[GRASS-dev] [GRASS GIS] #1191: make install gives sed error in r43810
Reporter: cgsbob | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Installation | Version: svn-develbranch6
Keywords: | Platform: Linux
      Cpu: x86-64 |
I was able to compiling r43810, but when I did a make install, I noticed
this error:
sed -i -e 's#/tools/g.html2man/g.html2man/tools/g.html2man#'
/home/bob/apps/grass-6.5.svn/include/Make/Man.make
sed: -e expression #1, char 48: unterminated `s' command
make[1]: [real-install] Error 1 (ignored)
It appears that the install process did not abort
Ticket URL: <http://trac.osgeo.org/grass/ticket/1191&gt;
Keywords: Makefile | Platform: Linux
      Cpu: x86-64 |
Changes (by hamish):
  * keywords: => Makefile
Comment:
the original line is here:
https://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/Makefile#L296
-sed -i -e 's#/tools/g.html2man/g.html2man$#/tools/g.html2man#'
${INST_DIR}/include/Make/Man.make
Hamish
ps- with r43791 are make: htmldocs-single, htmldocs, packagehtmldocs,
pdfdocs, cleandocs, html2pdfdoc, html2pdfdoccomplete, changelog now dead
for 6.5svn?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1191#comment:1&gt;
Keywords: Makefile | Platform: All
      Cpu: All |
Changes (by glynn):
  * platform: Linux => All
  * cpu: x86-64 => All
Comment:
Replying to [comment:1 hamish]:
-sed -i -e 's#/tools/g.html2man/g.html2man$#...
I'm fairly sure that "$#" should just be "#".
Ticket URL: <https://trac.osgeo.org/grass/ticket/1191#comment:2&gt;
      Cpu: All |
Comment(by hamish):
Replying to [comment:2 glynn]:
Makefile quoting/expansion rules different from Bourne shell ones?
EOL$ now removed in 6.5svn r43811
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1191#comment:3&gt;
      Cpu: All |
Comment(by glynn):
Replying to [comment:3 hamish]:
My mistake; you meant a literal $ as the EOL marker in a regexp, right? In
which case, use "$$":
-sed -i -e 's#/tools/g.html2man/g.html2man$$#...
Yes. make doesn't have '''any''' quoting rules. Anything involving a $
will be expanded somehow, wherever it occurs. Normal variables (and
function calls) use $(...) or ${...}. A "$" followed by any of `@%<?^+|*`
is an automatic variable, set based upon a rule's target and/or
prerequisites. "$$" evaluates to a literal "$". A "$" followed by anything
else evaluates to the empty string.
After such substitutions, each command is passed directly to the shell,
including any quotes, so the quotes should be whatever the shell itself
requires. Quotes in a command have no effect upon the substitutions
performed by make.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1191#comment:4&gt;
      Cpu: All |
Comment(by hamish):
Replying to [comment:4 glynn]:
yes. Just a small attempt to make the search string more exact, but as
that's the only occurrence of g.html2man in the include/Man.make file it
wasn't strictly required.
> In which case, use "$$":
thanks for the info. I've never been very strong on Makefile syntax and
have never found a good resource explaining it.
AFAIU none of the wingrass/mac/debian/... packaging scripts actually run
'make install', so after verifying that these changes do in fact help to
make g.extension functional on installed copies of GRASS we still need to
port these sed replacements around to the other branches and packaging
scripts.
Also, to make GRASS_ADDON_PATH work with the 'make install' dir structure
for local users, in (experimental) 6.5svn g.extension I've symlinked the
binary back into ~/.grass6/addons/ from ~/.grass6/addons/{bin|scripts}/
using 'ln -s'. I take it on wingrass this will still work, but by making a
full copy of the file?
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1191#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: Makefile
  Platform: All | Cpu: All
  * status: new => closed
  * resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/1191#comment:6&gt;
      Type: defect | Status: reopened
Resolution: | Keywords: Makefile
Changes (by hellik):
  * status: closed => reopened
  * resolution: fixed =>
Comment:
Replying to [comment:6 hamish]:
maybe related?
tested with r43842 in the osgeo4w-build-environment.
compilation ok, but installing isn't
GRASS GIS compilation log
Started compilation: Sun Oct 10 06:57:40 GMT 2010
Errors in:
No errors detected.
Finished compilation: Sun Oct 10 08:35:57 GMT 2010
Sun Oct 10 08:35:57 GMT 2010: STARTING make install
include/Make/Doxygen.make:13: warning: overriding commands for target
`htmldocs -single'
include/Make/Docs.make:11: warning: ignoring old commands for target
`htmldocs- single'
include/Make/Doxygen.make:19: warning: overriding commands for target
`htmldocs '
include/Make/Docs.make:38: warning: ignoring old commands for target
`htmldocs'
include/Make/Doxygen.make:39: warning: overriding commands for target
`pdfdocs'
include/Make/Docs.make:49: warning: ignoring old commands for target
`pdfdocs'
include/Make/Doxygen.make:51: warning: overriding commands for target
`cleandoc s'
include/Make/Docs.make:55: warning: ignoring old commands for target
`cleandocs '
echo /c/osgeo4w/usr/src/grass6_devel/bin.i686-pc-mingw32/grass65
make[1]: Entering directory `/c/osgeo4w/usr/src/grass6_devel'
`htmldocs -single'
`htmldocs- single'
`htmldocs '
`htmldocs'
`pdfdocs'
`pdfdocs'
`cleandoc s'
`cleandocs '
test -d /c/OSGeo4W/apps/grass/grass-6.5.svn || mkdir -p -m 755
/c/OSGeo4W/apps/ grass/grass-6.5.svn
test -d /c/OSGeo4W/bin/bin || mkdir -p -m 755 /c/OSGeo4W/bin/bin
sed -e "s#^GISBASE.*#GISBASE=/c/OSGeo4W/apps/grass/grass-6.5.svn#"
/c/osgeo4w/u sr/src/grass6_devel/bin.i686-pc-mingw32/grass65 >
/c/OSGeo4W/bin/bin/grass65
chmod a+x /c/OSGeo4W/bin/bin/grass65
sed -e "s#WINGISBASE=.*#WINGISBASE=/c/OSGeo4W/apps/grass/grass-6.5.svn#"
/c/osg eo4w/usr/src/grass6_devel/bin.i686-pc-mingw32/grass65.bat >
/c/OSGeo4W/bin/bin/ grass65.bat
chmod a+x /c/OSGeo4W/bin/bin/grass65.bat
cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf -
AUTHORS COP YING CHANGES REQUIREMENTS.html GPL.TXT contributors.csv
translators.csv | (cd / c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - )
2>/dev/null
cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - bin |
(cd / c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
bwidget | ( cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - )
2>/dev/null
cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - docs |
(cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - driver
| (c d /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - ) 2>/dev/null
cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - etc |
cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - fonts
cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - man |
tar: man: Cannot stat: No such file or directory
tar: Error exit delayed from previous errors
scripts | ( cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - )
2>/dev/null
cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - tools
if [ 1 -eq 1 ] ; then cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
mingw32 ; tar cBf - locale | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn ;
tar xBf - ) 2>/de v/null ; fi
include | ( cd /c/OSGeo4W/apps/grass/grass-6.5.svn ; tar xBf - )
2>/dev/null
sed -i -e "s#^\(GRASS_HOME.[^=]*\).*#\1=
/c/OSGeo4W/apps/grass/grass-6.5.svn#" -e "s#^\(RUN_GISBASE.[^=]*\).*#\1=
/c/OSGeo4W/apps/grass/grass-6.5.svn#" /c/OSG
eo4W/apps/grass/grass-6.5.svn/include/Make/Platform.make
sed: invalid option -- i
Usage: sed [OPTION]... {script-only-if-no-other-script} [input-file]...
   -n, --quiet, --silent
                  suppress automatic printing of pattern space
   -e script, --expression=script
                  add the script to the commands to be executed
   -f script-file, --file=script-file
                  add the contents of script-file to the commands to be
executed
   -c --nocr turn off \r$ translation; must be first switch on command
line
       --help display this help and exit
   -V, --version output version information and exit
If no -e, --expression, -f, or --file option is given, then the first
non-option argument is taken as the sed script to interpret. All
remaining arguments are names of input files; if no input files are
specified, then the standard input is read.
E-mail bug reports to: bug-gnu-utils@gnu.org .
Be sure to include the word ``sed'' somewhere in the ``Subject:'' field.
make[1]: [real-install] Error 4 (ignored)
sed -i -e 's#/tools/g.html2man/g.html2man#/tools/g.html2man#'
/c/OSGeo4W/apps/g rass/grass-6.5.svn/include/Make/Man.make
executed
line
cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32 ; tar cBf - lib |
sed 's#'/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
mingw32'#'/c/OSGeo4W/apps/ grass/grass-6.5.svn'#g'
/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/et c/monitorcap >
/c/OSGeo4W/apps/grass/grass-6.5.svn/etc/monitorcap
/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/et c/fontcap >
/c/OSGeo4W/apps/grass/grass-6.5.svn/etc/fontcap
chmod -R a+rX /c/OSGeo4W/apps/grass/grass-6.5.svn 2>/dev/null
tar cBf - gem/skeleton | (cd /c/OSGeo4W/apps/grass/grass-6.5.svn/etc ; tar
xBf - ) 2>/dev/null
tar: gem/skeleton/.svn/text-base: file changed as we read it
tar: gem/skeleton/.svn/tmp: file changed as we read it
tar: gem/skeleton/.svn: file changed as we read it
tar: gem/skeleton: file changed as we read it
/bin/install -c gem/gem65 /c/OSGeo4W/bin/bin 2>/dev/null
make[1]: Leaving directory `/c/osgeo4w/usr/src/grass6_devel'
Sun Oct 10 08:37:41 GMT 2010: STARTING cleanup
sed: can't read /c/OSGeo4W/apps/grass/bin/grass65: No such file or
directory
there seems to be all files in C:\OSGeo4W\apps\grass\grass-6.5.svn, but
in C:\OSGeo4W\apps\grass\bin there is only grass65.tmpl
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1191#comment:7&gt;
Comment(by hamish):
Replying to [comment:7 hellik]:
> maybe related?
yes, it's related. 'sed -i' isn't present in MSys. Pity, as it's really
very handy. FWIW it isn't strictly part of the standard but MacOSX does
have it. MSys is using's GNU's version of it, I guess they removed it
because Windows is much more picky about what you can do with an open
file. ?
hopefully fixed in r43854.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1191#comment:8&gt;
Comment(by hellik):
Replying to [comment:8 hamish]:
> > maybe related?
file. ?
not really
Started compilation: Mon Oct 11 15:36:04 GMT 2010
Errors in:
No errors detected.
Finished compilation: Mon Oct 11 17:11:23 GMT 2010
Mon Oct 11 17:11:23 GMT 2010: STARTING make install
`htmldocs -single'
`htmldocs- single'
`htmldocs '
`htmldocs'
`pdfdocs'
`pdfdocs'
`cleandoc s'
`cleandocs '
`htmldocs -single'
`htmldocs- single'make[1]:
`htmldocs '
`htmldocs'
`pdfdocs'
`pdfdocs'
`cleandoc s'
`cleandocs '
/c/OSGeo4W/apps/
grass/grass-6.5.svn
/c/osgeo4w/u
/c/osg
REQUIREMENTS.html GPL.TXT contributors.csv translators.csv | (cd /
(cd /
bwidget | ( cd
(cd
| (c d
(cd /
| (cd
(cd /
scripts | ( cd
| (cd
v/null ; fi
include | ( cd
sed -e "s#^\(GRASS_HOME.[^=]*\).*#\1=
"s#^\(RUN_GISBASE.[^=]*\).*#\1= /c/OSGeo4W/apps/grass/grass-6.5.svn#"
/c/osgeo4
w/usr/src/grass6_devel/dist.i686-pc-mingw32/include/Make/Platform.make >
/c/OSG
sed -e 's#/tools/g.html2man/g.html2man#/tools/g.html2man#'
rass6_devel/dist.i686-pc-mingw32/include/Make/Man.make >
(cd /
grass/grass-6.5.svn'#g' /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
xBf - ) 2>/dev/null
Mon Oct 11 17:12:54 GMT 2010: STARTING cleanup
directory
in C:\OSGeo4W\usr\src\grass6_devel\bin.i686-pc-mingw32 there are shell-
script and bat-file, but in C:\OSGeo4W\apps\grass\bin there is again only
grass65.tmpl
best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1191#comment:9&gt;
Comment(by hamish):
It did fix the 'sed -i' error, the errors you are seeing are unrelated.
this seems to be the first error seen:
are no man pages on WinGrass a known feature or a bug?
test -d /c/OSGeo4W/apps/grass/grass-6.5.svn || \
    mkdir -p -m 755 /c/OSGeo4W/apps/grass/grass-6.5.svn
sed -e "s#^GISBASE.*#GISBASE=/c/OSGeo4W/apps/grass/grass-6.5.svn#" \
    /c/osgeo4w/usr/src/grass6_devel/bin.i686-pc-mingw32/grass65 \
    > /c/OSGeo4W/bin/bin/grass65
sed -e "s#WINGISBASE=.*#WINGISBASE=/c/OSGeo4W/apps/grass/grass-6.5.svn#" \
    /c/osgeo4w/usr/src/grass6_devel/bin.i686-pc-mingw32/grass65.bat \
    > /c/OSGeo4W/bin/bin/grass65.bat
is /c/OSGeo4W/bin/bin/ correct ?
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1191#comment:10&gt;
Comment(by hellik):
Replying to [comment:10 hamish]:
I can remember darkly a discussion about this in the ML, it's about a year
or longer ago.
it should be C:\OSGeo4W\apps\grass\bin.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1191#comment:11&gt;
Resolution: | Keywords: Makefile, g.html2man, sed
  * keywords: Makefile => Makefile, g.html2man, sed
Comment:
missing man pages are a separate issue than this bug, and should probably
be moved to a new ticket.
the sed error is fixed anyway.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1191#comment:12&gt;
  Priority: normal | Milestone: 6.4.3
Resolution: fixed | Keywords: Makefile, g.html2man, sed
Changes (by neteler):
  * status: reopened => closed
  * milestone: 6.5.0 => 6.4.3
Comment:
Replying to [comment:12 hamish]:
probably be moved to a new ticket.
Closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1191#comment:13&gt;
Comment(by hamish):
before this is forgotten, did that ever happen? or are man pages not
wanted/relevant on Windows?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1191#comment:14&gt;
