[GRASS-dev] [GRASS GIS] #1196: v.krige.py fails with ImportError: No module named vkrige
Reporter: marisn | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Vector | Version: svn-develbranch6
Keywords: | Platform: Linux
      Cpu: x86-64 |
GRASS 6.5 r43904
GRASS 6.5.svn (personal_spearfish_60):~/soft/grass6_devel > v.krige.py
Loading packages, please wait...
Loading required package: sp
Loading required package: rgdal
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.7.2, released 2010/04/23
Path to GDAL shared files: /usr/share/gdal
Loaded PROJ.4 runtime: Rel. 4.7.1, 23 September 2009
Path to PROJ.4 shared files: (autodetected)
Loading required package: XML
GRASS GIS interface loaded with GRASS version: 6.5.svn
and location: personal_spearfish_60
Loading required package: foreign
Loading required package: lattice
         Note: polygon geometry computations in maptools
         depend on the package gpclib, which has a
         restricted licence. It is disabled by default;
         to enable gpclib, type gpclibPermit()
Checking rgeos availability as gpclib substitute:
FALSE
   File "/home/maris/soft/grass6_devel/dist.x86_64-unknown-linux-
gnu/scripts/v.krige.py", line 422, in <module>
     main()
gnu/scripts/v.krige.py", line 312, in main
     import vkrige as GUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/1196&gt;
Keywords: v.krige | Platform: Linux
      Cpu: x86-64 |
Changes (by hamish):
  * keywords: => v.krige
Comment:
apparently it needs to be started with:
  v.krige.py --ui
to forcibly launch the parser. probably an easy fix for that, but I'm not
sure of the exact incantation.
(also it would be good to tweak the Makefile to install the module to
$GISBASE/scripts/ ''without'' the .py extension)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1196#comment:1&gt;
Component: Python | Version: svn-develbranch6
      Cpu: x86-64 |
  * component: Vector => Python
Comment:
it seems to be working now in devbr6, closing bug.
That the module installs as g.module.py, g.module.py.html and
g.module.py.1 to be continued in #1768, #1555, and #2010.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1196#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.krige
  Platform: Linux | Cpu: x86-64
  * status: new => closed
  * resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/1196#comment:3&gt;
      Type: defect | Status: reopened
Resolution: | Keywords: v.krige
  * status: closed => reopened
  * resolution: fixed =>
Comment:
... in devbr6 it works from the command line but the GUI window still
gives a couple of tracebacks:
  * After loading a map and selecting a column, press [Plot/refresh
variogram], and:
   File "/home/hamish/src/grass/svn/grass65/dist.x86_64-unknown-linux-gnu\
     /etc/wxpython/scripts/vkrige.py", line 445, in OnPlotButton
     if globals()["InputData"] is None:
KeyError: 'InputData'
the global var isn't making it out of the outer v.krige.py wrapper..?
and,
  * if you press [Run]
     /etc/wxpython/scripts/vkrige.py", line 257, in OnRunButton
     self.goutput.RunCmd(command, switchPage = True)
     /etc/wxpython/gui_core/goutput.py", line 587, in RunCmd
     self._notebook.SetSelectionByName('output')
AttributeError: 'FlatNotebook' object has no attribute
'SetSelectionByName'
any hints?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1196#comment:4&gt;
Comment(by aghisla):
Probably fixed in trunk #57146 , but keeping this one open until backport
to devbr6.
Greetings from Prague,
Anne
Ticket URL: <http://trac.osgeo.org/grass/ticket/1196#comment:5&gt;
