[GRASS-dev] [GRASS GIS] #1193: Python Menu: Japanese (double byte character) in menu may cause parser error.
error.
Reporter: naokiueda | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Python | Version: 6.4.0
Keywords: | Platform: MSWindows 7
      Cpu: Unspecified |
In Japanese environment, r.reclass from menu GUI does not launched.
It is because Japanese character is double byte, and if first byte or
second bite is same code as '<', '>', or maybe '\', it cause parser error.
One of same trouble has been solved by following, but it looks like other
problem (caused by same mechanism) still remain.
GRASS in OSGEO4W, it is fix
in File menuform.py rev.43275 Line 1280
         # parse the interface decription
         self.grass_task = grassTask()
         handler = processTask(self.grass_task)
         enc = locale.getdefaultlocale()[1]
         if enc and enc.lower() not in ("utf8", "utf-8"):
xml.sax.parseString(getInterfaceDescription(cmd[0]).decode(enc).split('\n',1)[1].replace('',
'<?xml version="1.0" encoding="utf-8"?>\n', 1).encode("utf-8"),
                             handler)
         else:
             xml.sax.parseString(getInterfaceDescription(cmd[0]),
                             handler)
Verion
GRASS 6.4.0 (2010)
Revision: 37101
Date: 2009-05-10 13:35:38 +0200 (So, 10 Mai 2009)
(Fri Oct 08 17:30:18 2010) コマンド終了 (0 sec)
Error Log
   File "C:/GRASS__6401/etc/wxpython/wxgui.py", line 540, in
OnMenuCmd
cmd = self.GetMenuCmd(event)
   File "C:/GRASS__6401/etc/wxpython/wxgui.py", line 527, in
GetMenuCmd
input =
menuform.GUI().GetCommandInputMapParamKey(cmdlist[0])
   File
"C:\GRASS__6401\etc\wxpython\gui_modules\menuform.py", line
1944, in GetCommandInputMapParamKey
xml.sax.parseString(getInterfaceDescription(cmd), handler)
   File "C:\OSGeo4W\apps\Python25\lib\xml\sax\__init__.py",
line 49, in parseString
parser.parse(inpsrc)
   File
"C:\OSGeo4W\apps\Python25\lib\xml\sax\expatreader.py", line
107, in parse
xmlreader.IncrementalParser.parse(self, source)
   File "C:\OSGeo4W\apps\Python25\lib\xml\sax\xmlreader.py",
line 123, in parse
self.feed(buffer)
   File
211, in feed
self._err_handler.fatalError(exc)
   File "C:\OSGeo4W\apps\Python25\lib\xml\sax\handler.py",
line 38, in fatalError
raise exception
xml.sax._exceptions
SAXParseException
<unknown>:1:30: unknown encoding
Also, when I download source file, it's encoding is ascii (Shift-JIS, for
japanese) and not UTF-8. I think source file should be in UTF-8.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1193&gt;
error.
      Cpu: Unspecified |
Comment(by neteler):
I have tried on Linux and I could launch r.reclass in Japanese without
problems. Perhaps it is
a Windows-only problem.
Wish: please submit your changes as patch as attachment to this ticket.
for
To which file do you refer?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1193#comment:1&gt;
error.
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:1 neteler]:
AFAICT, it's a problem with Shift-JIS (cp932), which isn't compatible with
ASCII. Unix systems use EUC-JP, which doesn't have this problem.
Shift-JIS is a multi-byte encoding. Non-ASCII characters have a first byte
with the top bit set, but the second byte can be any value >= 64. While
this excludes the digits and most of the punctuation characters, it
includes `[\]^_{|}~`.
This makes it incompatible with any code which parses a stream of bytes
without reference to the encoding, as e.g. '\' (0x5c) might be an ASCII
'\' or it might be the second byte of a JISX0208 character; you can't tell
without tracking the shift state.
Unfortunately, the only Japanese encoding which is supported by Windows'
codepage-based API is Shift-JIS (actually, codepage 932, which is Shift-
JIS plus the usual Microsoft-specific extensions). There is no UTF-8
codepage (cp 65001 is UTF-8, but it can't be used as a normal codepage).
I don't think that there's any solution to this, other than "don't use
kanji (or hiragana or full-width katakana) in command lines". GRASS is
stuck using the codepage-based API (unless someone wants to implement
UTF-8 equivalents of all of the ANSI C and POSIX functions, and change all
of GRASS to use them), and expecting every function which deals with char*
to decode it according to the current locale isn't feasible.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1193#comment:2&gt;
error.
Keywords: wingrass | Platform: MSWindows 7
      Cpu: Unspecified |
Changes (by hellik):
  * keywords: => wingrass
Ticket URL: <http://trac.osgeo.org/grass/ticket/1193#comment:3&gt;
error.
      Cpu: Unspecified |
Comment(by hamish):
note here says it's fixed? [wiki:Release/6.4.2RC2-News#GUIchanges]
  * "wxGUI: fixed for languages which use double-byte characters (Japanese
etc)"
Ticket URL: <https://trac.osgeo.org/grass/ticket/1193#comment:4&gt;
error.
Priority: major | Milestone: 6.4.3
      Cpu: Unspecified |
Changes (by neteler):
  * milestone: 6.4.1 => 6.4.3
Comment:
Replying to [comment:4 hamish]:
(Japanese etc)"
Is it fixed? This is not clear to me.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1193#comment:5&gt;
