#1198: Error while parsing file paths in WiNGRASS with Python Script
Reporter: luislisboa1975 | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: wxGUI | Version: svn-releasebranch64
Keywords: | Platform: MSWindows XP
Cpu: Unspecified |
In a Python Script, in WinGRASS6.4.1(svn) all "\" in file paths are
eliminated.
It only runs if users use "/"
Keywords: wingrass | Platform: MSWindows XP
Cpu: Unspecified |
Comment(by hamish):
is this from within a specific grass module, from the wxGUI command entry
box, or from a self-written script?
the `\` is used to quote the character which follows it verbatim.
so `C:\Program Files\GRASS\scripts` reduces to `C:Program
FilesGRASSscripts`.
one solution as pointed out is to use `/` instead. Another way is to use
two of them, so that the second one gets quoted verbatim: `\\`.
ISTR that some OS-specific magic was added to the wxGUI command parser,
but I suspect the solution to this will ultimately be education:
gratuitous tooltips and inset Caution-boxes in the wxGUI help pages.
Cpu: Unspecified |
Comment(by benducke):
Actually, the problem goes deeper than the wxGUI. I have experienced it
(Windows only) with shell scripts. Basically, g.parser seems to remove all
occurrences of "\" from a file type input or output option. I think this
should be fixed in g.parser, not by forcing Windows users to adopt a
notation that is strange on their system. In addition, the option value
may come from a Windows file browser, which will certainly produce the "\"
Windows notation.
#1198: Error while parsing file paths in WinGRASS with Scripts
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:3 benducke]:
Windows notation.
It isn't g.parser doing this. It's either wxGUI (e.g. shlex.split) or the
shell.
In any case, this ticket contains insufficient information to attempt
reproduction. At a minimum, we require the exact command entered, the
means by which it was entered (cmd.exe, bash, wxGUI, etc), the GRASS
version, and the result.
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:5 glynn]:
it (Windows only) with shell scripts. Basically, g.parser seems to remove
all occurrences of "\" from a file type input or output option. I think
this should be fixed in g.parser, not by forcing Windows users to adopt a
Windows notation.
the shell.
I think #1447 is related, and complete with an example and a detailed
description.
