exponentially with
resolution.
Importing data...
Lade nötiges Paket: sp
Lade nötiges Paket: rgdal
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.7.1, released 2010/02/08
Path to GDAL shared files: C:/PROGRA~1/R/R-211~1.1/library/rgdal/gdal
Loaded PROJ.4 runtime: Rel. 4.7.1, 23 September 2009
Path to PROJ.4 shared files: C:/PROGRA~1/R/R-211~1.1/library/rgdal/proj
Lade nötiges Paket: XML
GRASS GIS interface loaded with GRASS version: 7.0.svn
and location: nc_spm_08
Lade nötiges Paket: foreign
Lade nötiges Paket: lattice
         Note: polygon geometry computations in maptools
         depend on the package gpclib, which has a
         restricted licence. It is disabled by default;
         to enable gpclib, type gpclibPermit()
Checking rgeos availability as gpclib substitute:
FALSE
Command: v.info
Extension: .exe
Description: Outputs basic information about a vector map.
Keywords: Vektor, metadata, history
Parameters:
   name: map, type: string, required: yes, multiple: no
   keydesc: name, keydesc_count: 1
[Data source for OGR access]
   name: layer, type: string, required: yes, multiple: no
[A single vector map can be connected to multiple database tables. This
number determines which table to use. Layer name for OGR access.]
Flags:
   name: h [Gebe den Werdegang anstelle einer Info aus.]
   name: c [Gebe Typ/Name der Tabellenspalten bestimmter Layer anstatt der
Info aus.]
   name: g [Gebe nur die Region der Rasterkarte aus.]
   name: m [Gebe nur den Titel der Rasterkarte aus.]
   name: t [Gebe nur Informationen zur Topologie aus.]
   name: verbose [Detaillierter Ausgabemodus]
   name: quiet [Schweigsamer Ausgabemodus]
Fehler in doGRASS(cmd, flags = flags, parameters = parameters) :
   Missing required parameter: layer
   File "C:\Program Files\GRASS-70-SVN\scripts\v.krige.py",
line 419, in <module>
     sys.exit(main(argv = grass.parser()))
line 386, in main
     logger = grass)
line 261, in Run
     globals()["InputData"] = self.ImportMap(input, column)
line 150, in ImportMap
     Rpointmap = robjects.r.readVECT6(map, type = 'point')
   File "C:\Program Files\GRASS-70-SVN\Python25\lib\site-
packages\rpy2\robjects\__init__.py", line 422, in __call__
     res = super(RFunction, self).__call__(*new_args,
**new_kwargs)
rinterface.RRuntimeError: Fehler in doGRASS(cmd, flags =
(Fri Oct 01 23:28:48 2010) Command finished (6 sec)
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1186&gt;
Reporter: hellik | Owner: aghisla
     Type: defect | Status: assigned
      Cpu: x86-32 |
Changes (by neteler):
* cc: grass-dev@… (added)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1186#comment:6&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords: wingrass, v.krige
  Platform: MSWindows Vista | Cpu: x86-32
Changes (by aghisla):
  * status: assigned => closed
  * resolution: => wontfix
Comment:
Closing this bug for the moment, as v.krige is temporarily removed from
compilation and is under major refactoring.
Development discussion is now available here:
http://trac.osgeo.org/grass/wiki/wxGUIDevelopment/vkrige
Feel free to open tickets for the upcoming version of v.krige, when it
will be published.
Anne
Ticket URL: <http://trac.osgeo.org/grass/ticket/1186#comment:7&gt;
